Thoughts on Diode Dynamics
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spielightdude, Sep 21, 2021.
  1. Sep 21, 2021 at 5:34 AM
    Spielightdude
    Spielightdude [OP] New Member
    Joseph
    2019 Tundra TRD off road and towing package
    Hi everyone,
    While looking around at things I stumbled across a 42" light bar that goes where the bottom front grill is.
    I am wondering if anyone has this mod and thoughts on the company itself?
    Thanks all
    FlipMonkey21 likes this.
  2. Sep 21, 2021 at 6:00 AM
    Kevmo
    Kevmo _________
    20 MGM TRD Limited DC
  3. Sep 21, 2021 at 6:34 AM
    TRDSPEC
    TRDSPEC New Member
  4. Sep 21, 2021 at 6:40 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I have 2 pairs of DD’s on my truck, and 1 pair of rigid. I think the finish is better on rigid, (some powder coat is chipping off the DD’s, but I think the DD’s are a good value. )
  5. Sep 22, 2021 at 7:52 PM
    Amateur Guy
    Amateur Guy New Member
    I don't have light bar, but swapped all exterior lights with DD. They were somewhat expensive, but worthwhile.
  6. Sep 22, 2021 at 8:09 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I plan to add one again. Had them on my Tacoma and 4Runner. I’m leaning now towards the 30 inch instead of the 42 because of the issues I’m herring about the 42 not staying in place.
  7. Sep 22, 2021 at 9:47 PM
    French Avocado
    Utah / Wyo
    @memario1214 of Hotshot Offroad can help you and explain all of the differences. A good resource, an official vendor and a great guy!
  8. Sep 23, 2021 at 3:21 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    I have the 42” bar in the bumper, just put it in last weekend. It seems to be a high quality unit, very bright. One thing I do like is that you can replace lenses if you want, if one gets hit by a stone or if you just want to change functionality.
    yes, install wasn’t a 5 min job, but just get the right tool for the mount and you’ll be fine… a 14mm flexible head ratchet wrench is what you’ll need. Not sure that this is DDs fault though. I did use Caliraisedled’s switch and the whole thing looks like it was made by Toyota. I’m a happy camper…
  9. Sep 23, 2021 at 7:41 AM
    clarkritchie
    clarkritchie New Member
  10. Sep 23, 2021 at 7:42 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    So the company itself is a great company. They are producing some excellent products. They are a pretty young company too which is experiencing rapid growth so there has been some growing pains with product availability and fulfillment, but they are actively making changes for the better.
    As for the 42" light bar I have one in my truck as well. It is a very powerful unit that can be installed in a couple of hours with just a handful of swear words. Some folks have experienced some issues where the brackets are flexing vertically to where it allows the bar to move some. I have seen some people use VHB tape to affix the bar down to the bumper to keep it stable and it sounds like it has worked. I have raised the concern to DD's engineering team, and have also looked at possibly making something in-house for people, but it's a ways out.
  11. Sep 23, 2021 at 7:43 AM
    memario1214
    Colton
    Missoula, MT
    And the link that @clarkritchie posted has some critical discussion as well :thumbsup:
    HulkSmurf14 likes this.
  12. Sep 23, 2021 at 9:53 AM
    Charliebrn
    NW Ohio
    This is what I did to fix the bar from moving. It’s rock solid:
    the back screw is already threaded on the light bar, so just picked up a short screw and aluminum bushing. Just have to drill the back hole in the bracket and put that all together before you actually bolt the bracket to the bumper mount.
    Mater and bulldog93 like this.
  13. Sep 23, 2021 at 11:42 AM
    vipgs3
    vipgs3 New Member
    CA
    2015 Toyota Tundra 4x4
    Will the 42” fit into the bulge?
  14. Sep 23, 2021 at 12:23 PM
    Charliebrn
    NW Ohio
    Not from what I’ve read. There are special kits for that however.
  15. Oct 10, 2022 at 6:51 AM
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    got the 42" and very happy with them.
    TRDFerguson, bulldog93 and Charliebrn like this.
  16. Oct 10, 2022 at 8:07 AM
    memario1214
    Colton
    Missoula, MT
    Random pop-up in my feed here!
    The Hotshot Offroad version of the 42" brackets is OFFICIALLY under development. Finally got the laser table access that we have been waiting on. Should have a prototype to share in the next couple of weeks :cool:.
