Rats ate wiring 2021 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Deserttundra21, Oct 6, 2022.
  1. Oct 6, 2022 at 2:45 PM
    Deserttundra21
    Deserttundra21 [OP] New Member
    Hello,
    I had my 2021 Tundra parked outside of the garage for a week, and that was enough time for a Rat to move in.
    They chewed through a black, red and green wire on the back side of the engine. I am having a hard time figuring out where the wires go to. The truck will start, but all the dash lights are on. It seems like the wires might go under the intake manifold. Is there a sensor under there with a red, black and green wire? The area circled is the general area of where the wires are behind the engine.
  2. Oct 6, 2022 at 11:09 PM
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    That harness doesn’t go completely under the manifold, it goes around the back side of it. I installed the power wires for my ARB harness and zip tied them to that exact harness when I ran them to the battery last weekend. That’s gonna be a tough job to fix because access is so tight. Personally I would solder and heat shrink any wires needing to be replaced but you could get away with weatherproof crimps as well. Damn rats! Sorry for the bad luck!
    Elduder likes this.
  3. Oct 6, 2022 at 11:14 PM
    Deserttundra21
    Thank you for the reply. Based on the research I have done; I think those wires are coming out from under the manifold and they go to the crank position sensor.
    Luckily you can buy that harness part # 82219-0C020
    We will see. I should probably get a OBD2 scanner to confirm.
  4. Oct 6, 2022 at 11:18 PM
    Redline870
    Ian
    Central NY
    Ckp would likely cause major drivability issues since that reading controls timing, fuel delivery, etc. Does it run fine beside the MIL being on? Definitely scan it to get you an idea of what they might be.
  5. Oct 7, 2022 at 4:03 AM
    pursuit2550
    pursuit2550 New Member
    I had a rat in my truck, no damage, and my wife’s Lexus. Hers, the rat ate through the windshield wiper fluid hose, that goodness it was only that. After that I bought the green poison squares and broke them in fours. Placed them around the engine bay and replaced as needed. Rat is dead now. Sucks this happened. Thanks for the reminder to go and check though.
  6. Oct 7, 2022 at 4:19 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Sorry this happened! Good luck getting it fixed.
  7. Oct 7, 2022 at 4:25 AM
    Total bummer. I had to get a few barn cats for my area.
    WILLINH, coldcanuk, TTund16 and 3 others like this.
  8. Oct 7, 2022 at 6:17 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    That would be a plush barn that barn cat is laying in....
  9. Oct 7, 2022 at 7:32 AM
    He comes inside for about 10 minutes. He then wants to get back outside.
    NewImprovedRon likes this.
  10. Oct 7, 2022 at 9:20 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Sure he does.. ;)
  11. Oct 7, 2022 at 10:04 AM
    He’s pretty feral. I can’t even pick him up without becoming mince meat.
  12. Oct 7, 2022 at 10:33 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I beat he tears up those rodents!
    WILLINH and ColoradoTJ[QUOTED] like this.
  13. Oct 7, 2022 at 10:40 AM
    I have two of them…and they kill everything.
    WILLINH, coldcanuk, Gravy and 2 others like this.
  14. Oct 8, 2022 at 3:56 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I read a thread about mice in cabin filters. I checked mine and it was ok. I got in my console for something and corn kernels fell out the back of the lid. Took it apart and found this. I set some mouse traps inside the truck and in the engine bay. Nothing in the truck. Got one in the engine bay. He was the only one I got in about two weeks of setting the traps. I still can’t figure it out how it got the kernels in there. F2AAD06A-D318-479D-90E3-1B088C21676C.jpg29210859-AF59-48A2-A6C3-76179F406617.jpg
    WILLINH, Spyker and Black Wolf like this.
  15. Oct 8, 2022 at 6:34 AM
    Great!
  16. Oct 9, 2022 at 1:21 PM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Anytime my truck sits for more than 2 days I make sure to;
    -Close all vents
    -Put air handler to recirculate (read it closes the fresh air vent, figured it might be one less entry method, maybe?)
    -Place a few cotton balls soaked with peppermint oil concentrate, I've got a few taped to the bottom of the engine cowl cover, and then finally I put some drops on the sound deadening material on the engine
    -Finally I place a Victor Rodent killer trap on top of the cowl, figured this way if there are creatures in there, they'll at least nibble and check out the poison (its a clear trap so you can see if the bait block has been chewed on).
  17. Oct 27, 2022 at 7:34 AM
    Double DC
    Double DC New Member
    2005 DC & 2021 DC
    Just went in for the 15k service on my '21 Tundra and they found that a mouse had chewed through the cabin filter. Which explains why I found a mouse chewed napkin in my center console about a month ago. The dealer installed a relatively fine metal mesh (maybe 1/16" squares) in cabin air intake and engine air intake for a mere $200. Perhaps someone more knowledgeable than I could provide info to folks on a DIY mesh install.
  18. Oct 27, 2022 at 7:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Check your cabin air filter while your at it. Dont want to be breathing a mouse toilet.
  19. Oct 27, 2022 at 7:52 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Double DC likes this.
  20. Oct 27, 2022 at 8:33 AM
    CTundraForMe
    CTundraForMe New Member
    Cats and traps are you friends.
    Except rat traps can be dangerous for kids.
    Poison is dangerous as anything that eats the dying animal will likely be poisoned too.
    I have mouse traps all throughout my garage, and plentiful cats outside for rodent control.
    Some people swear by flashing LEDs in the engine compartment.
  21. Oct 27, 2022 at 9:21 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    And after they eat poison they will look for water. I had one chew through a livewell hose in the boat after putting out poison. Luckily it was right under a floor drain. I went fishing and had to run bilge pump constantly.
