Secondary Air System / SAIS Replacement Info and Instructions
Discussion in '1st Gen Tundras (2000-2006)' started by wandering_boy, Jun 5, 2021.
  1. Jul 5, 2022 at 1:40 PM
    If I understand correctly, most or all of these kits simulate a healthy system, sending the "expected" inputs to the ECU. If your inspection is purely computer-based like it is here in GA, without any type of visual/tamper detection as part of the inspection, it should be invisible.
    It varies from state to state whether or not you'll have a more in-depth inspection. And there are varying levels of SAIS bypass kits ranging from "really damn obvious" to "extremely easy to conceal".
    Like, the 1st generation of the Hewitt kit, to me, is really easy on the install, but a trained inspector could probably find it if they knew what to look for. The 2nd Generation of the Hewitt kit is far more concealed, but requires popping out your dashboard and soldering onto 3 wires plugging into the ECU.
    Ultimately, YMMV. I think it depends on your level of comfort and the severity of your inspection. There's at least one, maybe two guys from CA on here who've installed the bypass kit and made it through the CA inspection process just fine.
    G_unit3000 and HewittTech01 like this.
  2. Jul 8, 2022 at 4:16 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    G_unit3000, EvilOne and FrenchToasty like this.
  3. Sep 29, 2022 at 6:27 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    Great Thread and hats off to @wandering_boy for detailed replacement documentation! My only input would be if you do the repair and go through all the effort to remove the intake please please please use Factory/OEM parts. Aftermarket Parts are cheap for a reason and see way to many owner cut this corner and end up paying more in the long run. If anyone has questions about the Bypass Please do not hesitate to contact us.
    Leo's first and Tundra2 like this.
  4. Sep 30, 2022 at 6:45 PM
    wandering_boy
    wandering_boy [OP] Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    All switching valves and the pump were from Toyota and GM direct. I feel like for the rubber intake gasket is a OE replacement. No Cheap stuff here. But absolutely a good tip for anyone who does this. Thanks for the input. always trying to make my instructions better. If you have a good link about bypassing besides what I have. Please feel free to PM with them.
    HewittTech01[QUOTED] likes this.
  5. Sep 30, 2022 at 6:50 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    You still pass smog but since technically it is an emissions control device. So it does technically legally make it unsellable as a smog-able vehicle. I can't remember what the code is but its either in the carb or CA dot Codes. But it passes and I certainly don't don't give a F. So why tell the next dude.
  6. Oct 1, 2022 at 10:43 AM
    Shift Happens
    Shift Happens New Member
    2002 SR5 AC TRD
    Lol, catching up on all the things that haven't been addressed.
    So, I want to verify I am reading all this correctly, an 02 does NOT have the air pump or any of these valves, right?
    I am chasing down a vacuum leak that makes a high pitched whistle, and it is a pain... replaced most of my hoses with off the shelf tubing and tried to seal the ends up on the tubes that are factory bent and flared that I will need to order.
    I have a question if anyone can help out with these specific symptoms: on start and when running, a high pitched reedy whistle sound is heard, cannot find source or pinpoint which side of engine but *seems* like drivers side. When I pinch or jiggle vacuum lines on either side of engine, the noise will subside or stop temporarily. Revving engine seems to reduce it or eliminate it until I let off gas but it could just be drowning it out. Whistle persists for about 10 sec after turning engine off.
    Any help would be greatly appreciated.
  7. Oct 1, 2022 at 11:20 AM
    Correct, '05-'06 only, VVT-i models.
    Quite likely intake manifold. Let's ask @bmf4069 since he's already gone through this with his and described very similar symptoms IIRC.
    Only use OEM manifold gasket. Trust on this.
    G_unit3000 and bmf4069 like this.
  8. Oct 1, 2022 at 11:45 AM
    Shift Happens
    2002 SR5 AC TRD
    Intake manifold? That is something I have not considered yet. I have been eyeing the charcoal canister as the culprit, but this helps, thank you.
    Is that gasket fairly simple? Or is it more like a valve cover gasket (which I need to do sometime and have been reading about)?
  9. Oct 1, 2022 at 1:03 PM
    bmf4069 Captain wtf
    Mine was backfiring pretty bad, but my gasket was completley blown out. @Shift Happens it wouldn't hurt to try to listen under the intake. It's very possible your gasket is bad.
