  1. Oct 16, 2022 at 6:44 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Wash/strip, iron remover, clay bar, wax and trim treatment
    Henry1jg, Nbab23, coldcanuk and 22 others like this.
  2. Oct 16, 2022 at 6:59 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The link won’t work, but the part numbers will.
    you have push button start, so you need the expensive front door handles because they include the electronics for the keykess entry.
    easiest thing to do is order the complete kit from Sparks
    https://www.sparksparts.com/p-tundra-smart-entry-handle-kit-crewmax-pkkitcrse
  3. Oct 16, 2022 at 7:02 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Ahh nice! That’s exactly what I was looking for, thank you sir! :bowdown:
  4. Oct 17, 2022 at 4:18 AM
    Millwood21
    Millwood21 New Member
    Jade
    2017 Platinum
    Pulled off the stock chrome steps to see how it looked. Waiting to pull the trigger on some sliders. May put the stocks back for now to protect from rock chips.
  5. Oct 17, 2022 at 5:01 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    No pictures but I finally replaced my original front rotors and pads after 20K miles of pulsing. Found some bad spots on the pads in the process.
    Looked around for cam leak spots. Still dry!
    Wired up my heated front seats. I naturally get hot really quick but these are nice for the first 15 minutes of my drive in the morning.
    Washed it before it rains again tomorrow.
    Signed the paperwork to buy out the lease.
    Successful weekend.
    Henry1jg, coldcanuk, Fedorsi and 12 others like this.
  6. Oct 17, 2022 at 8:32 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey Baja Mike, That rack turned out great. Thanks for running Baja Designs S2 on your setup.
    Best,
    Brandon
    Baja Mike[QUOTED] likes this.
  7. Oct 17, 2022 at 11:35 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Finally got around to installing the ESP plastic underseat storage for CrewMax. Easy install, looks good. Nice to have some storage bins under the seat.
    coldcanuk, ATV25, Baja Mike and 3 others like this.
  8. Oct 17, 2022 at 11:48 AM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Anyone know how to extract fuel from tank to test?
    Tried to siphon but there is a valve preventing the tube from going into tank (good to know).
    Thinking I may have to extract from fuel rail, but wanted to check with everyone in case there is easier way…
  9. Oct 17, 2022 at 12:54 PM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    I may have a little pecker, but what I lack down south I make up for with the Rock Warriors.
  10. Oct 17, 2022 at 1:00 PM
    RobertD
    Robert
    DFW, Texas
    Such a good looking wheel and that color works magnificently with your truck!!
    :101010:
  11. Oct 17, 2022 at 2:01 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Looks badass. I too have a little pecker but make up for it with a huge sack so I’ll be staying with 35s for now.
  12. Oct 17, 2022 at 3:08 PM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Looks awesome!! Do you have spacers on those bad boys?
  13. Oct 17, 2022 at 3:13 PM
    Ckatz53
    Ckatz53 Newish
    MD
    Yeah 2" boras because I was running 35s and the oem off road 18" wheels. Downsized to RW wheels and went up to 37s so this is entirely too aggressive at a -1 offset (bad rubbing at the pinch weld). Swapping these for another forum members Spidertrax 1.25" to put me in a better offset range then have to chop and reweld the pinch. Waiting for the Spidertrax to arrive so I can mount up and see how much I'll need to remove. Should be around +18.25 offset. Slightly more aggressive than the suggested +25 mark for these wheels/tires but I'll make it work. Nothing a plasma cutter/grinding wheel and some visually unappealing mig welding can't fix.
  14. Oct 17, 2022 at 3:30 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Did truck stuff. Picked up a 2001 TT-R 125 for my Son's 13th birthday in a couple weeks. It'll be his first bike. I think I may be bitten by the bug as well. That thing is fun!
