What kind of camper do you have???
Discussion in 'Towing & Hauling' started by Muleycrazy13, Feb 12, 2017.
  1. Oct 5, 2022 at 9:37 PM
    #721
    Retroboy1989
    Northern Utah
    I've seen a lot of recommendations to tow in S4. I just did a 5 hour tow from southern to northern Utah. I've found that S4 puts the tach around 2700 at 60mph and around 3000 at 66-67mph. I did alot of this drive in S4 between 60-65mph as I used rural highways instead of I-15 for over half of the distance. I tried using S5 where I could, but the highways are generally hilly and I couldn't hold TC lockup in 5th on any real incline, and I found myself force shifting to 4th to get back into lockup. Once on I-15, it was easier to hold 5th in lockup at 70mph.
    My question is this: how hard is it on the engine to hold 2800-3000 for several hours straight? I know higher revs help the trans as it limits shifting and keeps the TC in lockup, but how does that running affect a 5.7? Piston rings, bearings, timing chain, valvetrain, etc are they built for prolonged mid-rpm running? Obviously, the engine can do it, but at the cost of additional wear?
    I found that the engine roar actually quieted some at exactly 65mph, just under 3000rpm, so I spent a long part of the drive there.
    Wallygator and Cpl_Punishment like this.
  2. Oct 6, 2022 at 3:30 AM
    #722
    Built for it. DOHC VVTi revver.
  3. Oct 6, 2022 at 7:22 AM
    #723
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Not specific to the 5.7 but I've been told about 4000 rpm is generally about the max you want to run for a prolonged period of time.
  4. Oct 6, 2022 at 12:33 PM
    #724
    Boat outboards will run 4,000 rpm for hours and hours.
  5. Oct 6, 2022 at 12:36 PM
    #725
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'll keep that it mind if I'm using my boat to tow my trailer. :rofl:
  6. Oct 6, 2022 at 12:37 PM
    #726
    A 5.7 is just a pair of 2.8 four bangers sharing a crank.
    CaptRussia253 and Wallygator like this.
  7. Oct 6, 2022 at 12:46 PM
    #727
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
  8. Oct 7, 2022 at 4:15 PM
    #728
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    At the Soo locks.
  9. Oct 7, 2022 at 4:16 PM
    #729
    ZPMAN
    Minnesota
  10. Oct 7, 2022 at 4:23 PM
    #730
    Ruger19
    Ruger19 New Member
    2022 Tundra
    Older Jayco Jay flight 28bhs. Had a 2007 Tundra that towedPIbGbKVs8oh6DQ4ftDuzEYxnOoqAvYLs5_65mtxW_827cd45c868761063c41cd753edd6e7c76a084e0.jpg it for 10 years. Now have the 3rd gen, tows much better all the way around.
    Malinois38 and Wallygator like this.
  11. Oct 13, 2022 at 8:02 AM
    #731
    89toyotanc
    89toyotanc New Member
    Connor
    Charlotte, NC
    2013 Tundra Rock Warrior Edition
    Stock
    Headed out for the weekend to see the fall colors in Smoky Mountains towing our Jayco Jayflight 245RLS.
  12. Oct 16, 2022 at 12:26 AM
    #732
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    2017.5 Lance 1685
    Towed it for 6 years with my 4.7 '00 1st gen, just got the '19 and going camping in a couple weeks.
  13. Oct 16, 2022 at 5:26 AM
    #733
    Looks like a nice little set up. You planning to add a transmission cooler to your '19, or did you already?
  14. Oct 16, 2022 at 7:12 AM
    #734
    SD Surfer
    Bruce
    So Cal
    Thanks, we love it. It's pretty comfy, and has been remarkably trouble free.
    Haven't added one yet, I didn't realize they'd deleted the cooler till after I'd bought it. ('Cuz why the hell would they do THAT?!) :der::facepalm:I do question the wisdom of that move a little, but I figure most of the engineers at Toyota are smarter than me.
    I'll probably get an OBD dongle to monitor temps for a few trips towing before I decide whether or not to add one, curious what adding one does to the warranty.
    Maybe just change the ATF more often.
    My trailer's only about 5,500 lbs wet and loaded so the truck and trans won't be working too hard.
  15. Oct 17, 2022 at 11:58 AM
    #735
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Just came back from the last trip of the season, we loved every trip with this thing, can't wait for the next season.
  16. Oct 17, 2022 at 12:04 PM
    #736
    SD Surfer
    Bruce
    So Cal
    Holy CRAP, what a great spot!!
    Nice set-up too.
  17. Oct 17, 2022 at 12:05 PM
    #737
    Why is this the last trip? The good camping season is just getting started here.