    As an aside... We do have Diode Dynamics gear on sale for the next 3 days (10/10-10/12). You could pick up a light bar and harness now while they're on sale if you're kicking the idea around and await a proper lower bumper bracket kit :devil:
    https://hotshotoffroad.com/products/stage-series-light-bar
  17. Oct 10, 2022 at 8:09 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Big fan of their lights and customer service is top notch. Probably throw some white SS5 Spots behind the grill later this year.
  18. Oct 10, 2022 at 8:21 AM
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    For those truly interested in this 42” from DD, this morning I came across one on CraigsList here in Seattle (nearby in Kent about 20 mins away) for $350, like new condition. I know there’s a place for this on the forum, but just saw this this morning then saw this thread brought back to life. Not mine so I have no other info.
    https://seattle.craigslist.org/skc/pts/d/kent-tundra-fog-light-kit/7543685358.html
    bulldog93 likes this.
  19. Oct 10, 2022 at 8:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Add that here: https://www.tundras.com/threads/pnw-craigslist-finds.35293/page-12#post-2941633
  20. Oct 10, 2022 at 8:36 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Damnit Colton. I’m tossing around the idea of getting some SS3 Pros in place of my Rigid D series fogs. Then I could be matchy matchy on the front of the truck.
    Also, PM me if you need a field tester on those new brackets…
  21. Oct 10, 2022 at 8:38 AM
    memario1214
    Colton
    Missoula, MT
    I have been (im)patiently waiting for you to throw those Rigids out... Bout time you come around :rofl:
    joseph_womack and Mater like this.
  22. Oct 10, 2022 at 8:40 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I got some major side eye from the wife when I told her my gameplan just now. I guess I should just do it at this point since I’m already getting shit for it :monocle:
    French Avocado, Mater and reywcms like this.
  23. Oct 10, 2022 at 8:41 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes and Yes lol
  24. Oct 10, 2022 at 8:47 AM
    RusPro21
    Don
    Pa.
    That should jump up the sales for that light bar with the new brackets. I have been holding off on the light bar this time. Especially reading where guys having issue with the led light bar not holding in place. I love my Pros from Colton!! There awesome.
    Mater likes this.
  25. Oct 10, 2022 at 9:11 AM
    memario1214
    Colton
    Missoula, MT
    Hoping to solve the wobble issue once and for all! This bar performs very well for the money so I figure we might as well keep it securely in place!
    RusPro21[QUOTED] likes this.
  26. Oct 10, 2022 at 9:28 AM
    RusPro21
    Don
    Pa.
    Colton, Who is fabricating the mounts? If you buy the light bar will you still get the new mounts since they won’t be ready for a few wheels? Thanks.
  27. Oct 10, 2022 at 9:30 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Their fogs are some of the best quality I've seen. Output is better than the rigids from my experience.
  28. Oct 10, 2022 at 9:36 AM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    No experience with their light bars, but I run 4 SS3 Pro fogs (2 yellow, 2 white). They've been on the truck for about 2.5 years now and work wonderfully. Might as well be headlights with how bright they are. Soon I'll be looking for a set of small white cubes for reverse lights and maybe some ditch lights and will 100% be going with DD.
  29. Oct 10, 2022 at 9:54 AM
    memario1214
    Colton
    Missoula, MT
    A local fabrication company who I have worked with for a few years on personal projects with will be producing the brackets. Currently bouncing around locally to source the best place for powdercoating.
    The 42" DD light bar and Hotshot Offroad brackets will be different (but complimentary) products. Once we have the brackets complete and ready for retail we will make new listings and no longer even offer the DD brackets. So if someone wanted HSO brackets down the road, but wanted to capture the current sale I encourage them to purchase just the 42" light bar (and wiring harness if desired). DO NOT buy the currently listed Tundra "kit" on the website or you will receive DD's brackets.
    Side Notes:
    • Anyone who purchases a 42" DD light bar during this current sale will be eligible for the "bundle" pricing as if they purchased a light bar and brackets together.
    • We intend to offer discounted pricing on our new in-house brackets to anyone who has previously purchased a full DD kit from us in the past.
    DD's brackets run retail $60 and are verifiably not great. We're going to do our best to keep pricing as realistic as possible while still making it a viable product for us. What I can say is that pricing is not yet set, but don't expect to be slapped with a $150 set of brackets either. However, I can promise a few key features that are not currently available on the DD product. Not QUITE ready to share the deets... but close.
  30. Oct 10, 2022 at 10:45 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Why not the maxes? :boink:
