18x9 or 17x8.5 Method 312?
Discussion in 'Wheels & Tires' started by Clrems77, Oct 22, 2021.
  1. Oct 22, 2021 at 7:28 PM
    Clrems77
    Clrems77 [OP] New Member
    Looking for suggestions or recommendations on the listed wheels. Both will be going on my 21 tundra and wrapped in 35 x 12.5 tires. Does anybody know if one will fit better than the other as far as rubbing goes?
    will the sidewall beefiness be substantially noticeable?
  2. Oct 22, 2021 at 7:35 PM
    TexasTRD
    TexasTRD New Member
    I went with the 18x9 on my 2020 for two reasons. I already had like new 18" tires and I wanted the +18 offset. Biggest down fall to the 18" is tire price difference from 17 to 18 imo.
  3. Oct 23, 2021 at 6:16 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    depends, offset is going to be key, what are the offsets of the wheels you are considering?
  4. Oct 23, 2021 at 7:00 AM
    Clrems77
    17’s will be a 0 offset and 18’s a +18.
  5. Oct 23, 2021 at 7:02 AM
    frichco228
    Frank
    Virginia
    Saltyhero13 likes this.
  6. Oct 23, 2021 at 8:00 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Or a wheel spacer with 17s. I went with 18s and 295/70s.
  7. Oct 23, 2021 at 8:16 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Any issues with lock to lock turning?
  8. Oct 23, 2021 at 8:21 AM
    Shanet421
    San Diego,CA
    None at all forward/reverse lock/lock. She is a pavement princess so I can’t attest to off-road articulation.
  9. Oct 12, 2022 at 11:53 PM
    TannerW60
    TannerW60 New Member
    Tanner
    Florence Al
    2019 Tundra Limited 4x4
    what suspension or lift?
  10. Oct 13, 2022 at 1:19 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I run 17X12.5 with no BMC. I did have to trim the bumper a little bit and remove the mud flaps. I have a 3" lift with SPC UCAs. I have changed my bumper since then but that wasn't because of the tires.
  11. Oct 13, 2022 at 4:45 AM
    Shanet421
    San Diego,CA
    Icon 2.5 non resi with stock UCA. Set at 2.25” of lift.
