NSV-Hood-Mount-LED-Lightbar-System-Toyota-Tundra-14-20
Discussion in '2.5 Gen Tundras (2014-2021)' started by MiamiTundra2020, Oct 2, 2022.
  1. Oct 2, 2022 at 11:35 PM
    MiamiTundra2020
    MiamiTundra2020 [OP] New Member
    Miami, FLorida
    2020 Tundra Limited CrewMax 4x4
    STEELCRAFT FORTIS HD REAR BUMPER, BUSCHWCKER POCKET STYLE COLOR MATCHED FLARES,
  2. Oct 3, 2022 at 12:37 AM
    MiamiTundra2020
    Miami, FLorida
    Did you get it at a good price?
    Where did you get it from?
    Was it difficult to install ?
    Any advise?
    looks really nice!!!
    Thanks!
  3. Oct 3, 2022 at 2:30 AM
    For that price, you can get a much better bar. The advantage to the NSV is that it is a plug and play fitment wise. It is only 9,000 lumens though. The Baja S8 is a trickier install, bit it is 25,400 lumens.
    DaddyPete likes this.
  4. Oct 3, 2022 at 6:16 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
  5. Oct 3, 2022 at 6:34 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    But but but can you do Knight Rider mode with the S8?!
    RobertD and HulkSmurf14 like this.
  6. Oct 3, 2022 at 8:35 AM
  7. Oct 3, 2022 at 8:36 AM
    Also to mention, they changed the wiring. The NSV won't even light up until you go to high beams now.
  8. Oct 3, 2022 at 8:44 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The new switch is nice too
    HulkSmurf14 likes this.
  9. Oct 5, 2022 at 5:29 AM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    Does the Baja light fit as good as the NSV? The nsv bar looks like it fits great. Im planning to wire a light bar to a switch pro so I’m not interested in plug and play light bars. I also don’t what the night rider and other modes. I only want it to fit perfect and bright as possible. I don’t want to spend extra money on a wiring harness and lighting modes that I’m not going to use.
    Baja Designs likes this.
  10. Oct 5, 2022 at 12:15 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I’m leaning towards the bajadesigns light bar for in the bumper grill. I don’t plan on adding it to my hood. The only thing you need to remove the bumper for the light brackets but I had bajadesigns on my 4runner Pro. They are a awesome light bar.
  11. Oct 5, 2022 at 4:22 PM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey RusPro21, If you're thinking about putting an order in for a Baja Designs light bar reach out to me directly at brandonk@bajadesigns.com and I can take care of you.
    RusPro21[QUOTED] likes this.
  12. Oct 5, 2022 at 4:24 PM
    Baja Designs
    San Marcos, CA
    Hey Rangergillikin, Baja Designs sells an up-fitter harness for the S8 light bar that will allow for a simple install directly into your switch pro unit. Check out the link below.
    Best,
    Brandon
    S8 Up-fitter Harness:https://www.bajadesigns.com/products/onx6-s8-xl-upfitter-wiring-harness-universal/
  13. Oct 10, 2022 at 9:24 PM
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    I’d love to do the Baja Designs light, but that gap between the trim and light would make me absolutely bat sh*t crazy. For that reason, and that reason alone, I’m most likely going with the NSV.
  14. Oct 11, 2022 at 4:54 AM
    Rangergillikin
    Alabama
    Im the same way. It’s got to fit perfect.
  15. Oct 11, 2022 at 6:42 AM
    You can't see the gap between my S8 and the hood bulge.
  16. Oct 11, 2022 at 8:29 AM
    Baja Designs
    San Marcos, CA
    Hey Tundra234, Is there any way you can share a picture of that for the people considering Baja Designs as an option?
    Best,
    Brandon
  17. Oct 11, 2022 at 8:37 AM
    Will do. I'll get some shortly. I used the screen from the factory insert.
    Baja Designs[QUOTED] likes this.
  18. Oct 11, 2022 at 9:00 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
  19. Oct 11, 2022 at 9:06 AM
    Compress_20221011_120417_7156.jpg Compress_20221011_120416_6567.jpg Compress_20221011_120416_6731.jpg Compress_20221011_120416_6945.jpg
  20. Oct 11, 2022 at 9:33 AM
    Baja Designs
    San Marcos, CA
    Hey Tundra234, Thanks for sharing. Hopefully, this helps out those with fitment concerns.
    Best,
    Brandon
  21. Oct 11, 2022 at 11:46 PM
    Redline870
    Ian
    Central NY
    I would definitely consider this because I think it looks really sharp, but doesn’t that kill a significant amount of the light output? I’d imagine a comparison photo of the light output both with and without the screen would show a pretty significant difference.
  22. Oct 12, 2022 at 8:33 AM
    Baja Designs
    San Marcos, CA
    Hey Redline870, If you would like I can get a quote made up for you so you have a pricing idea. You do raise a good question about the grill restricting light output, I don't have any images of the difference but I can't imagine it's too drastic. Feel free to email me personally if you would like to move forward with a quote at, brandonk@gmail.com.
    Best,
    Brandon
  23. Oct 12, 2022 at 9:52 AM
    737fixer
    737fixer New Member
    As stated already, for the money it is a very weak lightbar. If your just looking for something to fill the space that looks cool then it's a G well spent. But having a lightbar that is just something for other people to look at and almost useless off road is I guess up for debate.
  24. Oct 12, 2022 at 11:00 AM
    Baja Designs
    San Marcos, CA
    Hey 737fixer, Comparing alternative options, for the price of the S8 you can't find another light bar with a 25,400-lumen output. As well as the amber backlight feature. Yes, there are cheaper options but for the price, you are getting a quality product with a Lifetime warranty as well as a fully serviceable light bar. Most companies alone will only offer a limited warranty and don't have the ability to open up the light and make desired changes to the light. Even with the restraining light from the grill, the S8 output will still outperform other options on and off-road.
  25. Oct 12, 2022 at 11:04 AM
    Basically he is saying what I posted a while back. The NSV is $1K for 9,000 lumens....total waste. The S8 is a much better deal.
  26. Oct 12, 2022 at 7:26 PM
    Redline870
    Ian
    Central NY
    You guys are really doing a good job of convincing me to go with something else lol. I already have Rigid fog lights and A-pillar lights. I may need to show Baja designs some love too. I appreciate their activity in this thread and on this forum as well!
  27. Oct 12, 2022 at 7:29 PM
    It's a no-brainer lol. NSV for $1k at 9,000 lumens or Baja S8 for $1k at 25,000 lumens. :D
  28. Oct 12, 2022 at 7:32 PM
    Redline870
    Ian
    Central NY
    I know, I know, but it’s a new truck with less than 10k miles so I really don’t want a gap between the light bar and the trim. Clean modifications that look OEM+ is what I’m after.
    Rangergillikin likes this.
  29. Oct 12, 2022 at 9:30 PM
    BlancaLaGordita
    BlancaLaGordita New Member
    Blanca
    2021 Tundra TRD Sport
  30. Oct 12, 2022 at 10:06 PM
    Rangergillikin
    Alabama
    I’d like to see a picture of how the Baja light bar looks in the hood scoop to see how big the gap is. The picture that Tundra234 posted looks great but it’s hard to tell how much gap there is with the screen in place. I was going to remove my screen when I install one. I don’t care about the night rider function but I do care about fitment.
