  1. Oct 10, 2022 at 8:02 PM
    #9481
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    Not picture worthy but finally got the freakin' ice maker working again. Long story short I had to replace the ice maker twice and the pump once. Made the mistake of buying a cheap ice maker off Amazon.
    Sure I could have called the Man but I was already in this deep and it ain't rocket science.
    I've had two cycles of ice so far after installing 4 hours ago. Think I'm gonna be ok.
  2. Oct 11, 2022 at 8:37 AM
    #9482
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Well that’s a first
  3. Oct 11, 2022 at 8:38 AM
    #9483
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    geez!
    how hard were you squeezin your caulk?!?!
  4. Oct 11, 2022 at 8:53 AM
    #9484
    TaquitoBandito
    Joel (AKA Bif)
    It's all that forearm and wrist strength. :rolleyes:
    ColoradoTJ, RobertD, Fotnot and 2 others like this.
  5. Oct 11, 2022 at 10:34 AM
    #9485
    Squatting Pigeon
    Holden
    North Texas
    Too hard apparently :anonymous:
    ColoradoTJ, Trooper2, RobertD and 4 others like this.
  6. Oct 11, 2022 at 10:34 AM
    #9486
    Squatting Pigeon
    Holden
    North Texas
    :spy:
  7. Oct 11, 2022 at 11:22 AM
    #9487
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    I mean, that doesn't exactly look like the Festool of caulking guns.
  8. Oct 11, 2022 at 2:41 PM
    #9488
    Made in China.
  9. Oct 11, 2022 at 3:59 PM
    #9489
    Squatting Pigeon
    Holden
    North Texas
    It most certainly is not.
    Busted out the Kraft Tools gun to finish the job :curls:
  10. Oct 11, 2022 at 6:00 PM
    #9490
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If you use a caulking gun a lot, I would recommend buying one of these sausage caulking guns. They’re a night and day difference, much more efficient and a lot cleaner to use.
  11. Oct 11, 2022 at 6:04 PM
    #9491
    1UPPER
    TEXAS
    Flux capacitor!
    A sneak peak on my latest garage build project. All the car lifts were installed last week. Storefront windows start tomorrow, exterior metal panel finishes are going on, tile installation started, new septic done, permanent power is done, garage doors are almost done, concrete curbs are done, and floating staircase is about to go in next week.
    drobb, AFKC, 4x4platinum and 17 others like this.
  12. Oct 11, 2022 at 6:14 PM
    #9492
    :101010:
  13. Oct 11, 2022 at 7:49 PM
    #9493
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Too bad festool didn’t make caulking guns. But they’d probably cost 3x what a decent usa-made one does if they did
  14. Oct 11, 2022 at 8:28 PM
    #9494
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Decided to ruin my back and not wait to rent a Jack hammer tomorrow and go to town on my porch/walkway.
  15. Oct 13, 2022 at 9:34 AM
    #9495
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    So this was as far as I got with a small 60lb Jack hammer. Thought it would work, which it did for most of the flat slab, but at 6-8” thick it was a no go.
    Had my buddy bring in some reinforcements and will deal with it this afternoon.
  16. Oct 13, 2022 at 9:44 AM
    #9496
    TaquitoBandito
    Joel (AKA Bif)
    You might as well dig yourself a lazy river / moat around your house while you have access to that beast.
  17. Oct 13, 2022 at 11:26 AM
    #9497
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Lol. It’s nice having a friend that works at a heavy equipment rental place. Once I procure the alligators I will get the moat and drawbridge setup.
  18. Oct 13, 2022 at 2:57 PM
    #9498
    TaquitoBandito
    Joel (AKA Bif)
    Until then, you could just float around it in an inner tube with your shotgun.
  19. Oct 13, 2022 at 3:57 PM
    #9499
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Don't forget to have your floating beer cooler tethered to you.
  20. Oct 13, 2022 at 5:59 PM
    #9500
    TaquitoBandito
    Joel (AKA Bif)
    I figured that was just assumed. :thumbsup:
    CodyP and JMB[QUOTED] like this.
  21. Oct 13, 2022 at 7:57 PM
    #9501
    JMB
    Chesapeake, VA
    :cheers: As it should be.
  22. Oct 14, 2022 at 12:02 PM
    #9502
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Due to current lumber prices and COVID I built the most expensive front porch I could afford! :rofl:
    D9B6877C-FF98-472A-8E12-7C3C1C4CF8FA.jpg But seriously those silly temp steps cost me like $100.
    Now I’ve gotta wait a week for the concrete guys to come out but this is what I’m thinking unless someone tells me I’m an idiot and to do it another way.
    Ground level porch
    Two rounded steps up to the doors
    Stamped
  23. Oct 14, 2022 at 1:28 PM
    #9503
    RainMan_PNW
    Casey
    Clark County, WA
    My only question is:
    What’s the point of the little quarter circle by the corner of the garage?
    That will likely cost more money in forming labor and working around the space when finishing than what the materials will cost to just fill it. You won’t want to plant anything large in s space like that, so consider some large potted plants or series of planters instead of making an odd small “bed” set down into the space.
    biebs96, kparrow, NUDRAT and 9 others like this.
  24. Oct 14, 2022 at 1:44 PM
    #9504
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I went back and forth on that and was gonna ask the concrete finishers opinion because if I fill it in I thought it would look weirder but maybe not…
  25. Oct 14, 2022 at 1:48 PM
    #9505
    NWPirate
    Zach
    WA
    Piggybacking on that, do you have the grade to bury a 3" pipe and run your downspout out towards the street?
    That would be a slick spot during the freeze/thaw time of year.
  26. Oct 14, 2022 at 1:59 PM
    #9506
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    finished off the fencing and gates at the WA property. added 4ft dual gates on one side so in the future i can put an insulated house matching shed back there to store moto's and other toys. maybe a small fishing boat. also being in the pnw, winterized the drip system. first time i ever did that. was sure to start using low pressure to not to blow out the connectors, etc. was a satisfying process. guess i'll know next spring if i did it right.
    also trying not to feed this guy and get caught in that trap, lol. has a collar and i think he lives next door.
  27. Oct 14, 2022 at 2:16 PM
    #9507
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Ah! That was the other reason I wanted to not concrete it. I don’t know what grade I would need but it would be a lot of work :/
  28. Oct 14, 2022 at 2:19 PM
    #9508
    NWPirate
    Zach
    WA
    :thumbsup:
    That solves that then!
    TaquitoBandito and RainMan_PNW like this.
  29. Oct 14, 2022 at 2:31 PM
    #9509
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I thought since it doesn’t get much sun there I would just do basalt and a water feature or something.
  30. Oct 14, 2022 at 3:42 PM
    #9510
