  1. Oct 2, 2022 at 7:36 PM
    Nice setup. Mine is still in work lol.
    Major, Wallygator, AggiePhil and 5 others like this.
  2. Oct 2, 2022 at 7:42 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    The mounts you made are awesome! Mine keeps rotating the same so maybe I'll have to do something similar...
  3. Oct 2, 2022 at 8:49 PM
    AndyTex
    AndyTex New Member
    2020 Tundra 1794 4x4
    Replaced the stock battery after 2 years and 2 months. Costco definitely has the best deal on a 27F.IMG_8385.HEIC.jpg
  4. Oct 2, 2022 at 8:49 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Another step closer in my SP9100 install - it's powered up but not hooked up to anything yet. I need to loom the wiring and do some routing cleanup, but need to finish the bumper first.
  5. Oct 2, 2022 at 11:49 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    It was a lot of work but at least I have piece of mind that it’s not going to move. I over built mine like I do everything but it’s solid as it’s can be. I made the main hanger brackets out of thicker stainless and made the aluminum pieces with grooves and second screw slot so I could mound the hangers and slide the light on and off until I got the angle adjusted. I still had to unbolt hangers to mount light to brackets but it did make it easier getting light set to correct angle. I’m sure that there are simpler solutions for making light stay in place but I like to make things bomb proof as possible. I was told that Hotshot offroad is designing something that should be coming out in the next month or two. Diode Dynamics shouldn’t even sell that bracket that comes with the light. It’s just junk. I did trim the inside plastic around edge around the bumper to give me a little extra room and I milled the aluminum brackets a little thinner in the finished product but didn’t take any pictures. Bracket just need to have two screws on each end to stop it from moving. This could be done with bracket that came with light by drilling a second hole. From what I’ve read other have said that the brackets, that came with light, were not rigid enough for the weight of the light and would sag so I went with thicker brackets. Hope this gives you some ideas. Good luck.
    FD599846-DBF0-4189-A404-C167345E4995.jpg A6B0855C-EF46-4665-AB02-5843C8706726.jpg
  6. Oct 3, 2022 at 12:56 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    this is on my wish list
  7. Oct 3, 2022 at 12:59 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    I spy a MT09? Judging by the s23 Bridgestone
  8. Oct 3, 2022 at 4:57 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Hope you never need to get into that fuse box.
  9. Oct 3, 2022 at 5:42 AM
    SwitchThrottle
    Who makes that power distribution box, or was that a custom build too?
  10. Oct 3, 2022 at 5:46 AM
    joey2018
    joey2018 New Member
    Gave mine a bath by hand at home. It was pretty flirty after running all over sw fl checking on homes for clients and helping people
    Where we could. First time in 5 years I have washed a vehicle in my driveway. 6E4C5D54-268D-4A24-B7CA-1691531F2F10.jpg
  11. Oct 3, 2022 at 6:05 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    Looking Sharp!
    Is that front bumper plastidipped?
  12. Oct 3, 2022 at 6:16 AM
    Rangergillikin
    Alabama
    I built it myself. I just welded 1/8 stainless plate together to make the metal box and milled and slotted the grey plastic. My friend printed the cover. The bottom has a area left open so that you can push wire through. 72B9FBBE-1CA4-487E-AA43-9AAA59F27D07.jpg
  13. Oct 3, 2022 at 8:04 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Four screws and two bolts and it all comes off. The connectors for everything are set so that I can unplug or unscrew a terminal and the whole thing lifts off easily.
    That, and I don’t anticipate needing in there very often. In 12 years and 300k miles on my last Tundra, I never once had to get into that box.
    Wallygator, JCBerb, AggiePhil and 2 others like this.
  14. Oct 3, 2022 at 8:09 AM
    TaquitoBandito
    Joel (AKA Bif)
    I was gonna say that I've seen your thread I'm pretty sure you planned ahead. ;)
    RobertD likes this.
  15. Oct 3, 2022 at 8:48 AM
    SwitchThrottle
    Fair enough...I agree that rarely does it need to be opened, but when I saw the bolts, my first thought was hope he carries tools always...just in case...
  16. Oct 3, 2022 at 9:03 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    That is really sick. Thanks for sharing the additional picks! Definitely gonna start thinking about something for my Rigid light bar
  17. Oct 3, 2022 at 9:17 AM
    RainMan_PNW
    Casey
    Clark County, WA
    GrayGhost17, rebmo, AGTundra and 8 others like this.
  18. Oct 3, 2022 at 9:29 AM
    TN -Tundra
    TN -Tundra New Member
    D
    2020 Tundra Crewmax Black
    20221004_161745.jpg I'm a Vols fan with a Blacked out 2020 Tundra. I have a simple Power T on my back window, a TN Vols license plate holder and a black with orange power T on my front plate. The red TRD wheel caps on my rims was driving me NUTS....so I painted them to match the orange touches on my truck. Added some orange valve stem covers too and now I'm happy! This is an fairly easy mod for anyone that doesn't like the red color on the wheel caps. Picked up some sanding sticks and model paint at my local Hobby Lobby. Used fine point Qtips that I also got at HL and finished with a clear coat after the paint cured.20221001_154918.jpg 20221001_223440.jpg
  19. Oct 3, 2022 at 4:44 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Good eye! Close though, it's an 07, 2020.
    Nothin like a flirty Tundy... :taco:
    Toe404[QUOTED] likes this.
  20. Oct 3, 2022 at 5:45 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    Just installed my finger grips from @2020Platinum.
    More info from his YouTube video:
  21. Oct 3, 2022 at 7:06 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Sort of silly… unneeded exhaust tip fell into my hands.
  22. Oct 3, 2022 at 7:08 PM
    biebs96
    PA
    what did you paint it with?
    And maybe consider painting the clamp and bolt. It will make it disappear from view when installed.
  23. Oct 4, 2022 at 7:17 AM
    king.cong.1119
    king.cong.1119 New Member
    Went offroad with a rivian this weekend. It is surely a nice vehicle and surprisingly capable off road.
  24. Oct 4, 2022 at 8:50 AM
    joey2018
    joey2018 New Member
    Thanks now I don’t want to take it out of the garage lol. Not plasti dip those are the eco bumper shell covers. They have held up very well through many automated car washes also. I’m very happy with them.
  25. Oct 4, 2022 at 8:55 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Few more pieces on the way closing in on the final items for baja
    AggiePhil, Baja Mike, RegGex and 4 others like this.
  26. Oct 4, 2022 at 9:03 AM
    Taco-Spike
    Two Trucks
    Got my tires re-balanced - had an annoying vibration at highway speeds.
    Drove it on the highway to the next town and back. All good now :)
  27. Oct 4, 2022 at 9:26 AM
    TN -Tundra
    D
    That's great to hear as I just ordered a set for my truck!
  28. Oct 4, 2022 at 9:41 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    I installed the pedal commander yesterday and removed it today and will be returning it. I was skeptical of its value but a bunch of people swear by them so I thought I'd give it a shot. It's nice to make the pedal a little more sensitive but not $315 nice in my opinion.
  29. Oct 4, 2022 at 9:46 AM
    You didn't like it? I have 2 of them....they make a world of difference in throttle response.
  30. Oct 4, 2022 at 9:48 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    I do like it, it did give the pedal a nicer feel on city +1 but after driving it a bit I came to the conclusion it doesn't hold $315 worth of value to me. I'd rather spend the money on something else.
