Added TRD rear sway bar kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2015TRSPROSD, Jun 23, 2015.
  1. Jun 23, 2015 at 10:39 PM
    2015TRSPROSD
    2015TRSPROSD [OP] 2015 Tundra TRD PRO
    2015 TRD PRO CREWMAX
    XPEL protective Film (XPEL.com) Whole vehicle Tundra stamped letter insert (black) TRD PRO bed stamp letter insert Punisher Hood Decal (Matte Black) Fender and side cladding (TrdSparks) Side steps (Iron Cross- Linex coating) Retrax Pro Bed tonneau cover (Black) Punisher skull hitch cover (color matched custom paint) Michelin Defender LTX MS 295/70/18 Toyota Tundra 14-15 LED Taillights - Dark Red Smoked Lens Opt7 Headlights (bright as the sun pure white light) Tundra center console decider TRD Cold Air Intake Stubby antenna Weather Tech all weather mats TRD Brake pads Titanium exhaust wrap (covers exhaust pipes) Painted Engine Cover (Color Matched) Optima battery Billet Aluminum Optima Battery cover (Skull design-Optimatrays.com) TRD Sway Bar Kit Headlight Revolution (Gen 2 fog lights) Headlight Revolution Stealth light bar Color stable window tint Door sill protective trim Drivers side Grip Assist Hamdle add on LED bulbs inside & outside placements Focal front speakers and tweeters Kicker rear speakers JL stealth box subwoofers Kicker 4 channel amp Kicker mono amp Rebadged Whole
    I will say it makes a big difference for driving the vehicle in town and highway like I do. Glad I did it.
  2. Jun 24, 2015 at 3:32 AM
    TODDK
    TODDK New Member
    Todd
    Hibbs, PA
    2014 Tundra TRD
    6" lift sitting on 20x10x-24 wrapped with 35 MTs
    No paint to match???
  3. Jun 24, 2015 at 3:34 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Looking good. Underbody colors doesn't matter. Even exactly same color looks different when installed underbody.
  4. Jun 24, 2015 at 4:05 AM
    You will really notice the difference with a camper or a heavy load.
  5. Jun 24, 2015 at 4:57 AM
    I've heard these make a huge difference on cornering. It's def on my list to purchase.
    Tundyfundy and darkknight2014 like this.
  6. Jun 24, 2015 at 5:59 AM
    Hellwig also makes decent sway bars. Adjustable and non-adjustable versions depending on rear lift set up. Wouldn't be surprised if the TRD sway bar is made by Hellwig.
  7. Jun 24, 2015 at 6:10 AM
    2015TRSPROSD
    On the off ramp last night, took it at 65mph handled like my FJ.
    P-Factor and T-Rex266[QUOTED] like this.
  8. Jun 24, 2015 at 6:16 AM
    2015TRSPROSD
    If your asking why I didn't paint the TRD SAWY BAR KIT, That would be like painting the springs and the CAI. I'm not at a "white party" or in this case an "inferno party" I'm not here to change TRD colors, just add some nice character to my truck. Besides it looks just enough but not too much as is.
  9. Jun 24, 2015 at 7:57 AM
    What?? You don't paint your springs or coils to match? Shame shame. (sarc of course)
    By the way, Is the TRD sway bar around $275 or so not installed?
  10. Jun 24, 2015 at 10:01 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Dude, that's way too much to pay. I found mine on Craig's List for less than $200.
  11. Jun 24, 2015 at 10:13 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Gonna pair it with the Sequoia front sway bar too?
    My biggest gripe with the TRD is how low the sway bar sits. If I get one, I won't mount it on the bottom of the axle like you did. I'll rotate the clamps 90 degrees and have it off the back of the axle. Like so:
  12. Jun 24, 2015 at 10:48 AM
    I have been looking for one one Craig's. Did you happen to put quick disconnects on or do you think you need them? Just curious how yours reacts if at all when you are off pavement.
    Punisher29073 likes this.
  13. Jun 24, 2015 at 10:50 AM
    I like that setup. A lot.
  14. Jun 24, 2015 at 11:41 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I didn't use any quick disconnects, the Tundra is too wide for the trails up here. I've done the off-road thing and sold my Tacoma to someone that'll use it. It became such that ultimately it was too impractical for daily use and was a waste to street it. I have different project to spend "extra" on.
    That being said, on the Forest Roads, the rear TRD sway bar stiffens the ride up against any articulation, my having the Sequoia sway bar up front contributes to that I'm sure, as well as the truck being a "little" lighter (RCSB)
    Also, I would think that rotating the rear sway bar in the manner demonstrated in the picture above would decrease the leverage that the links would put on the bar lessening its effectiveness. I'm of the argument that if you are going to off-road your truck, don't bother wasting money on the sway bar, buy something for off-road. FWIW
    tat2ude39 and 15max like this.
  15. Jun 24, 2015 at 11:57 AM
    jberry813
    Lake Tahoe
    The end links are just pivots. Sway bars are used as lateral load assistance (flattening the truck's ride around corners), not up and down. Rotating it to the back of the axle will have absolutely zero perceivable difference.
    Think about the diameter of the end links. They are about as big around as a pencil. Putting any load on those and they'll deform like a pencil too. That's not how a sway bar works.
