04 Tundra Pulling left on 1st brake pump.
Discussion in '1st Gen Tundras (2000-2006)' started by Jaydog1019, Mar 4, 2019.
  1. Mar 4, 2019 at 8:24 AM
    Jaydog1019
    Jaydog1019 [OP] New Member
    2004 Toyota Tundra
    Stock
    hi,
    I’m puzzled. I just changed out my whole front suspension with new struts, upper and lower control arms, upper and lower ball joints and new rack and pinion. Then I had the truck aligned. The truck will pull left pretty good when you step on brakes the first time, each subsequent pump they grab good and tight and goes straight. So I’ve rebleed the brake fluid at least 4times, still same issue. Then suspected a collapsed hose, rebleed and still drivers side is grabbing hard. Then I suspect frozen calipers so I changed both of them on the front and rebleed them and yet the passenger side still pulls on the first initial push of the brake. Then push 2 and 3 really grabs good and is even braking on both sides with no more pull. Starts all over when the next time I need to brake. I’m am confused as to what else it could be. ABS block maybe? Any ideas?
  2. Mar 4, 2019 at 3:09 PM
    Can you check your old pads and see if they had even wear? Also check your rears. You may have wheel cylinders or adjusters acting up.
  3. Mar 4, 2019 at 3:31 PM
    Jaydog1019
    2004 Toyota Tundra
    Stock
    Yes the seem to have worn evenly. I replaced the cylinders on the back brakes about a year ago. I rebleed those again this round and worked my way up to the front. Maybe I need to redo it again.?
  4. Mar 4, 2019 at 6:19 PM
    They're probably good. How about your tierod ends and steering rack? Any play in there?
  5. Mar 4, 2019 at 6:38 PM
    Jaydog1019
    2004 Toyota Tundra
    Stock
    No, they’re all new as I put those on at same time as the rack and pinion and control arms and ball joints. Just a mystery. I may change tire to the back and vice versa and see if that helps? Idk .
  6. Jul 9, 2022 at 10:42 AM
    larryr941
    larryr941 New Member
    Larry
    03 tundra
    I hope this thread is still alive. I am having the same issue with my o3 tundra 4x4. I have changed out the calipers, pads brake lines and rebuilt the rear brakes as well. The only thing left that i can think of is the master cylinder. Does anyone have any idea on the resolution on this issue?
  7. Jul 9, 2022 at 12:30 PM
    shifty` All my rowdy friends have settled down
    @larryr941 did you bleed the proportioning valve after all that?
    Are you 100% sure you adjusted the rears correctly?
    Have you tried applying and releasing the parking brake several times AFTER doing the work to settle in the rears?
    I would expect a pull left or right would be the fronts, but the rear brakes seem to have a hell of a lot of influence on the overall breaking experience.
    I'd go back through and re-check your work. Including re-adjusting the rears.
    alb1k likes this.
  8. Jul 9, 2022 at 12:44 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Sure sounds like an air in the line problem.
    shifty`[QUOTED] likes this.
  9. Jul 9, 2022 at 4:42 PM
    larryr941
    Larry
    03 tundra
    I did not think about the proportioning valve. I will try that and go thru everything again. Will get back with you when i do that and give you an update.
  10. Jul 9, 2022 at 5:32 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Jack the front of the truck up and have someone press the brakes as you feel the brake hose on the passenger side front brake. Rather than having a collapsed hose which is blocking flow, you probably have a weakened hose which is expanding/ballooning.
    This will cause more braking on the driver side which causes the truck to pull to the left.
    alb1k likes this.
  11. Jul 9, 2022 at 6:45 PM
    larryr941
    Larry
    03 tundra
    Well Guys, I just bled all four brake wheels and did not have any air in the lines. I have already changed out the brake lines at the front calipers. I have adjusted the proportioning valve and will check it out in the morning to see what happens. I will update at that time.
    shifty` likes this.
  12. Oct 10, 2022 at 5:32 PM
    Cajunman007
    Cajunman007 New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    Well?? Left us hanging!! What gives? Did it work?
    KNABORES likes this.
  13. Oct 11, 2022 at 5:27 AM
    larryr941
    Larry
    03 tundra
    SORRY I LEFT YOU HANGING. I JUST GOT BACK FROM VA. ANYWAY. I DID FIGURE OUT THE ISSUE. IT WAS THE LOWER CONTROL ARMS ON BOTH SIDES. SORRY FOR THE UPPER CASE. ISSUE HAS BEEN RESOLVED. THX EVERYONE FOR THE INPUT.
    Cajunman007 and shifty` like this.