    As @shifty` said, OEM would be best. This gasket was from RA and is maybe a year or 2 old.
  10. Oct 1, 2022 at 1:54 PM
    Oof. Man, I don't think I knew that part of it. Yikes!
  11. Nov 14, 2022 at 3:21 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    So I've had my CEL going on & off since installing the bypass kit.
    Hewitt has been 100% solid on customer service, . . . I'm the one who has been lagging and not getting back into the harness to triple check my connections.
    I suspect I left too much slack in the bypass harness when I soldered up the wires.
    Light comes on for a day or so, then goes off for a couple weeks. Weird.
    So my smog cert was due, and the light CEL was 'off' so I said, F-It and went for it . . . passed just fine.
    I'll report back when I get off my arse & take another look at the connections & take some of the slack out of the wires.
    wandering_boy[OP] and 2006Tundra like this.
  12. Nov 17, 2022 at 7:52 AM
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    So dumb question for y'all...
    It appears all this is to correct codes caused by the SAIS system failure. If I have no issues do I just run it till I do or is there some preventative stuff I should be doing?
  13. Nov 17, 2022 at 11:38 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    There is nothing you can do preventatively to avoid an SAIS failure.
    However, I seem to remember that in 'certain scenarios' one (or more) of the switching valves/ solenoids can get stuck in an open or closed configuration, which requires you to add an additional component to the Hewitt bypass kit after the fact.
    I know this is a 'vague reply' , maybe someone else will jump in and explain it better.
    I know this sounds ridiculous, but a 'safer' way to avoid the problem is to install the bypass kit before the system itself fails in the first place.
    Yep, fixing something that isn't broke . . . . Yet.
  14. Nov 17, 2022 at 11:42 AM
    2006Tundra
    Lou
    Long Beach, CA
  15. Nov 17, 2022 at 11:59 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Yep if one of your valves sticks open you have to install blocking plates on the exhaust manifold at least on my 07 not sure on 06
    also stuck open valve puts truck in limp mode so you have to repair or bypass
    G_unit3000 likes this.
  16. Nov 28, 2022 at 5:39 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    Unfortunately there is no maintenance for your SAIS. You just have to wait until it shits the bed. Unless you want to proactively replace things. The check valves that connect to the headers are the most common problem as the heat of the exhaust causes everything to rust up. Nothing you can do about that. It's just a law of chemistry.
    tokolosh[QUOTED] likes this.
  17. Nov 28, 2022 at 5:42 PM
    The trick is, just don't make the mistake of studying chem like I did. Ignorance is bliss.
  18. Nov 28, 2022 at 5:47 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    I've only done high school chem and basic chem in college. It has ruined my life. lol
  19. Nov 28, 2022 at 5:54 PM
    Full year of chemistry in high school, a couple semesters of inorganic chem in college. It was literally the only thing I enjoyed in college before taking 'a semester off'. College wasn't for me.
  20. Jan 6, 2023 at 1:14 PM
    #50
    HewittTech01
    Lexington, SC
    Well said and pardon I am late to the dance. As you will see plastered all over the forum and inter webs the SAIS is Failure Prone. There are a few advantages to installing the Bypass Kit as a preventative measure. First, there are certain SAIS error codes that will put the truck into Limp Mode, specifically "Valve Stuck Open" fault codes P2440 2442. When the truck goes into Limp Mode your performance and acceleration will be governed and luck to get up to 35 MPH. This would be terrible if you take long trips with your truck, travel off road or regularly tow. Second, if the truck is driven for long duration or you repeatedly clear the codes this expose the Pressure Sensor Inside the Air Switching Valve to exhaust. Exhaust can damage the Pressure Sensor. The Bypass Kit require the Pressure Sensor to be in good working condition to operate as engineered. In the event of Pressure Sensor damage then Addons to the Bypass Kit will be needed to clear codes.
    So you can wait to the SAIS components fail and install the Bypass Kit. Or save your self some trouble and install proactively. Below I have included a few thread we posted about the SAIS and our Bypass Kit. Do not hesitate to contact us if you have any questions.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
    G_unit3000, JasonC., EvilOne and 2 others like this.
  21. Sep 7, 2023 at 12:43 PM
    #51
    liltex
    liltex New Member
    2005 Tundra 4.7 Access cab with P0418 and P2445 codes that can be cleared and OBD2 reader.
    Have had vacuum noise for months now but finally thrown into limp mode for the first time this last week.
    The Hewitt Gen 2 kit specifically addresses both the P2445 and P0418 codes.
    Specifically, I am asking about the P0428 code for other kits.
    MY QUESTION -
    Anyone installed either RUtech or Slyfox bypass kits?
    Did you encounter the P0418 code and did either of these kits keep this code from popping up and putting truck in limp mode?
    Trying to choose a kit; no concerns re:emission inspection or needing to start the truck within 10 sec. of turning key.
    THANKS!
  22. Sep 7, 2023 at 1:44 PM
    #52
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Is it 428 a typo or is it 418….:confused:
  23. Sep 7, 2023 at 7:35 PM
    #53
    liltex
    liltex New Member
    P0418 – SAIS Circuit/Relay ‘A’ Circuit Malfunction Bank 1
    My apologies
    BubbaW likes this.
  24. Sep 8, 2023 at 3:51 AM
    #54
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Have no input on any of the kits mentioned but here's one about Rutech with a number of member comments concerning Slyfox
    Air injection pump bypass kits: Hewett vs. Rutech
  25. Sep 8, 2023 at 8:15 AM
    #55
    HewittTech01
    Lexington, SC
    @liltex Obviously we are a little biased but hopefully your research will bring you to Hewitt Tech Bypass Kit. The other kits will not address the P0418 since it is an electrical SAIS fault code. If you go with the Gen 1 (V36H) and Pump Proxy Pack addon it will address the issue. If you have any question do not hesitate to contact us.
    Gen 1 $190 $155
    - Our V36H kit will prevent the SAIS from operating on a cold start and ECM will read as Not Ready/Incomplete. With this unit, all of the SAIS parts/components will need to remain in place for the computer to see continuity on them. Installs at Mass Air Flow sensor and Engine Coolant Temperature sensor. Also, the starter relay wire will need to be ran from the bypass module to a terminal inside the fuse box.
    + Covers only mechanical SAIS error codes*
    *Kit Addons needed for each the following codes
    P0418 - Needs Pump Proxy Pack ($155)
    P0419 - Needs Pump Proxy Pack ($155)
    P0412 - Needs Valve Solenoid Pack ($75)
    P0415 - Needs Valve Solenoid Pack ($75)
    Kit Addon
    Pump Proxy Pack $155
    Please let us know if you have any questions,
    2006Tundra, HBTundra and Leo's first like this.
  26. Apr 19, 2024 at 3:01 PM
    #56
  27. May 8, 2024 at 1:23 PM
    #57
    Sand-man
    Sand-man New Member
    Sanders
    2007 SR5 5.7L 4x4
    When you say limp mode, are you saying the motor just idles and you got no response when pressing on the gas pedal? I'm experiencing this now with my 07 Tundra 5.7L. If I come to a complete stop then press on the gas pedal she will take off for a couple seconds then right back to limp mode, over and over and over again. At first it seemed like it was only happening after a sharp left turn, not really sure if that's still the case because I'm totally baffled at what it's doing and how to fix it. I'm pretty mechanical but have never had a vehicle do this in my 47 yrs of driving.
  28. May 8, 2024 at 2:02 PM
    #58
    Leo's first
    Groton ma
    Do you have a cel or other lights lights on?
    Also Wandering-boy has a 1st gen tundra on our 2nd gens once it goes into limp
    you have to clear the codes with a scanner or disconnect the battery to get it out of limp mode
  29. May 8, 2024 at 3:17 PM
    #59
    Sand-man
    Sand-man New Member
    Sanders
    2007 SR5 5.7L 4x4
    No lights are on. The only time any lights are on is when I turn the ignition on, one it's started all the lights go out. All this started after replacing the left rear axle bearing and axle with a NAPA aftermarket assembly. I thought maybe that was the problem so I put the original back on to test that theory, no difference.
    Leo's first likes this.
  30. May 8, 2024 at 3:48 PM
    #60
    Sand-man
    Sand-man New Member
    Sanders
    2007 SR5 5.7L 4x4
    Actually, when I first installed the aftermarket assembly many lights lit up, except for the check engine light. VSC, ABS, 4Hi-4Lo, all 3 of these were flashing. Then I a did a zero point calibration and now none of these lights are lit up other than when I first turn on the ignition.
