2011 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by RHickman, Sep 25, 2022.
  1. Sep 25, 2022 at 11:49 AM
    RHickman
    RHickman [OP] New Member
    Randy
    Indiana
    2005 Tundra
    Looking at a 2011 Tundra with 165,000 miles. I’ve got a 2005 now. Anything I should be looking for on a 2nd gen?
  2. Sep 25, 2022 at 3:17 PM
    mike diamond
    mike diamond New Member
    Michael
    2007 toyotaTundraLimited
    20 inch wheels
    No rust and good paint $16,500
  3. Sep 25, 2022 at 3:56 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Indiana? Rust on the rear half of the truck, particularly the bed (before and behind the wheel wells on the floor), bed crossmembers, frame crossmembers, and frame as it swoops up over the rear axle behind the cab. Rusted brake lines.
    Vacuum noises on startup? Signs the air injection system about to take a dump.
    Leaking water pump.
    Check to make sure the 4wd works and shifts, can be tempermental at first if not used recently.
    Check to make sure the check engine light works, turn key to ON for a dash bulb check. Look for check engine light to illuminate.
    Check door gaps and different shades of paint on different panels to see if its been wrecked or been to a body shop.
    Check coolant and oil when its cold before you start it. Then listen carefully for weird noises on a cold startup. Then let it idle and run the whole time you look at it with the AC on to make sure it works when warmed up, the heat works, and the engine doesnt overheat at an idle. Stomp on the gas during test drive once the transmission is warmed up to see if it slips. Check all the windows, door locks, HVAC modes, lights to make sure they work.
    Buy one from an old man if possible. :rofl:
    baraynavab and 07DCLimited like this.
  4. Sep 25, 2022 at 5:28 PM
    RHickman
    Randy
    Indiana
    2005 Tundra
    Large crew cab, sr5 w/towing packsge
  5. Sep 26, 2022 at 2:47 AM
    RHickman
    Randy
    Indiana
    2005 Tundra
  6. Sep 26, 2022 at 6:49 PM
    RHickman
    Randy
    Indiana
    2005 Tundra
    Ended up buying the 2011, thanks for all your help
