Shimmy shimmy shake - brakes.
Discussion in '2.5 Gen Tundras (2014-2021)' started by FWC, Oct 11, 2022.
  1. Oct 11, 2022 at 4:24 AM
    FWC
    FWC [OP] New Member
    Frank
    Upstate NY
    2019 Tundra Black Platinum
    My 2019 Platinum with 29,500 miles has developed a shake in the wheel when I apply the brakes in the last several weeks. Of course I know that means rotor related so at my visit to the dealer for 30k service I asked to have it checked. Service tech tells me the rotors are warped and they would turn the rotors and replace the pads, all at my cost. They also tell me this is fairly common yet Toyota does not reimburse for any of the costs. That is pretty disappointing for a vehicle that is 3 years old and low milage.
    Since I can't take it out on the dealer I am going to bitch a little to Toyota, though I know it's going nowhere. In the meantime I will run them a while longer until I find satisfactory replacement parts.
  2. Oct 11, 2022 at 4:40 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Sometimes the rotors can develop hot/high spots too. Try re-bedding the brakes. It may not fully resolve the shimmy but improve it significantly. I experienced the same thing you did at around 30K to 35K. I did a re-bed and it's much better now.
    Tundra18overland and FWC[OP] like this.
  3. Oct 11, 2022 at 6:54 AM
    If you decide to replace them...StopTech Sport that are cryo treated and slotted only. Do not do slotted and drilled....they can cause pulsation.
    Bprose and FWC[QUOTED][OP] like this.
  4. Oct 11, 2022 at 7:27 AM
    timsp8
    NY
    Mine got the shakes around 10k. Brakes are a wear item. No warranty claim for brakes with 30k on them.
    Tundra18overland likes this.
  5. Oct 11, 2022 at 7:40 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I had same problem also, I did the road force balance first, that didn't work then I change the rotor and pads, and that solve the issue. I think mine was around in the 35k when it started.
    FWC[OP] likes this.
  6. Oct 11, 2022 at 7:48 AM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Had same issue around 30 or 35k (2018). Finally got tired of it and had front rotors resurfaced. The guy at O'reilly's said they were some of the most warped rotors he's ever seen and he had to take a lot of material off, but said I could probably get one more turn out of them. No more shimmy. I researched drilled/slotted, seems drilled are prone to cracking and the consensus was to do slotted only, but then read slotted can chew through pads faster, so I kept it OEM. I'm happy with my resurfaced OEMs. I say resurface and keep on trucking, but definitely "bed" them once you install them and might as well throw fresh pads on there while you're at it. Bedding them should greatly decrease the chance of them re-warping.
    I understand drilled/slotted helps with heat dissipation thus improving "stopping power," but personally, I'm unsure I would reap the benefit of drilled/slotted or slotted only, unless I was frequently towing heavy.
    FWC[OP] and timsp8 like this.
  7. Oct 11, 2022 at 8:03 AM
    timsp8
    NY
    I thought drilled rotors were to help keep them cool, but then read an article that said the holes were for the gases. Which I guess helps with heat in a way, but it also talked about how hot pads won’t touch the surface of the rotor due to a thin gas layer and the holes help get rid of that layer of gas. I think the article was on ebc’s website.
    I had drilled and slotted powerstop, and they were awful. I have slotted cryo stoptech and they have been pretty good.
    Not my rotors, but an example of them cracking.
  8. Oct 11, 2022 at 4:51 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Another one here, had original rotors turned around 30,000 miles....later went with slotted rotors front and rear...so far great..and I'm not easy on my brakes..
    FWC[OP] likes this.
  9. Oct 12, 2022 at 3:38 AM
    FWC
    FWC [OP] New Member
    Frank
    Upstate NY
    Thanks for the input, going to re bed my brakes today and see what happens.
  10. Oct 12, 2022 at 9:20 AM
    pursuit2550
    pursuit2550 New Member
    I currently have around 26k. I have no issues with my rotors but my pads were more than half gone. I decided to go down the brake world rabbit hole. Oh boy, that was a mistake. First was that I couldn’t believe that NO rotor is made in the US anymore, all China made. The whole cryo stuff, well that’s another deep hole. Only leading cryo manuf is Frozen and another one but can’t remember the name. Cryo also warps, so it’s a crap shoot. Drilled is a waste of time, period. Slotted is good but our trucks don’t benefit from it. Saw videos of test done on daily drivers and didn’t make a difference. Bedding in your pads makes a big difference. And pads are also a big deal. Those 2 in my opinion is what makes or brakes a good braking system.
    FWC[OP] and Tundra18overland like this.
  11. Oct 12, 2022 at 11:10 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    DBA rotors are made in Australia. Advics rotors are made in the US. EBC rotors are made in the UK. All have rotor options for the Tundra.
    This is also some good reading about rotors.
    https://centricparts.com/getmedia/b..._Whitepaper_B1-Warped-Brake-Disc-8-2018_1.pdf
    https://alconkits.com/support/brake-pad-info/110-the-real-truth-about-warped-brake-rotors
    There are several other good reads here about pad bedding as well:
    https://centricparts.com/resources/resource-library?category=Whitepapers
    WILLINH and FWC[OP] like this.
  12. Oct 12, 2022 at 12:45 PM
    pursuit2550
    I swear a searched high and low for US made rotors and not one came up. I couldn't find anything on Advics other than its OEM for Toyota and many other manuf.
  13. Oct 12, 2022 at 12:49 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
  14. Oct 12, 2022 at 12:54 PM
    pursuit2550
    FWC[OP] likes this.
  15. Oct 12, 2022 at 12:56 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Welllll they could be mfg in the US but still be Chinese steel
  16. Oct 12, 2022 at 4:50 PM
    Rocko9999
    Rocko9999 New Member
    They are likely not warped but have uneven pad material from overheating. Resurface and get Akebono pads.
    FWC[OP] likes this.
