Suspension overhaul, what to do.
Discussion in 'Suspension' started by Whitewhale, Oct 7, 2022.
  1. Oct 7, 2022 at 2:06 PM
    Whitewhale
    Whitewhale [OP] New Member
    Kyle
    The Berkshires
    16' white limited
    My bilstein 6112/5160 setup is toasted after 28k miles and I’m looking to upgrade.
    my road is very bad, reasoning for my bilsteins to have bit the dust so quickly. Also my lower control arm camber bolts are seized (no suprise, thanks New England) and my leaf pack is flattening.
    I’m looking at oem new LCA drenched in anti seize, camburg uniball UCA, KING 2.5 front and rear without adjusters, deaver leaf packs and coach builder rear shackles. Looking for a 2.5-3” lift out front and 2.5 in the back. Basically some rake when no rack and level when loaded up.
    my bed all summer has a UPtop overland rack, tent, awning, two bikes, bike rack and camp gear most weekends and ranges from 500-750 lbs.
    I’ve contacted deaver for leaf spring options and haven’t heard back from them. Any recommendations on packs?
    also kings seem to have two, 2.5 options. One has a black finned resi and one has the classic smooth silver. Any difference between the two internal wise other than possibly better cooling capabilities? I’m gonna be ordering all these parts during the winter for a lovely spring time install, just want all my ducks in a row and part numbers so I’m ready to go. Any help is appreciated !
  2. Oct 8, 2022 at 5:51 AM
    M@-AZ
    M@-AZ New Member
    Phoenix
    21' Tundra Limited TRD OR (AG)
    After 28k?! geez...
    I've had great luck with Dobinsons over the years. I've had them on two 4Runners and just installed a full kit on my Tundra.
    Simple and reliable.
  3. Oct 9, 2022 at 9:53 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I don't necessarily think they're toasted after 28k, but what I do think is that the suspension may no longer work for you since it seems like you're carrying quite a bit of gear.
    It does seem like you've already done some research on your own on wanting a set of Kings front/rears with no adjusters. The difference between smooth body and finned is most likely heat dissipation. Most likely geared more towards racing as when the suspension cycles, the oil will heat up - the finned reservoirs will allow the oil to cool much quicker to reduce shock fade.
    You state that you also live in New England and being in New England with salted roads, I would probably not recommend going uniballs unless if you can do the maintenance after every drive; sealed ball bearings (such as JBA or SPC) might be more practical unless if you're willing to take the gamble.
    Look into swapping your coils to higher rates to compensate for weight? Deaver / Alcans may be the way to go with adding some bumpstops such as superbumps or timbrens?
  4. Oct 9, 2022 at 10:07 AM
    Maggy4x4
    Maggy4x4 N+1 mods
    Washington
    2008 SR5 Tundra
    35s on methods Icon lift 46 gal fuel tank
    I agree on shying away from uniballs, even here in Washington they get squeaky even with normal maintenance. My buddy has to replace them on his taco regularly.
    I’ve had good luck with the icon UCAs with the delta joints. The delta joint I think is retrofittable to other uniball control arms too, double check that though
  5. Oct 9, 2022 at 10:17 AM
    GravityGear
    Aurora, CO
    Finned doesn't really do anything on street driven trucks. More for looks; the fins aren't big enough to dissipate heat efficiently. It's not a TT or class one doing 90+ with 4.0s. BUT with that said, I overheat my twin tubes every time I'm off-road and I don't have a lot of gear. I'm not an overlander, I'm an off-roader.
    For the NE climate and winter conditions, 2-3" lift Elkas would be perfect. They have aluminum bodies, so the rust and oxidation will be slowed greatly. Just gotta be concerned with the shafts. With the uniballs, just pack a dam of grease around the uniball. It will create a barrier to catch a lot of stuff before it reaches the uniball. It looks like hell, but it works. Also, LSK makes stock length uppers with sealed uniballs.
  6. Oct 10, 2022 at 8:12 AM
    Whitewhale
    Kyle
    The Berkshires
    16' white limited
    Their toasted lol all the fluid leaked out with the duro bump stops.
    pvn.beluga[QUOTED] likes this.
  7. Oct 10, 2022 at 8:15 AM
    Whitewhale
    Kyle
    The Berkshires
    16' white limited
    I was looking at Elka, but isn’t it tough with spring rates? I read you could only get 600 lb springs with them. I haven’t found enough info about them. My friends kings held up pretty well over winter for 3 years but I’m always down for other opinions
    I had total chaos UCA on my 4 runner and didn’t have an issue but I’m not against delta joint uppers.
    more or less just trying to figure out what to do for rear deavers lol
  8. Oct 10, 2022 at 8:19 AM
    Your situation makes a good case for rear airbags.
  9. Oct 10, 2022 at 8:46 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Dang, how do you think it even got to that point at just 28k?
  10. Oct 10, 2022 at 8:51 AM
    Whitewhale
    Kyle
    The Berkshires
    16' white limited
    the road we live on is atrocious. My neighbor broke broke his leaf springs and I’ve had to replace the suspension in my car already once and that was in 6k. Honestly need coils strictly for my road
  11. Oct 10, 2022 at 9:07 AM
    Cheaper to get gravel brought in and grade the road than keep replacing broken suspension parts.
    cran2 likes this.
