2012 Tundra internal TPMS
Discussion in 'Wheels & Tires' started by Norm1953, Oct 1, 2022.
  1. Oct 1, 2022 at 12:14 PM
    Norm1953
    Norm1953 [OP] New Member
    Norm
    Lakeland, Fl
    2012 Tundra SR5
    I've owned my 2012 Tundra double-cab, SR5, TRD, 4x4, xyz since summer of 2015. By accident I found out that the truck has an internal tire monitoring system. Does anyone rely on this system and can you add more sensors to the 4 tires on TT.
  2. Oct 1, 2022 at 12:21 PM
    ride970
    ride970 New Member
    2011 tundra magnetic grey rock warrior
    Trd intake and exhaust
    I completely ignore the light on the dash, my 07 Silverado always had the tire light on the dash, my wife’s 08 4Runner has a light on the dash, her previous rav4 had a light on the dash, my 2011 tundra currently has a light on the dash. Always ignored it. Hate tpms. My 07 Silverado had the option to view the actual psi in the tires. That was kinda handy
  3. Oct 2, 2022 at 7:52 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    All 2007 up trucks I know for sure have TPMS. The 2007-2017 use it just to control an orange warning light on the dash. The 2018+ trucks actually display pressure vlaues on the lcd in the gauges.
    I believe there is a way to add a 5th spare tire to the system but nobody has actual created an easy software solution to do it.
    Somthing like scan gauge will read and display the values on the 2007-2017 trucks
    There is one sensor in each of the 4 tires. It wirelessly relays the tire air pressure, tire air temperature and sensor battery voltage to the TPMS ecu. It operates on the same wireless frequency as the key fob that locks and unlocks the doors.
  4. Oct 3, 2022 at 5:40 AM
    minter66
    minter66 2007 TSS CrewMax
    Techstream only shows 5 available slots for TPMS ID's - when adding the sensor ID's, it only prompts for 4. I don't think you can add more than that.
