OEM TRD Pro fogs vs Rigid SAE 504813
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redline870, Oct 10, 2022.
  1. Oct 10, 2022 at 11:17 PM
    Redline870
    Redline870 [OP] New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Anyone ever compare the OEM fog lights of a TRD Pro against the Rigid SAE fogs like the 504813? I ask because the lens on the factory TRD Pro fog lights looks tiny by comparison. I can’t help but think the Rigid SAE’s would throw more light. With the way the fog lights shake around on bumps, I’m considering changing them out for something else.
    Baja Designs likes this.
  2. Oct 12, 2022 at 5:15 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Rigid will be better than OEM fogs...so would Diode Dynamics and Baja Designs...
  3. Oct 12, 2022 at 5:18 PM
    I run 2 sets of those Rigids on my truck. They put out a good bit of light.
  4. Oct 12, 2022 at 5:36 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    nowayout and bulldog93 like this.
  5. Oct 12, 2022 at 5:41 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  6. Oct 12, 2022 at 5:43 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  7. Oct 12, 2022 at 7:05 PM
  8. Oct 12, 2022 at 7:09 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  9. Oct 12, 2022 at 7:15 PM
    Just a video comparing lights in general.
  10. Oct 12, 2022 at 7:23 PM
    Redline870
    Ian
    Central NY
    Even better than the OEM rigid fogs?
  11. Oct 12, 2022 at 7:24 PM
    Redline870
    Ian
    Central NY
    TRDFerguson[QUOTED] likes this.
  12. Oct 12, 2022 at 7:25 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    My primary driver is to match the rest of my DD aux lights haha. The D series are great, so you can’t really go wrong either way.
  13. Oct 12, 2022 at 7:27 PM
    You would be happy with the Rigid SAE's. I run 4 of them for my fogs.
  14. Oct 12, 2022 at 7:29 PM
    Redline870
    Ian
    Central NY
    I’m really considering replacing my stock fogs with them. The lens is tiny on the OEM fogs and they jiggle around like crazy. I’m thinking of doing the modification to mount a standard series D series Pro to the metal bumper support behind the fog
  15. Oct 13, 2022 at 4:22 AM
    HulkSmurf14
    2014 Tundra Limited
    Yes
  16. Oct 13, 2022 at 10:06 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey Redline870, Baja Designs also makes an OEM fog light replacement. Check out the link below for that option in our SAE light.
    Best,
    Brandon
    Baja Designs Tundra Fog Light:https://bajadesignsdev.wpengine.com...21-tacoma-2014-2021-tundra/?page=1&vid=146666
  17. Oct 13, 2022 at 10:38 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Baja Designs[QUOTED] likes this.
  18. Oct 13, 2022 at 10:46 AM
    Baja Designs
    San Marcos, CA
  19. Oct 13, 2022 at 3:22 PM
    Redline870
    Ian
    Central NY
    I’ll probably stick with the Rigid’s just to maintain an OEM look, but I think you’ve convinced me on the light bar for the hood bulge in my other thread. I’ll reach out for a quote.
  20. Oct 18, 2022 at 11:59 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  21. Jun 21, 2025 at 2:43 PM
    xx3xil3xx
    xx3xil3xx New Member
    Aj
    2018 tundra sr5
    Stock
    Whats the oem rigid fogs worth? I came up on a set with housing and everything but the passenger side fog housing plastic is broken
  22. Jun 21, 2025 at 3:02 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I also run 4 of the rigid sae fogs and the light output is great. I never had the TRD rigids but compared to the oem led fogs it was not even in the same ballpark.
  23. Jun 21, 2025 at 4:09 PM
    xx3xil3xx
    Aj
    2018 tundra sr5
    Stock
    I have diode dynamics right now so i might just sell the oem pro fogs with the bezel
  24. Jun 21, 2025 at 5:11 PM
    xx3xil3xx
    Aj
    2018 tundra sr5
    Stock
    I dont think they sell this piece
  25. Jun 21, 2025 at 7:15 PM
    MadMaxCanon
    You would definitely have to customize a mount.
    xx3xil3xx[QUOTED] likes this.