  18. Oct 17, 2022 at 1:40 PM
    #738
    Downytide
    GTA
    Gets pretty cold, lots of snow, and most provincial parks are closed unless you want to camp on crown land (like BLM), but then unless I put tracks on the truck it won't make to most spots.
    it was a beautiful spot, nothing like desert scenery, hopefully next year/2024 can make the big west coast trip.
    this was one of the view the wife took, that's lake Ontario, not an ocean.
  19. Oct 17, 2022 at 2:23 PM
    #739
    SD Surfer
    Bruce
    So Cal
    My desert, your woods, lakefront, or ocean...
    With these views as our front yard, sitting there with a cup of good coffee and smellin' the bacon cooking, it doesn't get much better. :bananadance:
  20. Oct 17, 2022 at 5:48 PM
    #740
    Casper421
    In the woods
    06 DC
    How much does your trailer weigh? How did the 00 pull it?
  21. Oct 17, 2022 at 5:59 PM
    #741
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    Last camping trip/bike race of the year for us.
  22. Oct 17, 2022 at 6:05 PM
    #742
    Dunes
    Dunes New Member
    JJ
    2023 Grey CrewCab 6.5 TUN 4x4
    I carry my Rock A Bye bye camper builder out of Casa Grande AZ .. its dry camper and sitting on my 08-LB-SC. WIll post pict later
  23. Oct 17, 2022 at 6:52 PM
    #743
    SD Surfer
    Bruce
    So Cal
    GVWR is 5,500 lbs. and I'm probably pretty close to that most trips.
    The '00 w/4.7 did very well, a little slow up some grades but that was due more to gearing than lack of power.
    I tend to drive more by the tach than the speedo when towing, and with OD off there's certain grades that it can't quite hold 3rd at the speed I'd like, but 2nd revs too high, so I just downshift and slow down.
    Other than that it was a pretty well matched combo, very stable and uneventful.
  24. Oct 17, 2022 at 7:26 PM
    #744
    Retroboy1989
    Northern Utah
    Yep, only difference is trying to hold 4th with a 6 speed here.
    I like it when I get on the just right grade with the TC locked in 4th and let torque and horsepower do the work. I find mine will go up to at least 59% throttle without unlocking if I can keep it around 60mph.
  25. Oct 17, 2022 at 7:29 PM
    #745
    Casper421
    In the woods
    06 DC
    Glad to hear! Just bought a 21’ at 3000lbs dry. Have some 4.88’s I’m gonna slap in and shouldn’t even feel it back there!
  26. Oct 17, 2022 at 10:33 PM
    #746
    SD Surfer
    Bruce
    So Cal
    I'm looking forward to the difference between having a very adequate tow vehicle and a towing beast.
    From 245 HP to 381
    From 315 Ft/lbs to 401
    From 3:91's to 4:30's
    From 3 usable gears to 4 (Maybe 5 on flats)
    From undersized disc/drum brakes to proper 4 wheel disc
    The '00 never failed me in 6 years, did it's job well, and didn't mind being beat on a little after we set up camp.
    But the '19 is gonna' make my life a bit easier I'm sure.
    OHwendTrd and 16CMTXED like this.
  27. Oct 17, 2022 at 10:36 PM
    #747
    SD Surfer
    Bruce
    So Cal
    Oh yeah, you're golden. Use them 4:88's for engine braking on the downhills for sure...
    My only knock on the '00 is that they're a little underbraked IMHO.
    What kind of trailer did you get? Pictures man, we like pitchers! :worthless:
    Cpl_Punishment likes this.
  28. Oct 18, 2022 at 2:58 AM
    #748
    Made this exact transition myself (kept the FGT) and have enjoyed towing with the ‘19. The thing you left out is the additional tow vehicle weight. Feels very stable and capable compared to my 2000. I tow in S4 and haven’t monitored trans temps. If I was towing any real distance, I would probably add the trans cooler. My longest runs are an hour or 2 here to some state parks.
  29. Oct 18, 2022 at 7:25 AM
    #749
    Casper421
    In the woods
    06 DC
    Agree on the brakes and I plan on a rear disc conversion and gx460 brakes up front. Should be a huge improvement in braking.
    We picked up a Jayco jay feather 195rb Baja.
    Can’t wait to get delivery and start making it our own!
    Wallygator and JDR76 like this.
  30. Oct 18, 2022 at 8:02 AM
    #750
    SD Surfer
    Bruce
    So Cal
    Good point on the extra weight. My '00 always felt very stable, I'm sure some of that from the Andersen WDH... they may not transfer as much weight as traditional spring bar systems, but they're known for having very effective sway control.
    Yeah, with both wifey and I still working FT, most of our trips are the same as yours. Rarely more than 200 miles round trip. Had the trailer 6 years next month and it has less then 7K miles :(
    Fortunately living in San Diego we have a gold mine of good camping close to home... beach, mountains, desert, even some pretty good boondocking. And other than avoiding the desert in the summer, no off season to worry about.
    Good looking rig!!
    Looks like it has good ground clearance for boondocking!!
