Paint-Most Durable Q.
Discussion in '3rd Gen Tundras (2022+)' started by Uconn411, Sep 30, 2022.
  1. Sep 30, 2022 at 7:03 AM
    Uconn411
    Uconn411 [OP] New Member
    Richard
    Good Morning. So I'm renting a Tundra for a week in November to try it out on vacation. If it meets my needs, I'm planning to put in an order for a 2023, Crewmax (non-TRD). I've read through threads regarding paint and durability (or lack there of).
    My top 4 colors:
    Magnetic Gray Metallic
    Army Green
    Blueprint
    Celestial Silber Metallic
    I currently have a "obsidian blue" Honda Pilot that has the flaky look to the paint. The biggest issue I've had is trying to touch up, you just can't match the look on the paint even with the Honda OEM color. I think it's that "bass boat" like looking flake that is tough to match. So I'm trying to look for the most durable paint on a Tundra (added benefit if it touches up decently). I've tried looking up paint thickness but it seems to vary. Thanks!
  2. Sep 30, 2022 at 7:29 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Toyota paint is thin, especially on the new trucks. Color won't change that much however Toyota has had some issues with white and pearl white, as do most brands. The whites often dont have a clear coat.
    Anyway, MGM is a nice color that looks good a long time and does not show dirt or scratches too bad. Same with the green. Silver can tend to fade over time. Toyota deep blues like nautical or blueprint have had some clear coat or other issues. Beautiful color but it will show marks, scratches more.
    Whatever color you choose, keep it clean and wax/seal 3+ times a year and it should look great for a long time. For longevity, I would say MGM or Army Green as best bets from the choices you list.
    Metro14536 likes this.
  3. Oct 3, 2022 at 9:42 AM
    wayoflife
    wayoflife Exploring Cascadia and beyond
    Seattle-ish, WA, USA
    '22 1794 6.5' TRD Offroad Blueprint/Cream
    Westcott 3/1 Method 705 18x9 18mm Maxxis RAZR 295/70R18
    Blueprint owner here, can sadly confirm. Breathe near it and it scratches. Don't dare let your teenage boy fart at it.
  4. Oct 3, 2022 at 10:03 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Same with the Celestial Silver unfortunately
    wayoflife[QUOTED] likes this.
  5. Oct 4, 2022 at 2:49 AM
    JoeInMinn
    JoeInMinn New Member
    2022 1794 Trd
    In your shoes , I would look into doing your own ceramic coating its not hard just a solid day and a half of work. Or have some quality ppf done but a reputable shop NOT THE DEALER!! I am going to get my most likely to be scratched areas covered in PPF , then ceramic coat the truck.
    Kap1 likes this.
  6. Oct 4, 2022 at 10:22 AM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    I'm experiencing the same issues with the black. The factory paint is super thin! I noticed scratches after the first car wash. Since then its been touchless only. I only drive it on the weekends and somehow there is a new scratch after everytime it leaves the garage. :(
  7. Oct 4, 2022 at 10:29 AM
    catalac
    catalac New Member
    I think the tundra paint is just fine compared to the fords and chevs I owned the same years, I wouldn’t worry about it. Go light color if worried about visual scratches, can’t beat white or silver.
  8. Oct 4, 2022 at 10:35 AM
    JoeInMinn
    2022 1794 Trd
    I love detailing and do a lot of cars. Its not extremely uncommon . Black obviously will show marks super easy. Toyotas paint isn't the hardest or softest(Tesla) , but any brush style on car wash that contacts the car will cause scratches no matter how hard or soft the paint.
    Use quality microfiber like ones from The Rag Company, don't wipe your car without some lubrication involved ie detail spray, rinse less wash ect. The only way to prevent any car from scratching is a proper wash process at home, 2 buckets ,grit guards, clean wash pads. I have seen cars with super hard ceramiclear coats scratch no issue with just some dust and a microfiber.
    I got a new Cadillac a couple years ago extremely hard paint, the first wash the dealer did in there car wash took me 9 hours of labor to undue the damage.
  9. Oct 4, 2022 at 5:00 PM
    MJPlat
    MJPlat New Member
    Those are 4 very different colors you’re debating. I would just pick the one you like the most and like other have stated above, keep a layer of wax on it all the time, 2 bucket wash and park it in the garage (or covered). The paint, no matter the color, should do fine over the long run.
    zonehenge likes this.
  10. Oct 5, 2022 at 6:37 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Two words - ceramic coating.
    Get it installed professionally of course!
  11. Oct 5, 2022 at 7:12 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Ive owned 1 blue streak metallic tundra and 3 or 4 MGM tundras. Currently on WCP and it shows zero scratches vs MGM which scratches easily.
