Need help, abs light and traction light on.
Discussion in 'Electrical' started by harleyway, Oct 15, 2022.
  1. Oct 15, 2022 at 2:37 PM
    harleyway
    harleyway [OP] New Member
    Took it to the dealer and they suckered me for 141 bucks. Ordered a professional obd tool. Scan results came up with no communication with yaw rate sensor. There was damage to my engine harness that's is under the steering wheel. The one that passes through the fire wall through the rubber grommet. I'm trying to track down the wire that communicates with the ecu and yaw sensor. Included is scan results, and picture of harness that was damaged. Any help and guidance is greatly appreciated. I literally haven't even made my first car payment yet. 2017 toyota tundra limited edition.
  2. Oct 16, 2022 at 12:38 PM
    francischris
    francischris New Member
    2019 Tundra
    does anyone what is the accessory wire for an amp turn on a 2019 toyota tundra crewmax w/jbl amp
  3. Oct 16, 2022 at 1:47 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Hard to see how bad the damage is in your photo. Did you buy the truck that way? Is it rodent damage?
    The Yaw Rate sensor communicates to the ABS ecu and has several wires passing right through your damaged area.
    If the main harness really is damaged, i would probably pull the driverside interior kick panel. Unhook the connectors and pull the end of the harness out of the firewall so you can properly repair it. If you do this take lots of pictures and label connectors as you unplug them. Will really help when you go to put it back together.
    Tacopashka likes this.
  4. Oct 16, 2022 at 2:04 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Bring it back to where you bought it from. Sounds like you got it less than 30 days ago