    Law323 and NewImprovedRon like this.
  16. Jun 24, 2015 at 12:20 PM
    I've taken my Tundra all over various trails and narrow crappy mining roads. It can be dicey at times. I do have to pull my mirrors in at times. The only problem I have on rare occasions is turning around, which does suck. I bought my Tundra for the off road thing. I have bought all my past 4X4's for the off road thing.It's probably too wide for 5% of the trails/mining roads here and I've been wheeling here for 11 years over a lot of the major passes and not so major. Spend a lot of time up near James Peak with all the other Jeeps and trucks up there on all the "narrow" trails. For those rare times times I can't use my Tundra I'll use the Jeepster. Actually the wider Tundra wheel base comes in handy since I don't have to deal with Jeep trail/road ruts. I'm obviously not talking about rock crawler trails. I've only had to stop a couple of times because of being too wide and didn't want to shear off sheet metal. If you don't want scratches stay on the highway is my motto.
    With sway bar quick disconnects you can have the best of both worlds. On or offroad.
  17. Jun 24, 2015 at 12:27 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    i want to add one. i have 4" blocks. i check out hell wig and they don't really have anything that says for a lift.
  18. Jun 24, 2015 at 12:29 PM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    also looking at pictures on google and it seems people mount them differently as well
  19. Jun 24, 2015 at 12:30 PM
    I have their catalog and they have one for stock height and one that can be adjusted but don't recall how much it can be adjusted. You should call Hellwig for specifics.
  20. Jun 24, 2015 at 12:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've been here a bit longer and tend toward the super technical, sketchy, body damage trails. I like that challenge, but I don't have the room for any more vehicles.
    I understand that the sway bar does not change suspension travel (up and down of both wheels at the same time), it resists articulation (one wheel moving rising or dropping when the other is moving in the opposite direction or not moving at all). I believe that there is a difference, albeit possibly unperceivable, when the sway bar is incorrectly installed as in the pictured. There's a reason that it is instructed to be installed flat, that's part of the reason why some are adjustable and why lifted trucks need longer links. I think that I would be able to show what I'd like to with a pencil and a napkin, but can't think how to here in text. It has to do with how the force of motion is applied perpendicularly to the ends of the bar rather than at an obtuse or acute angle. *grimaces in frustration*
  21. Jun 24, 2015 at 12:51 PM
    Been wheeling for 43 years. Cali, Baja, Oregon,Washington, BC, Nevada, Alaska, Japan, Philippines, here. I've developed a good sense of what four wheeling is about over that time.
    CementSR5, Law323 and Wynnded[QUOTED] like this.
  22. Jun 24, 2015 at 1:03 PM
    I do plan on fixing up the Jeepster so I can hit some of those crazier trails, but it's going to take a lot of work and $. And a lot of time. Should be fun.
  23. Jun 24, 2015 at 1:11 PM
    jberry813
    Lake Tahoe
    Build your own longer end links
    Respectfully, you don't need a bar napkin to explain it to me. I've built tons of suspensions in lifetime ranging from go-carts, race cars, quads, and offroad trucks. I'm intimately familiar with how a sway bar works. Moving the TRD sway bar to the back of the axle instead of the bottom will move the the axle side of the sway bar up maybe 1.5". Since the end links pivot on both ends (frame side and sway bar side), the sway bar will just be slightly pivoted down and the end links slightly pivoted rearward. No ass dyno will be able to tell the difference. Hell there's that much change in the front sway bar on a 2nd gen tacoma when you use the sway bar brackets to push the sway bar forward away from the coilovers.
    And if you really were that anal retentive about the sway bar being used as it was "designed," it was "designed" for a stock truck. Not a truck that has any amount of rear lift. Take random joe's truck with a 2" block in the rear. By moving the sway bar to the back of the axle instead of the bottom...you're actually putting the sway bar back at the angles it was "designed" for. Regardless...those end links are so stupid simple, a new shorter set could be built in 15 minutes out of scrap metal. I've built a rear sway bar for a linked truck pulling 28" of travel, I'm sure I can manage with a truck that has a stock(ish) rear end.
  24. Jun 24, 2015 at 4:48 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Naw, if you're comfortable doing it that way, I have no objections. My frustration and mention of the napkin is because I can't seem to put into words what I'm trying to say, I feel I could draw it though, or wave my hands around a bunch.:goingcrazy:
  25. Jun 27, 2015 at 9:32 PM
    2015TRSPROSD
    It's installed and yes $250.00 + $32.00 labor for install
  26. Jun 27, 2015 at 9:36 PM
    Fair price. Especially labor. Not bad at all.
  27. Jun 27, 2015 at 10:20 PM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    Where/ Who did you buy the sway bar from? I was just looking on line for one.
  28. Jun 28, 2015 at 11:55 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    trd sway bar can be found on the Amazon
  29. Apr 27, 2017 at 3:59 PM
    Joeblue4x4
    Joeblue4x4 New Member
    Will the TRD
    sway bar help with towing? Improve sway from the travek trailer transferring to the truck? Thanks
  30. Apr 27, 2017 at 4:23 PM
    jberry813
    Lake Tahoe
    Yes...very much.
    Law323 likes this.
