What's a good yet inexpensive way to add lights to help see on dark twisty turns back country roads?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spielightdude, Oct 1, 2022.
  1. Oct 1, 2022 at 7:19 AM
    Spielightdude
    Spielightdude [OP] New Member
    Joseph
    2019 Tundra TRD off road and towing package
    Hi everyone,
    I have a 2019 sr5 extended cab with the TRS offroad package.
    I live out in a very woodsy area with a lot of dark backroads.
    On my way into work many a time I have had to slam on my brakes coming out of corners only to met with a deer and everything else under the sun.
    I am looking for advice and options on options for lighting that will help me see better and longer distance and off to thr sides.
    I am wondering if ditch lights or a behind the grill light bar would help?
    If a light bar itself is a better option I would want to keep it stealthy.
    Also I have the factory led headlights and fog lights.
    Also considering upgrading the factory fog lights. Is amber better in fog than white?
    I want to see better but also keep it kind of not so obvious when looking at the truck aside from ditch lights
    Any thoughts ideas or advice is greatly appreciated!
    I know there are a ton of options out there but also not looking to break the bank.
    Thanks everyone
  2. Oct 1, 2022 at 7:26 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Can't get much better than the factory LEDs. You could add additional lights, many have installed lights in hood bulge or other areas on the front of the truck.
    Check out the lighting forum here, I am sure it will give you some good ideas. Many of the posts will list parts, pics, install, etc.
    WFD473 and Taco-Spike like this.
  3. Oct 1, 2022 at 7:27 AM
    Taco-Spike
    Two Trucks
    Tons of light bar / pod options out there that can help on the cheap
    for deer, you’d probably want to go with white, you’ll be able to see their eyes from a distance. Mine has helped me driving to and from CO to TX and back several times
    amber is more for inclement weather, fog, dust, snow etc
    Sunnier and Spielightdude[OP] like this.
  4. Oct 1, 2022 at 7:31 AM
    Spielightdude
    Joseph
    Taco spike for replacing the factory led fog lights was considering going the amber route but for other options definitely staying with white.
    I deal with a lot of fog in the fall and spring here.
    Taco-Spike likes this.
  5. Oct 1, 2022 at 7:32 AM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    I upgraded to amber Diode Dynamics Sport fog lights & I highly recommend them. I also live in the mountains that are full of critters/deer. They just make night driving easier & less stressful for my aging eyes.
  6. Oct 1, 2022 at 7:33 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Cheap and easy = ditch lights
    When properly placed, which is off to the corner, they actually help you see where you are turning into.
    A light bar might end up blinding someone coming towards you.
  7. Oct 1, 2022 at 7:36 AM
    Spielightdude
    Joseph
    I definitely want to avoid blinding anyone, I deal with a lot of that with trucks around here.
  8. Oct 1, 2022 at 7:38 AM
    Sunnier
    Sunny
    San Diego, CA
    Taco-spike is not wrong. The “amber” lights don’t seem to highlight the “amber” coats and eyes of wild creatures as early as bright whites. BUT depending on where you live, it’s less-attention-drawing to replace your OEM ambers in the OEM housing. Baja Designs has an amber that’s more bright yellow, very bright, and it’s what I’d install in the same place of the OEM fog lights if I were in your situation.
    A less-expensive supplier for bright white lights, veteran owned and made in the USA, with a comparable warranty to BD is Black Oak. If you can tolerate adding small metal mounts in front of your A pillers, several fabricators make them for our trucks that sit close over the back edge of the hood— you’ll get used to them, and you can mount effective lighting.
    Edit: I just saw @Cruzer beat me to this. The lights/ location I mean, are also called “ditch lights”.
  9. Oct 1, 2022 at 7:44 AM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    I put in DD SS3 Max for driving the gback roads and love them.
    Summoning @memario1214
  10. Oct 1, 2022 at 7:46 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ditch lights aimed down and out for you know actual ditches where those pesky deer like to hide out biding their time for road kill suicide. I use low profile white light (2600 lumens per pod). It'll get er done.
    Get some powder coated hood mounts and you're golden.
  11. Oct 1, 2022 at 7:47 AM
    Spielightdude
    Joseph
    I like the idea of amber fog lights and have look at and like the idea of ditch lights. The question is spot or flood or combo for ditch lights.
    Was looking at Rago fabrication for mounts for ditch lights?
    Looking at the stobes n more side shooters?
    They are a local company with awesome warrantees.
  12. Oct 1, 2022 at 8:07 AM
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    Another vote for the Diode Dynamics fogs. I have the SS3 sport version of the factory replacement fogs in amber and they are amazing.
    nobodyintexas likes this.
  13. Oct 1, 2022 at 9:13 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Baja Designs Squadron Sport/yellow lens half clear half reflected.
    Makes me smile every time I have them on, beasts. No one has ever flashed me.
    Sunnier likes this.
  14. Oct 1, 2022 at 9:32 AM
    Sunnier
    Sunny
    San Diego, CA
    <insert New Orleans Mardi Gras beads pic here>
    Sumo91 likes this.
