Spilled laundry detergent
Discussion in 'Detailing' started by KClav, Aug 20, 2022.
  1. Aug 20, 2022 at 3:00 PM
    KClav
    KClav [OP] MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Any tips for removing spilled liquid ‘Tide’ laundry detergent. I’ve sprayed with vinegar/water mix and sucked up with the shop vac for about an hour, spent another hour and a half with a rug doctor. I’d guess a cup or so spilled. Got most of the carpet clean, about a 6x12” area still suds when I wet it. Car has overpowering scent of laundry detergent. It’s not the worst smell, but man it’s strong!
  2. Aug 20, 2022 at 3:03 PM
    Retired...finally
    Keep at it. Just takes more water. Lots and lots more water.
    AZBoatHauler and YardBird like this.
  3. Aug 20, 2022 at 3:18 PM
    ColoradoTJ likes this.
  4. Aug 20, 2022 at 3:20 PM
    Pull the seats, pull the carpet, hose it till the suds are gone. Let it dry, put it back in.
    Luckydog likes this.
  5. Aug 20, 2022 at 3:22 PM
    KClav
    May be my next move, need to find a little more time to tear into that though.
  6. Aug 20, 2022 at 3:27 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Liquid detergent acts like soap, it dissolves oil based, so you need it to be sucked up, It may take just a few minutes for the litter/salt to soak up the soap, or it may take several hours. Use paper towels to push the moistened litter/salt into a dustpan and dispose of it or vacuum repeat if needed but don't let it distract you from the fact that in 1998, The Undertaker threw Mankind off Hell In A Cell, and plummeted 16 ft through an announcer’s table.
  7. Aug 20, 2022 at 3:36 PM
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
    I had glue and tar in our RV carpet and came across this recipie
    6oz Ultra dawn dishwashing detergent.
    6oz 99% rubbing alcohol
    30 trigger squirts oxy clean Maxforce.
    Mix in a sprayer bottle and it will remove anything. didnot damage carpet. And smells really good too.
    watch this:
    https://www.youtube.com/watch?v=eOSEbtdmMSA
    Oxy clean max force may be enough for the laundry soap.
    Vinegar and water (equal parts) will break down laundry soap but then it smells like vinegar.
  8. Oct 11, 2022 at 7:41 AM
    se7en
    se7en New Member
  9. Oct 11, 2022 at 11:22 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
