DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Sep 27, 2022 at 9:51 PM
    #2341
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Those tires look good. Waiting for availability for 17's cause I want to give them a try. I'm tired of MT's lol
  2. Sep 27, 2022 at 10:05 PM
    #2342
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Anyone running 0mm offset figure out a good way to clearance the rear wheel wells when stuffed?
    I’ve rolled the inner lip up as far as I can, but when stuffed I’m slicing up the sidewalls and lugs.
    Best two examples I grabbed from a video:
    9430915B-C86E-454E-9DA7-44128811F43D.jpg ECF22AE9-C990-4908-B768-3D5C0F2DC09E.jpg
  3. Sep 28, 2022 at 4:56 AM
    #2343
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep Adv glass lol
  4. Sep 28, 2022 at 5:39 AM
    #2344
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Are these the 11.5” wide ones?
    Edit: they look great btw!
  5. Sep 28, 2022 at 6:51 AM
    #2345
    eccracer104
    San Diego, CA
    Shit. Lol
    Kiddnapped Tundra, SAGE63 and des2mtn like this.
  6. Sep 28, 2022 at 7:12 AM
    #2346
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL just let it happen it'll only hurt once.
  7. Sep 28, 2022 at 10:15 AM
    #2347
    Deaner713
    Deaner713 New Member
    2015 Tundra 5.7L CM SR5 4x4 MGM
    I like them so far, a very subtle howl but not as near as other tires. I had Duratracs and those were louder. Slightly less aggressive to the Ridge Grapplers but these have a 55K warranty which is nice. Also the weight is 9lbs lighter than the Ridges at 74lbs
    these are 12.5", slightly skinny looking imo but i think 37s can have that effect
    BlackSheep[QUOTED] likes this.
  8. Sep 28, 2022 at 10:55 AM
    #2348
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You should be able to get 6*+ on SPC with setting A.
    EvoTundra likes this.
  9. Sep 28, 2022 at 11:38 AM
    #2349
    Deaner713
    That's actually crazy to me. Mine are set to A with the SPC logos face the front of the truck and we could only squeeze +4 caster. Maybe I have to do Camber last? As in dial the caster first then adjust camber on the top?
  10. Sep 28, 2022 at 11:52 AM
    #2350
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    My alignment guy pushed caster as far forward as possible, then moved it back, then adjusted camber then toe from what I remembered.
    reywcms likes this.
  11. Sep 29, 2022 at 7:56 AM
    #2351
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What's the ideal width of rim for a 37? I see the sizes vary from tire to tire but more common is a 13.50 so I'm thinking a rim with at least 10" width would make the tire look more filled out.
    I had 20x10s but it isn't very easy to find a good looking non-black 18x10. I don't want a marshmallow look but I like a wider tire profile.
  12. Sep 29, 2022 at 8:55 AM
    #2352
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Always set: Caster->Camber->Toe
    KevinK likes this.
  13. Sep 29, 2022 at 9:02 AM
    #2353
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    There are many variables at play here. Actual tread width...Shoulder lugs...etc
    37x13.5r18 Toyo RT on 18x9 wheel
    37x12.5r17 Toyo RT on 17x8.5 wheel
    Side by side
  14. Sep 29, 2022 at 9:20 AM
    #2354
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    It’s weight reduction. :thumbsup:
    Ours do the same a little bit. Eventually it stops when enough weight has been removed. It also depends on the shoulder profile of the tire and bump stop limits.
  15. Sep 29, 2022 at 9:48 AM
    #2355
    SAGE63
    San Diego County
    Time to dump the c4 bumper and winch
    ... not.
  16. Sep 29, 2022 at 8:04 PM
    #2356
    Yzed608
    Yzed608 New Member
    Wisconsin
    Maybe it's just the angle, but the rear tire looks like it has some camber to it.
  17. Sep 29, 2022 at 8:15 PM
    #2357
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Maybe see if you can pull the beside an inch or so. I haven't looked under my Tundra to see how easy it would be but I did it on most trucks back in the 90s/00s. Heres a period correct video showing the basic idea. LoL.
    https://youtu.be/bp95_ek9_dc
  18. Sep 29, 2022 at 8:39 PM
    #2358
    eccracer104
    San Diego, CA
    Haha I’ve seriously thought about that. I’ve read somewhere someone did that with a double cab standard bed and then later said “I don’t think it would work on the short bed” but perhaps I need to investigate further lol
    BroTun13[QUOTED] likes this.
  19. Oct 3, 2022 at 11:37 AM
    #2359
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    Ive been a long time stalker of this page and have dreamed of Joining the club. Permission granted????
    Finally got the (36.7) Ridge Grappler 37s installed.
    2011 tundee with 180k miles.
    Black Rhino 20x10 w/ zero offset.
    6" procomp II lift.
    Planning to finnally swap out the procomp lift spacers pro comp shocks for full coil over! Thinking about the RC vertex for front and rear, holler if i should stay away.
    You guys are killing it out there with these setups, will be diving into more research for rear leaf springs soon.
    Hightide, B.Ross, Berdine and 8 others like this.
  20. Oct 3, 2022 at 11:38 AM
    #2360
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Looks great!
  21. Oct 3, 2022 at 7:44 PM
    #2361
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    I've got a similar setup and dream of the day when I can ditch the spacers on my Pro comp 6"...alas other projects take priority. Those vertex coilovers seem quite a bit more affordable than the Bilsteins if I remember correctly. Really interested in how they turn out for you.
  22. Oct 15, 2022 at 5:42 PM
    #2362
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    I replaced my SCS Ray 10's and Nitto ridge grapplers in 37x11.50r18 with some Black Rhino Rapids and Kanati Mud Hogs in 37x12.50r17. The new wheels and tires are about 10 pounds lighter per corner.
    Deaner, Hightide, J&ATundra and 16 others like this.
  23. Oct 15, 2022 at 6:22 PM
    #2363
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Big fan of Kanati tires. How do you like em? I'll probably go with these when I'm ready for 37s (next tire buy)
  24. Oct 15, 2022 at 6:35 PM
    #2364
    STravis
    Travis
    Ruidoso, NM
    So far so good. I just got them put on yesterday evening. We put about 300 highway miles on them today and they did fine. I'll post back after I get some dirt on them.
  25. Oct 15, 2022 at 6:37 PM
    #2365
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The width must help with the lighter weight. They're definitely a thinner profile
  26. Oct 15, 2022 at 6:38 PM
    #2366
    STravis
    Travis
    Ruidoso, NM
    The tires they replaced were actually 11.50 wide and these are 12.50. But the lighter combo will definitely be nice.
    texasrho83[QUOTED] and Shanet421 like this.
  27. Oct 15, 2022 at 6:44 PM
    #2367
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I guess I'm used to seeing 13.50 widths for 37s
  28. Oct 15, 2022 at 7:10 PM
    #2368
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Looks awesome!
  29. Oct 15, 2022 at 7:25 PM
    #2369
    STravis
    Travis
    Ruidoso, NM
    I've always liked tall skinny tires. 12.50 isn't particularly narrow, but it looks narrow on a 37.
  30. Oct 15, 2022 at 7:26 PM
    #2370
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Remember the Kelly Springfields?
