Aluminum Front Bumper Options (Tires Rubbing)
Discussion in '2.5 Gen Tundras (2014-2021)' started by UseEveryColor, Oct 10, 2022.
  1. Oct 10, 2022 at 7:50 AM
    UseEveryColor
    UseEveryColor [OP] Full-time artist and author
    Saint Augustine
    2018 CM TRD OR Limited 4x4 Cavalry Blue
    Toytec Boss 3" coilovers, SPC UCAs, Toytec 1.5" rear shackles, BFG T/A KO2 in 295/60/R20, Fuel Shok Matte Bronze wheels, Prinsu rack, Black Oak 40" Pro Series 2.0 lightbar in yellow, ARB Touring 8' awning, Eylar 53" cargo box, Lamin-X bed liner, console gun safe, Stealth running boards, Gator FX tonneau, Tundra badges shaved from doors, LaminX yellow fogs, short antenna, V-Leds in ALL exterior lighting, black-out tint, Tufskinz interior kit, matte black Tundra tailgate inserts, K&N air filter, Coachbuilder front bumpstop extensions.
    To the point, I'm looking for aluminum front bumper options for my 2018 Tundra. I live near and drive on the beach, so I'd like to avoid steel. I've only found the ICI and the Victory options. I know you guys scour the web and are privy to the nooks and crannies, so maybe you can tell me what else to look at.
    For the details, I just installed the Toytec Boss Aluma Series at 3" and my 295/60/R20s are rubbing. I removed the mud flaps and took out the plastic behind the bumper ends and now just BARELY clear the back (frame) with the front tires at full lock, and I go full lock all the time backing in an 18' trailer through a tight corner. Hoping I wont have to do the frame chop, but first I want to get the front rub taken care of with the bumper. Thanks in advance.
  2. Oct 11, 2022 at 9:20 AM
    UseEveryColor
    Saint Augustine
  3. Oct 11, 2022 at 10:11 AM
    I would not go with an aluminum bumper. I would go steel and have it Line-X'ed. As far as rubbing on the bumper, I would install the Coachbuilder bumper shims. Easy to install and will push it forward 1/2 inch.
    https://shop-coachbuilder.myshopify.com/products/coachbuilder-front-bumper-shim-kit
  4. Oct 11, 2022 at 11:04 AM
    UseEveryColor
    Saint Augustine
  5. Oct 11, 2022 at 11:15 AM
    It wouldn't have any significant strength like steel during an impact.....especially the way people drive these days.
  6. Oct 11, 2022 at 12:13 PM
    UseEveryColor
    Saint Augustine
    I get your point, and agree about drivers out there, but the center of my bumper now is just plastic. I'm sure aluminum is stronger than that. I'm really concerned about rust and weight. Line-X is a great idea, but only makes the steel heavier.
    DZ_ likes this.
  7. Oct 11, 2022 at 12:23 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    If your clearance issue is on the backside, more positive caster will help this. Aftermarket UCAs can help with this. I have JBA UCAs and with +4° caster and heating and molding my rear mud flap, I clear most of the time. Still a little rub when articulating near the ends of the suspension limits. 285/75/18 on OE wheels.
    Edit to add: I do like and agree with your logic behind an aluminum bumper. For the right application, I think it is a good material choice.
  8. Oct 11, 2022 at 12:36 PM
    UseEveryColor
    Saint Augustine
    I have the SPC UCAs. Not sure where they're set. I removed the rear mud flaps and it looks like I MIGHT clear back there now. I heated the front plastic pieces and trying to reshape them now for an immediate fix. I don't want to mess up my brand new tires :mad:
