22Tundra TRD Pro motor oil
Discussion in '3rd Gen Tundras (2022+)' started by Thesamurai, Oct 2, 2022.
  1. Oct 2, 2022 at 1:51 PM
    Thesamurai
    Thesamurai [OP] New Member
    2022Tundra TRD PRO
    I have 22 TRD Pro and have a good amount of Mobil 1 synthetic left over from my Ram it’s 0-40 can I use this or would it be bad for my motor?I always do 5k oil changes and 10k filter/oil.
  2. Oct 2, 2022 at 5:06 PM
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    Manual calls for 0-20, where they allow 5-20 for occasional changes in certain conditions.
    I’d never run something not recommended- no way I’d want to explain that in case of an issue.
  3. Oct 2, 2022 at 5:09 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    It would have an increase of oil pressure until it warmed up and thinned oil out. I think I would shy away from it.
  4. Oct 2, 2022 at 6:41 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    Remember, you have turbochargers. They tend to spin at high RPM, so you don't want your oil to be so thick, especially at cold start, that those expensive and hard-to-replace items are not properly lubricated.
    On my 2010 Tundra, the engine would rev to about 1500 RPM instantly at cold start. Don't know if the V6 engines in the new Tundras do that, but if you're going to use thicker oil than specified, don't go much thicker and let your engine idle for a few minutes after a cold start so the oil can warm up and thin out a bit.
    If you live where it gets cold and the Tundra sits outside, stay with the OEM specified oil viscosity.
  5. Oct 2, 2022 at 8:42 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    0-40 is not thicker and will pour the same as 0-20 in cold. The 2nd number is how well it stays together in higher heat, the lower number is how well is pours in cold, so clearly 0-40 is the same is 0-20 for Cold, now for hot, its even better, higher heat range. Besides its Mobil 1 synth.
    07DCLimited likes this.
  6. Oct 2, 2022 at 9:02 PM
    mass-hole
    mass-hole New Member
    I dont think anything would happen but I also wouldnt run it on a brand new warrantied truck. Wouldn’t want to give them any reason to deny warranty coverage on something just because of the oil.
    on my older, out of warranty vehicles I do run different grades. 10W-30 in my Lexus and 5W-40 in my Ecoboost
