Truck shutting off while driving
Discussion in '1st Gen Tundras (2000-2006)' started by c.wilson30, Oct 3, 2022.
  1. Oct 3, 2022 at 10:05 AM
    c.wilson30
    c.wilson30 [OP] New Member
    Cameron
    2005 Silver Tundra 4.7 TRD DC
    Custom Sleeping Platform/Storage System Tires - Toyo AT3 - 295/75/R16 Bilstein Lift - 6112/5160 Radio - Jensen Car910W All new speakers - JBL GTO609C/GTO629 New wires ran to speakers
    I was driving through an old pond bed that wasn’t crazy bumpy but I was in 4HI with my tires turned a little less than full lock and when I went over this bump my truck shut off. I turned it back on and everything seems to be fine. This is the first time I’ve had a 4.7 do this to me. I’ve owned this 2005 Tundra DC 4wd V8 for about 8 months now and have done many of off road miles (lots were worse than the conditions were when the truck shut off) and haven’t had this problem yet. I’m wondering if it’s bad grounding or wiring somewhere? I’ve noticed that the truck does run kind of rough at idle but nothing crazy for a 160k mile truck probably just me looking into it to much lol. Please let me if someone else has had this problem
  2. Oct 3, 2022 at 10:08 AM
    Casper421
    In the woods
    06 DC
    Start with the small things. Check to make sure your battery cables are tight. Did this pond have water in it or dry?
  3. Oct 3, 2022 at 10:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Spark plugs? Ever been changed?
  4. Oct 3, 2022 at 10:14 AM
    Instant shutoff without any special noises and stuff, I'm thinking it's power related and would focus on the power cables.
    Not knowing if you were seeing any dash lights after it shutoff makes it difficult to say. Really need to know the current state/symptoms, what are they?
    I'm really hoping the pond was dry or mostly dry at the time, and this isn't a hydrolock situation, but I couldn't tell from your post.
    Aerindel likes this.
  5. Oct 3, 2022 at 10:18 AM
    Just a point about this also.
    If it gets power, are there any codes set? Does it crank?
    (I'm thinking about the few things that would cause the fuel pump to fail... which would kill the engine almost instantly, but all power would remain on, and it would be able to crank, but wouldn't be able to fire)
  6. Oct 3, 2022 at 1:34 PM
    Aerindel
    Aerindel New Member
    Montana
    Sounds exactly like a battery cable situation to me.
    shifty` likes this.
  7. Oct 9, 2022 at 12:33 PM
    c.wilson30
    Cameron
    The pond was completely dry and there wasn’t any codes thrown. I just did a 35 miles camping trip through mountain roads and didn’t have a single problem with it. I know there is some rust underneath the truck so I’ll check grounds and my cables to the battery
  8. Oct 10, 2022 at 6:30 PM
    Grounds are a great hypothesis, great first look. How heavy are your keys? Maybe the jiggling about is affecting the ignition due to a key ring full of keys on a worn ignition cylinder. These trucks are equipped with a "crash" fuel shutoff (ask me how I know) that will cut the fuel pump with a rapid decel / sudden jarring stop scenario. Maybe the rough terrain triggered it? Also, My 2000 with 265k plus miles has a nice smooth idle, so there may be something else amiss if your idle is rough. Cracked plug boot? Or those previously mentioned ground cables.
    Mr.bee and shifty` like this.
  9. Oct 11, 2022 at 4:07 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    How does one reset this fuel shutoff? Or does it reset after an ignition cycle?
  10. Oct 11, 2022 at 4:52 AM
    Turn the ignition off and back on.
    NickB_01TRD[QUOTED] and shifty` like this.