  12. Oct 10, 2022 at 10:40 AM
    Whitewhale
    Kyle
    The Berkshires
    16' white limited
    :rofl: Unfortunately the road is pretty long. Supposedly it’s gonna get repaved but I don’t think that’s happening anytime soon
  13. Oct 10, 2022 at 10:57 AM
    sstarkman
    sstarkman New Member
    2019 Tundra SR5
    Bilstein 8112 DSA+ +2.5” Front Shocks Dirt King BJ UCA Cooper AT3 XLT 285-75R18 Spidertrax 1.25” Alcan Custom Leafs +1” Fox TRD Pro 2.5” Rear Shocks Durobump Front and Rear Stock Airbox Mod AFE Filter OTT Rear Diff Breather Powertrax Grip Pro Frozen Rotors Front Hawk LTS Rough Country Speedo Cal Softopper Datin Fab Bed Cage CVT Mt. Hood Tent Total Chaos Bed Stiffeners Decked Drawers
    Call Alcan, they will build you a custom pack for the weight of your setup, lift, normal use. They used different shackles. Built mine for my camper etc. Ride is money.
    https://www.alcanspring.com/
    Go with the new Camburg X Joint. I would stay far away from Uni in your environment.
    I run fox 2.5 fronts and rears. They are great.
    The other way to go is OME Heavy Load BP51 kit.
  14. Oct 11, 2022 at 4:20 AM
    Whitewhale
    Kyle
    The Berkshires
    16' white limited
    I had fox 2.5 resi on my wife’s TT fj and they are great. Just do not hold up at all to winter, I love fox and had them on all my sleds and bikes. I know they came out with aluminum shocks, they just don’t have them for tundra yet only tacomas. If they drop them for the tundra I’ll definitely buy those.
  15. Oct 11, 2022 at 10:40 AM
    sstarkman
    2019 Tundra SR5
    Found this on a Raptor forum: https://www.amsoil.com/p/heavy-duty-metal-protector-amhsc/?zo=1678239&zo=1678239
    Or I found this on Tacomaworld:
    “Your first concern should be the piston rod, because dented and rusty piston rods are the leading cause of shock failure. You're on the right track with adding a boot to protect the rods, although it is critical that boots are well ventilated.
    Fox piston rods are made from 17-4 H900 stainless steel with a hard chrome coating. This is the strongest, most dent resistant and most corrosion resistant combination you can get.
    King, Bilstein and newer Icon shocks use industry standard 1045 base material with hard chrome coating. These are good and less expensive, which is why it's the industry standard.
    Sway-A-Way and Radflo use Nitro Steel piston rods which is a 1045 base with nitride coating. They are stronger and more dent resistant than regular 1045, but substantially more brittle and not very corrosion resistant.
    There is some more detail here, including hardness test numbers.
    http://accutuneoffroad.com/articles/fox-vs-king-2-0-coilover-shock-comparison/
    For the body King uses Cad plating which is a bit more corrosion resistant than zinc used by everyone else.”
  16. Oct 11, 2022 at 3:34 PM
    GravityGear
    Aurora, CO
    I haven't really looked at them too much myself, but it does appear to be a standard 2.5" body. You should be able to get some other springs and put them on there. @Toytec Lifts might be able to give more info on the perches and their compatibility with other springs.
  17. Oct 11, 2022 at 11:14 PM
    ctdomain
    ctdomain Expeditioner
    Clint
    2019 Limited Quicksand Tundra
    Suspension: ADS Front C/O's w/adjusters, ADS Piggyback rears, Toytec Shackles, Icon Rebound 17in wheels +25 offset, 35x12.50xr17 Nitto Ridge Grapplers. Miscellaneous: Tech 12 volts remote start, Tyger side steps, Color matched pro grille & bulge, Black handles off of SR5 Tundra
    If you’re looking at buying Deaver and running new shocks with one of their packs I’d give MCM fabrications a call. Matt over there has their shit down to a science, might be worth picking his brain. Also depending on what you’re doing and your setup Icon makes a sealed delta joint that is made out of aluminum and could be worth your time
  18. Oct 14, 2022 at 3:58 AM
    Whitewhale
    Kyle
    The Berkshires
    16' white limited
    I was looking more into deaver and the more I looked the more I wanted to go with Alcan. If I’m spending 1200$ on leafs I don’t want my springs popping or having any issues considering I’m going to be spending about 6 grand all said and done.
    Alcan got back to me and it’s about 8 weeks or less for custom made packs specific to my setup, cab and truck. Kinda awesome.
  19. Oct 14, 2022 at 5:53 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I've been in Central Mass for about 5 years now. The mag-chloride road salt is rough on suspension parts and brake rotors.
    I found a broken leaf in the oem spring pack earlier this year. I think it was a combination of the rear leveling block and road salt that killed it. I switched to the OME Dakar pack with the extra overload spring and OME greaseable rear shackles so I could get rid of the leveling block.
    The oem springs had gone flat so a real rear ride height comparison is difficult, but it's at least 2-3" higher now. (The OME shackle is the same length as the stock shackle.)
    I was worried about a harsher ride with the extra overload spring, but it was pretty bad already with the flattened/broken oem springs. The rear feels much smoother on bumps now, but there is noticeably more body roll even with the Helwig rear sway bar installed.
    I have a Leer canopy that weighs about 200-ish lbs, but I haven't put a heavy load on the hitch or in the bed yet. I have airbags with Daystar cradles so I'm not that worried about managing rear squat if the OME springs can't keep up a heavy load.
  20. Oct 14, 2022 at 6:05 AM
    careyrob
    Carey
    Massachusetts
    I haven't replaced the front oem shocks and LRO 3" leveling spacer yet, but I'm thinking about using the OME heavy front springs on adjustable front shocks since the rear rides so much better now. I just haven't decided which shocks to go with for the front.
    One of the sales reps at Toytec recommended that I avoiding uni-ball and delta-joint UCAs because of the excessive road salt in NE. I'll be using the SPC adjustable UCAs when I replace the front shocks since they use a sealed upper ball joint.
