  1. Oct 12, 2022 at 2:18 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Everything I can think of on the light checks out...pulling amperage per the spec sheet, lighting up when i connect it direct to battery, continuity checks out. I'll wait for their response before doing much more with it.
  2. Oct 12, 2022 at 2:21 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Keep me posted!
  3. Oct 12, 2022 at 2:43 PM
    Taco-Spike
    Two Trucks
    :stirthepot:
    RobertD[QUOTED] likes this.
  4. Oct 12, 2022 at 2:54 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    I was going to get a baja s8 remember reading it was 4.1 amps per every so many inches (like 8 or 10 or something)...curious to know what the issue is.
    Mater likes this.
  5. Oct 12, 2022 at 3:12 PM
    SAGE63
    San Diego County
    me too my S8 light bar works fine with my SP9100
    edit: 30" also
    Mater, reywcms and HulkSmurf14 like this.
  6. Oct 12, 2022 at 3:19 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Baja Designs likes this.
  7. Oct 12, 2022 at 3:43 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey RainMan_PNW, Is the S8 working? if so it will be pulling right around 12amps. I would do a direct power test on the light and make sure it is working properly. I know the switch pro unit has 4, 30 amp connections, and all the rest are 17 amps so you should not have an issue running this light. If everything checks out on the light it's sounding like it's an issue with the switch pro unit. Here is a diagram of that unit. If the unit is still covered under warranty I would definitely reach out to them after doing some tests.
    Best,
    Brandon
    Wallygator, DZ_, coldcanuk and 6 others like this.
  8. Oct 12, 2022 at 3:57 PM
    bfunke
    bfunke Tundra Curmudgeon
    Spent a month in Tundras jail because I referred to aftermarket alarms as the feculent excrement they are. Admins being childish. Ugh.
    Wallygator likes this.
  9. Oct 12, 2022 at 4:01 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    So what is a GFC?
    Yotatrucks7[QUOTED] likes this.
  10. Oct 12, 2022 at 4:02 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Go Fast Camper- Light weight off-roading camper that has a pop up tent.
    Yotatrucks7 and ZPhilip[QUOTED] like this.
  11. Oct 12, 2022 at 4:04 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    GAknight, rebmo, dorton and 7 others like this.
  12. Oct 12, 2022 at 4:15 PM
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Might have been good to drop the tank, drain as much of that fuel as you could..??
    Super jealous, and congratulations on the monster upgrade.
  13. Oct 12, 2022 at 4:37 PM
    king.cong.1119
    king.cong.1119 New Member
    This is the season for rust prevention in the salt belt country. I know, I need to get a proper respirator.
    I did this two years ago before trucks first winter and the coating has been held up great for this past two years.
    451F650D-B028-4BFD-AAF9-31312A9DCA46.jpg 63534D78-7F8A-48D0-9E51-136413BC3275.jpg 74A7E2B8-9501-4DDD-98DE-5FA35078908C.jpg 535A9EDF-F20B-495D-BB9D-E5D61D1024EC.jpg
  14. Oct 12, 2022 at 4:41 PM
    Taco-Spike
    Two Trucks
    Your PPE reminds me of something Clarke Griswold would wear
    I mean that in a good way
    coldcanuk and Rabidllamas like this.
  15. Oct 12, 2022 at 4:44 PM
    king.cong.1119
    Lol. Wearing glasses sucks
    Taco-Spike[QUOTED] likes this.
  16. Oct 12, 2022 at 4:46 PM
    Taco-Spike
    Two Trucks
    I think the worst is when you do something where you sweat. I can’t stand looking through a bunch of sweat soaked glasses.
  17. Oct 12, 2022 at 4:47 PM
    king.cong.1119
    Yea. Like skiing, over the glass google and the glasses themselves always fogs up from the heat radiating from my face.
  18. Oct 12, 2022 at 4:59 PM
    Cthulhu
    I installed JBA Offroad UCA’s yesterday (173 ft-lbs is a beyatch!!), aligned today. Happy with results, but will keep the tires rotated every service visit, and watch the inner tire wear.
  19. Oct 12, 2022 at 5:17 PM
    What did you use to get in there? Definitely not a whole lot of room.
  20. Oct 12, 2022 at 5:22 PM
    Cthulhu
    There was JUST enough room to get my torque wrench on the nut, I think the key was having the tire actually OFF when torqueing. According to JBA, with their special bushings, there is no need to have the wheel on the ground to torque. I triple checked because all I've ever read was that you should torque suspension components only after the full weight of the truck is on them.
  21. Oct 12, 2022 at 5:28 PM
    Bergy24
    Bergy24 New Member
    Exactly one year from making my first payment,I just made the last payment on my 21 Limited. Now to wait for the Title to come.
  22. Oct 12, 2022 at 7:26 PM
    lowball
    lowball New Member
    LB
    2018 Silver Tundra TRD Off Road
    Huge install today! :cheers:
    Velocity72, kbark, Yzed608 and 7 others like this.
  23. Oct 12, 2022 at 7:52 PM
    Nobody Important
    Nobody Important New Member
    Indiana
    2021 TRD Pro Tundra
    Awesome
  24. Oct 12, 2022 at 10:17 PM
    pistolpete
    pistolpete New Member
    Two Questions:
    What's your lift and tire size setup on this rig?
    What did you paint your bumper corners with?
  25. Oct 12, 2022 at 10:26 PM
    RainMan_PNW
    Casey
    Clark County, WA
    4A per 10” section from what I saw on their site.
    :thumbsup:
    Yes
    I tested direct to the battery and got 11.9A draw.
    I’m seeing that number drop a little to closer to 11A if I run the light through any of the SP switches 1-4 with the engine OFF. Turn the engine ON and the draw jumps up to 12.5-13.5A and switches 1 and 4 trip immediately (even set to a 20A cutoff). Switches 2 and 3 seem to work, but if I set them to a 15A cutoff they also trip immediately.
    I didn’t test on circuits 5-8 because I shouldn’t have to use a 30A circuit to fire a 12A light. I’ll continue to work with them to try to figure out what’s up…waiting to hear back from them after I sent them a more detailed version of this info.
  26. Oct 13, 2022 at 6:46 AM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    I know, I know…. Made the post and realized I only had pics during install and not final.
    Behold:
    Wallygator, GAknight, kbark and 29 others like this.
  27. Oct 13, 2022 at 6:54 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    There she is! Congrats.
  28. Oct 13, 2022 at 6:57 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I just spoke to someone who had a glitch in their switch pro. They'll be warranting it and mentioned there maybe a small bad batch of units.
  29. Oct 13, 2022 at 8:16 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Added the Prinsu grab handles to my rack today. Also bought a can of 6X3 Lunar rock spray paint. I'm considering painting them to match the truck, but I'll test the paint when it comes in.
    Helo, GAknight, kbark and 12 others like this.
  30. Oct 13, 2022 at 9:07 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    Nicely done! I've heard good things about that CRC spray. I am about to go get my fourth application of Krown at the Line-x facility in York. I have done DIY with Fluid film on all of my other cars every year, but just switched to PB Blaster Surface Shield since it seems to have pretty good reports so far. I soaked everything on my wife's '21 Forester yesterday and used 2 full cans.
    I'm impressed you did your whole truck by hand lol. I don't mind doing my unibody cars with spray cans since it's not too bad to get the suspension and subframes, but there's too much frame on the Tundra for me to get in all the nooks and crannies lol
    biebs96 likes this.
