1000 miles and in a rental
Discussion in '2.5 Gen Tundras (2014-2021)' started by dhdubey88, Jul 8, 2017.
  1. Jul 8, 2017 at 12:06 PM
    dhdubey88
    dhdubey88 [OP] New Member
    Roseville
    2017 SR5 crew max
    Flowmaster 40 series muffler Headache rack/tonneau cover Bilstein 6112 at top notch Bilstein 5160 Coachbuilder +2 shackle Rear diff breather relocate Coachbuilder bumper shims Lower control arm skid trim Oedro bolt on sliders Raceline injector 18” wheels 35x12.5x18 toyo RT
    Got my brand new 2017 5.7 crewmax and love it but after about 800 miles it stared to make a bad sound on cold start up that only last a few seconds. I dropped it off at Toyota on Thursday night so they would be able to check it out on cold start. Weren't able to find out what it was over the corse of Friday but heard the noise. I currently have a rental Camry from them. They were telling me when I talked to them this am that they may have to call toyota t get help from the TASK team. Just thought I would share in case anyone else has had something similar happen. Tried to attach video showing sound but isn't letting me upload.
    FlashCulprit and Y0TA PR0 like this.
  2. Jul 8, 2017 at 2:22 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Have to upload to YouTube then share link on here.
    What kind of bad sound? Someone may be able to chime in.... @LOTSOFTOYS
    Backslider and FlashCulprit like this.
  3. Jul 8, 2017 at 3:16 PM
    dhdubey88
    Roseville
    2017 SR5 crew max
    I'll have to set up a you tube account to load it up. The best I can describe it now is a rattle/knock for a few seconds then goes away and everything sounds normal
    FlashCulprit likes this.
  4. Jul 8, 2017 at 3:24 PM
    dhdubey88
    Roseville
    2017 SR5 crew max
  5. Jul 8, 2017 at 4:08 PM
    MikeyMTBs
    MikeyMTBs New Member
    Sure doesn't sound good...
    Achuop likes this.
  6. Jul 8, 2017 at 4:16 PM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    Does the sound only happen at start up?
  7. Jul 8, 2017 at 4:53 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Odd that it hasn't thrown any codes. Sounds like it would have.
    Hoping the dealership can figure it out!
  8. Jul 8, 2017 at 5:30 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    That's definitely not normal
  9. Jul 8, 2017 at 5:38 PM
    Cement Pro
    Stock
    The dealer will figure it out I guess.
  10. Jul 8, 2017 at 5:43 PM
    too tall
    too tall New Member
    I swear it sounds like octane knock
  11. Jul 8, 2017 at 6:11 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Sounds a little like piston slap.
  12. Jul 8, 2017 at 6:15 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Ouch! Whatever that is it isn't normal. Hope they figure it out and correct the problem for you.
    dhdubey88[OP] likes this.
  13. Jul 8, 2017 at 7:07 PM
    allybear21
    allybear21 New Member
    Walker
    2017 Toyota Tundra 1794 Barcelona Red
    I had an issue similar to this in my 2012 Tundra. It had something to do with the engine thinking I was putting is E85 fuel. They flashed some new codes that finally fixed the issue. Mine only did it in cold weather. Toyota corporate was very good. They even sent their own tech from California to Georgia to help the dealer.
    After about three attempts, they finally got the issue fixed and I didn't have another issue while I owned that truck. It had over 200,000 miles when I traded it in for a 2017.
    ColoradoTJ and Patriot like this.
  14. Jul 9, 2017 at 9:03 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Only on cold start up. If I turn it off then back on immediately after cold start up It doesn't do the noise again.
  15. Jul 9, 2017 at 9:04 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Yup. No codes just odd noise at cold start up then runs fine.
    Me too
  16. Jul 9, 2017 at 9:05 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    I've only put 91 in it
  17. Jul 9, 2017 at 9:06 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    That's what I thought from looking around on here but the guys at the dealership seemed puzzled by it.
  18. Jul 9, 2017 at 9:09 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Did you have the flex fuel engine? That is good to hear that your issue was resolved and your tundra got a good 200k.
  19. Jul 9, 2017 at 9:49 AM
    allybear21
    Walker
    Yes, mine was a flex fuel truck. I never put a drop of E85 in it, but for some reason if the temperature got below 40 degrees, the engine would think it was starting with E85. Only happened on first start of the day and would go away. Toyota tried several different computer flashes and they would work for a couple weeks and then do it again. The last flash they did worked for the remaining life of my ownership. Toyota corporate was great to work with. Very helpful and performed everything fast. I noticed the last time they flashed it, the truck had a sound once you turned it off. Not a bad sound but one that sounded like the fuel pump was doing something. My new 2017 has the same sound of a pump running for a second after you shut off.
  20. Jul 9, 2017 at 10:01 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Mine is not the flex fuel but it does have that same sound at shutoff. Sounds like it comes from over by the glovebox area. Hopefully I will have as good of an expierience as you did with the fix.
  21. Jul 9, 2017 at 10:08 AM
    allybear21
    Walker
    Yours sounds different than mine. Mine sounded like you were starting up a 57 Chevy and smoke would come out the pipes. Either way, it's probably some type of computer flash that they will figure out.
    dhdubey88[QUOTED][OP] likes this.
  22. Jul 12, 2017 at 10:08 PM
    dhdubey88
    Roseville
    2017 SR5 crew max
    I received a call from the service manager where my truck is (Roseville toyota) this morning after calling toyota directly yesterday. He believes my issue to be the vvti gear and is going to Change it out. I will update more as I hear from them.
  23. Jul 12, 2017 at 10:28 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    The sound the all make at shut down is the aip totally normal. Mine has a noise during warm up that kinda sounds like that but not nearly as nasty and it takes a while to go away. Going to have to get it out.
    Midnighttaco08 likes this.
  24. Jul 15, 2017 at 9:28 AM
    dhdubey88
    Roseville
    2017 SR5 crew max
    I picked up my tundra today! I am very happy to have it back! They replaced the vvti gear on Thursday, had to wait for Friday morning to do a cold start to verify if noise was gone and wanted me to plan on picking it up today (Saturday) so they could verify noise was gone on two cold start ups. Had a hickup with the local dealer but was quickly resolved after talking with the service manager. After having a rental Camry and 4Runner I am very pleased to have the space and power back that I paid for. I will still be keeping a close ear out in the mornings to see if the noise comes back.
  25. Jul 15, 2017 at 10:08 AM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Glad you got the problem resolved!
  26. Jul 15, 2017 at 10:36 AM
    TheBeast
    TheBeast The Beach
    good it worked out
  27. Jul 15, 2017 at 10:57 AM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    The sound from the glove box area is normal. It's the air injection pump.
    Just playing devils advocate here... if the VVTI was causing it... any thought the noise was caused by piston slap since the vvti was keeping the valves open too long? If so, was everything replaced in the valvetrain that could have been damaged?
    I'd be asking for an extended warranty at the cost of Toyota, personally, to make sure the aftermath doesn't show down the road...
    Joeshaker likes this.
  28. Jul 15, 2017 at 12:23 PM
    dhdubey88
    Roseville
    2017 SR5 crew max
    Thy gave me a detailed explanation about it and it seemed pretty sound from how they explained it and my friend that used to teach at UTI. But something I could still try to get toyota to take care of. I am working a trd pro grill into the deal with local dealer due to the communication that was lacking on their end.
  29. Jul 15, 2017 at 1:03 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    Go for the warranty... the pro grill can be installed at your leisure. But breaking down in 3 years because of this can't...
    Anyway, :cheers: To getting free shit
