Really need some creativity for mounting this camera
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundyFromDownUndy, Oct 8, 2022.
  1. Oct 8, 2022 at 4:12 PM
    TundyFromDownUndy
    TundyFromDownUndy [OP] New Member
    2020 Platinum Tundra
    So I've purchased a dashcamx, and installed the front 4k cam. I ran the wire for the rear cam, and now I just need to mount the camera. I was thinking I needed some sort of clip, that has spring to it, so I can clip it over the headliner (which is not completely flat, so that's one challenge) and them slide the camera over the exposed side of the clip, holding it in place in the least evasive way possible. The camera has a gap between it and its swiveling platfor., which only swivels 90 degrees. I also bought 1 inch cable clamps , in hopes I could flatten it and then put a bolt and nut through the hole and the 2 holes on the top of the mounting plate. But I wouldn't be able to hold the nut still behind the liner when tightening. So yeah. I'm out of ideas and menards employees didn't offer much. So here I am. Broken. Humbled. Help.
  2. Oct 8, 2022 at 4:15 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  3. Oct 9, 2022 at 12:14 PM
    burtlively
    burtlively New Member
    2017 Tundra 4x4 CrewMax Platinum
    7B7CB4AA-FACD-4B3A-BE4F-094D86626034.jpg EFAF2AF2-3A4A-4E9A-BF05-2B69D2AC7B2A.jpg Here’s what I did.
  4. Oct 9, 2022 at 2:32 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Mounted inside your 3rd brake light/cargo light? Interesting! Can you share more details on how you did it?
  5. Oct 9, 2022 at 8:17 PM
    burtlively
    In a nutshell I drilled a hole in the brake light, dropped the headliner, removed the 3rd brake light, took out the middle light and mounted the camera there. Rank the wires and connected my new “smart Rearview mirror”. I’m not saying I’m the least talented person on this forum, but I’m close. Basically if I can figure this one out, anyone can. The brake light cover needs to be tidied up. Mine is very crude and rudimentary.
  6. Oct 9, 2022 at 10:24 PM
    tejastundra1
    tejastundra1 New Member
    bulldog93 and sf319 like this.
  7. Oct 10, 2022 at 4:56 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
  8. Oct 11, 2022 at 5:19 AM
    TundyFromDownUndy
    Awesome. They didn't have 1 inch in black so I got 2inch for it. Hopefully that'll be fine
  9. Oct 11, 2022 at 5:48 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    It'll just hang a bit lower is all, or you could trim it shorter. Black wasn't in stock when I ordered so I went with the gray, didn't match the camera but it matches the interior. I cut a notch in the metal bracket to match the bracket on the camera, fits nicely together but it's not necessary. I also felt the camera was pointed a little up once it was installed in the truck so I bent the drop section of the metal bracket towards the front of the truck a bit, not much, just enough to angle the camera how I wanted it.
  10. Oct 11, 2022 at 9:28 AM
    Teebo502
    Teebo502 TUNDRA LIFE
    Teebo
    Louisville, KY
    2020 White Tundra CM TSS
    Chrome Delete, OEM TRD Pro Exhaust, Red Leather Seats, OEM TRD Pro Led Headlights, Steering Wheel Mod, Window Tint, Bed cover, 2" Front Level, REXING V1P Pro Dash Cam.
    https://www.thedashcamstore.com/custom-folded-bracket-for-secondary-dashcam-lenses/
  11. Oct 11, 2022 at 9:34 AM
    Teebo502
    Teebo
    Louisville, KY
  12. Oct 11, 2022 at 1:57 PM
    HOKIES
    HOKIES New Member
    Western Virginia
    2021 B Red Crew Max
    I second the recommendation of “ The dash cam store” bracket. I experience no vibration on video imaging. Simple and effective . Easy to install
  13. Oct 14, 2022 at 11:50 AM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Bracket then mounted rear camera. No vibration and clear view of rear bed and rear tail gate area
  14. Oct 14, 2022 at 1:01 PM
    TundyFromDownUndy
    Looks clean. Was yours 1 or 2 inch? Nice to hear I can set it, and forget it
  15. Oct 14, 2022 at 1:05 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I zip tied mine to the metal hook for the child seat tether under the center headrest.
    bulldog93 and MadMaxCanon like this.
  16. Oct 14, 2022 at 1:25 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Depends on your camera, mines was small so 1” was enough
  17. Oct 14, 2022 at 1:28 PM
    18" TRD Off Road Wheels
    Meso made some molle style roof racks that rand from oh shot handle to oh shit handle in the tacos.
    Could you shape something to go across the same way and mount your bracket to it? It'd be reusing the handle mounting points, so no drilling.
  18. Oct 18, 2022 at 8:33 AM
    TundyFromDownUndy
    For those who are curious. The 2 inch is too long and needs to be cutting or it will press into your back window. I guess I'm the first to buy the 2inch? I
  19. Oct 18, 2022 at 8:54 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Just bend the bracket forward towards the windshield a little, that'll keep it off the rear glass, I did this with the 1in drop bracket also
  20. Oct 18, 2022 at 9:04 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    My rear cam shorted, so it isn't there at the moment. But, I made an aluminum bracket and riveted it to the headliner with stainless washers on the back. Use a grommet to make the hole look presentable.
  21. Oct 18, 2022 at 9:28 AM
    TundyFromDownUndy
    Thanks yall, very helpful in times of frustration.
    Gaston likes this.
  22. Nov 22, 2022 at 3:58 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    What camera is that
  23. Nov 22, 2022 at 4:05 PM
    Squatting Pigeon
    Holden
    North Texas
  24. Nov 22, 2022 at 4:12 PM
    MadMaxCanon
  25. Nov 30, 2022 at 10:38 AM
    HOKIES
    HOKIES New Member
    Western Virginia
    2021 B Red Crew Max
    Pulling down the rubber gasket. Placing the mount inside the crevice where the rubber gasket goes. Then shoving the rubber gasket back up into the area. That simple.
    MadMaxCanon[QUOTED] likes this.
  26. Nov 30, 2022 at 10:49 AM
    MadMaxCanon
    Cool thank, was worried i had to mess with the headliner
  27. Aug 9, 2025 at 9:03 AM
    RobertD
    Robert
    DFW, Texas