  15. Oct 17, 2022 at 7:14 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
  16. Oct 17, 2022 at 9:38 PM
    Retroboy1989
    Northern Utah
    I've really liked this.
    https://www.amazon.com/dp/B01NALK2FC
  17. Oct 18, 2022 at 6:15 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Love it!!
  18. Oct 18, 2022 at 6:56 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    We rented a 1800s farmhouse for a week on the water (northern neck), right at where the little Wicomico dumps into the bay.
    I averaged 16.4 mpg for the week, 300 miles. Driving there and home loaded with 2 kayaks in the bed and the truck full of gear, 3 days of 4wd low use running from the farmhouse to the dock and then various running around to the different towns close by for fun or shopping. Considering I am lifted and run 275/70 E load, I didnt think 16.4MPG (hand calculated) was too bad. Hand calculation was better than the computer which had MPG listed at 15.7.
    Here are some pics
  19. Oct 18, 2022 at 6:59 AM
    frichco228
    Frank
    Virginia
    Oh, and I got notice just yesterday that my Cryto treated rotors and new pads have shipped. Been waiting for them a month plus, they were not supposed to ship until mid November so I am happy they will be arriving early. I went with Akebono performance pads and stop tech slotted Cryo rotors for the front. Will probably replace the rear brakes in the spring.
    Tundrastruck91 and CaptRussia253 like this.
  20. Oct 18, 2022 at 7:50 AM
    I have the StopTech Sport slotted on mine on all 4 corners.
  21. Oct 18, 2022 at 7:54 AM
    AJT knobs and painted factory rings. I slipped a tooth or 2 removing the first knob (fan speed) but that's what the sharpie marks are for.
    Compress_20221018_104840_0453.jpg Compress_20221018_104839_9586.jpg Compress_20221018_104841_1779.jpg Compress_20221018_104840_0177.jpg Compress_20221018_104841_1195.jpg
  22. Oct 18, 2022 at 9:41 AM
    Millwood21
    Jade
    2017 Platinum
    BD lights came. Waiting on a harness and my switch pro and I’ll get this thing installed and wired up.
    8F1E1734-93B3-46C8-BF1C-D1886552F1B3.jpg A8F20687-7C2A-4E0D-913C-662717FB9194.jpg
  23. Oct 18, 2022 at 9:47 AM
    Baja Designs
    San Marcos, CA
    Hey @Millwood21, That third brake light is gonna look great. I've been considering adding one to my truck. Post a picture when you have it all installed I would love to see it on the truck.
    Best,
    Brandon
    Millwood21[QUOTED] likes this.
  24. Oct 18, 2022 at 10:05 AM
    Millwood21
    Jade
    2017 Platinum
    I sure hope so. I believe it will tho. Only problem now is I need more lights! I’ll be sure to post pics when finished.
    RobertD and Baja Designs[QUOTED] like this.
  25. Oct 18, 2022 at 10:09 AM
    Baja Designs
    San Marcos, CA
    Reach out to me directly regarding any lights you are looking to purchase, I would love to help you out @Millwood21.
    Email:brandonk@bajadesigns.com
  26. Oct 18, 2022 at 10:13 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I received my Toytec Bumper Shims and promptly had them sent out to get powder coated as they come as raw aluminum. I had them back from the powder coater same day.
    Then, since I had a lot of spare time due to getting covid. I spent some time detailing the interior and exterior.
  27. Oct 18, 2022 at 10:31 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    it doesnt do a whole lot other than a light yellow light tint. If you really want to cut through fog/dust you need real yellow bulbs.
    Spyker[QUOTED] likes this.
  28. Oct 18, 2022 at 10:38 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Glad to see them get some use!
    Tundra234[QUOTED] likes this.
  29. Oct 18, 2022 at 10:39 AM
    Thanks again! :thumbsup:
    Toe404[QUOTED] likes this.
  30. Oct 18, 2022 at 12:01 PM
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
    Got a sweet knob. Get a grip.
    JeremyTRD, BiggHertz, DZ_ and 6 others like this.
