Welcome to Tundras.com!
Quick Links:Would you do it ?
Resurrection from the deep, starting problems.
Thoughts on Rear Suspension Rubber Helper Spring Kit
Smoke at startup, valve guide seals? Replace without removing heads?
What is the best place to buy a timing belt/water pump kit that contains OEM Toyota parts
How to fix my cut out stock radio harness
Secondary air injection pump and valves
Discussion in '1st Gen Tundras (2000-2006)' started by JessiJane06Tundra, Oct 27, 2018.
