2008 Gen 2 Check Engine Light
Discussion in '2nd Gen Tundras (2007-2013)' started by martinjrherrera, Aug 19, 2020.
  1. Aug 19, 2020 at 12:40 PM
    martinjrherrera
    martinjrherrera [OP] New Member
    martin
    2008 Toyota Tundra SR5
    Tundra mechanics unite! Check engine light on first time ever for my 08. Throwing code P0418,P2445 I need assistance. Drove truck and doesnt accelerate take awhile for it to kick in and accelerate and sometimes it is fine no issues. What are yalls thoughts?
  2. Aug 19, 2020 at 1:06 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    AIP system. Do a search and you'll find plenty of info.
  3. Aug 19, 2020 at 1:13 PM
    martinjrherrera
    martin
    Search where in here or what search string do I use?
  4. Aug 19, 2020 at 6:15 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Search using "AIP system". When you read up about it, you will find that you will probably be better off by-passing the system. Fixing it will cost a lot of money so by-passing it will be more cost effective. Also fixing it will not guarantee it from a future failure. Mine had already been worked on twice before I bought my truck. The AIP system is a terribly designed system that is prone to repeated failures. Toyota dealers are raking in big bucks from unfortunate owners repairing it.
    HewittTech01 likes this.
  5. Aug 19, 2020 at 6:25 PM
    TemujinNomad
    TemujinNomad New Member
  6. Oct 5, 2022 at 6:28 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    @bleach I could not have said it better myself. To supplement I wanted to provide some additional Secondary Air Injection System resources for everyone runs into this inevitable issue. I will leave it at that and anyone that has additional question do not hesitate to contact us.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
