1445 code on my 2005 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by garbageman, Sep 18, 2022.
  1. Sep 18, 2022 at 3:12 PM
    garbageman
    garbageman [OP] New Member
    jj
    2005 tundra
    none
    this sounds really bad and expense
  2. Sep 18, 2022 at 3:48 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    Probably a Secondary Air Injection System component failure.
    Bypassing the system is the cheapest and easy option.
    https://hewitt-tech.com/product-category/bypass-kit/gen-1-secondary-air-injection-bypass-kits/
    SAIS Failure and Trouble Codes
    Any Secondary Air Injection System component failure generally sets the check engine light (CEL) and causes the Engine Control Module (ECM) to store trouble codes. You will know a failing air pump is the problem when you hear a loud vacuum cleaner noise for 20-30 seconds after a cold start. Most of these mechanical failures also cause the vehicle to enter “limp mode”, which is when throttle response is limited to 50% to protect the engine from damage.
    https://hewitt-tech.com/codes/
    HewittTech01 likes this.
  3. Sep 18, 2022 at 4:48 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Signs Up.
    Creates a User Name.
    Posts an SOS.
    Info Dump from the Inmates.
    Never To Be Seen Again.
    Grumpy74, FirstGenVol and des2mtn like this.
  4. Sep 18, 2022 at 6:00 PM
    shifty` All my rowdy friends have settled down
    I suspect you're right, and it really gets my goat too. Too many fly-by-nighters. I'd rather have the reputation of helping vs. being uninviting though. Blame my upbringing, it's how I was raised. It's hard to fight my cynicism sometimes, but ... "bigger picture" et al.
    I'm curious if @garbageman hears any whistling or high-pitch whine noises at startup. I swear the Hewitt Tech bypass kit warns you about getting the switching valves in the correct position, but I don't recall the process to get them there. It may be possible to follow a process to try to reset the valves.
    But yeah, bypass is the cheap solution. Replace SAIS is the more-permanent solution if you're willing to spend $600-1200 depending on who does the work.
  5. Sep 19, 2022 at 4:23 PM
    growit
    growit New Member
    2006 Dbcb SR5
    I used the Hewitt bypass years ago on my 2006 dbcb, still working great.
    HewittTech01 and Leo's first like this.
  6. Sep 28, 2022 at 7:41 AM
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    Thanks to all who recommended or endorsed the The Hewitt Tech SAIS Bypass Kit. If you have any unanswered questions please do not hesitate to contact us, we are here to help. I have included a few links below to recently posted threads.
