So many AR-15,wow
Discussion in 'Guns & Hunting' started by pursuit2550, Sep 1, 2022.
  1. Sep 1, 2022 at 5:43 PM
    pursuit2550
    pursuit2550 [OP] New Member
    So I already own 1 AR. It was my first and its fine but want something from a manuf. Mine is a built AR, nothing fancy. DPMS lower+upper, Wylde barrel, Magpul accessories and a Vortex Venom Red Dot. I was looking at spending less than 2k OTD. I have looked at the Saint Victor and Edge. I was currently looking at the FN Tac3. I have also looked at soooo many others that its mind draining. It will be just for fun. Typical range days, that's all. Considering I hardly make it the range, I was also thinking of something cheaper. I have a .22 conversion that I am going to install on my current AR and start showing my son & daughter to shoot. So I want another one just for me.
  2. Sep 1, 2022 at 5:54 PM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    LWRC
    LMT
    Daniel Defense
    Noveske
    Bravo Co.
    Not necessarily in that order. Also buy a couple extra parts kits in case they ever pass a ban.
  3. Sep 1, 2022 at 7:45 PM
    JimBeam
    JimBeam Moderator Staff Member
    2015 Limited
    $2k will get you a lot of gun and red dot
    you can easily get into a basic Daniel Defense, FN, Colt, Sons of Liberty, and many others
  4. Sep 1, 2022 at 8:26 PM
    Dirtnap
    Dirtnap New Member
    2021 Tundra TRD Pro Lunar Rock
    You can’t go wrong with a BCM or LWRC. Picked up a LWRC di and it has been quality
  5. Sep 1, 2022 at 8:44 PM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Palmetto State Armory for an inexpensive range toy. Or S&w M&P tactical. I generally spend under 1k on my range toys because I could not fully exploit the capabilities 2k-plus rifle, but would spend more if I get to a point where I could make the most of it. Use the difference and buy parts and ammo. In this environment I am focused on accumulating parts and large cap magazines for my most frequently shot platforms. I have a few ARs. Then I picked up cheap spare complete lowers. Then I started buying cheap lower parts kits and bolts and bolt rebuild kids and such. Once you get number 2 start planning on having everything you need to feed and maintain it through a shortage. My stash is set up with enough spare parts redundancy so every gun can always keep running through parts breakage and so if any gun goes down I know somewhere in there I have the part to fix it myself or give to a gunsmith to install without ordering anything.
  6. Sep 1, 2022 at 8:51 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Mr. Beam :hattip:
    Ready to part w/that 18 EC yet??? :cool:
  7. Sep 2, 2022 at 3:30 AM
    pursuit2550
    I have looked at a couple of those and it’s over $2k. And to top it off most, if not a lot of the gun shops here don’t carry them.
    FREEDOMcomesatacost likes this.
  8. Sep 2, 2022 at 3:41 AM
    pursuit2550
    I was also thinking of going with. $1 and under AR spending the rest on parts and bullets. I don’t really go shooting a lot or do any type of shooting that would require a high end AR.
  9. Sep 2, 2022 at 5:02 AM
    JimBeam
    2015 Limited
    nope!
  10. Sep 2, 2022 at 5:12 AM
    JimBeam
    2015 Limited
    From QC to potential failures to shootability of the gun
    there is a huge difference between most $600 guns and most $1500 guns
    all of my guns except a couple handguns are range toys but I still want to reduce failures and have a good quality rifle that doesn’t cause me to spend more money over the life of the gun or every other range trip because either something failed or there’s a better replacement part
    I’m not saying go drop $$$$ stupid money on a boutique rifle, but get something that doesn’t need immediate change in parts…you’ll nickel and dime yourself out of way more money over the years that way
  11. Sep 3, 2022 at 5:34 AM
    eharri3
    eharri3 New Member
    Generally if you get a bcg with good staking on the gas key, staked castle nut and a bolt with the right specs you are going to be good with an occasional range plinker even if it isn’t a 1500 dollar gun. Every failure with a low cost low round count AR I have experienced related to a castle nut backing out or a gas key coming loose. Close 3rd is cycling issues because of the crap extractor springs Used in most cheap bolts. 4th is gas tube coming lose so look for a barrel dimpled for the gas block or maybe pinned. Also easy to dimple yourself later.
    Even the cheapest PSA lowers I have bought come with a staked castle nut. Now I just buy them, slap a decent upper with a good bolt on it, upgrade the extractor spring if need be and end up with a moderate round count range beater AR that will run like a top for 6-700 bucks.
  12. Sep 3, 2022 at 5:44 AM
    Hanzo
    Hanzo New Member
  13. Sep 15, 2022 at 6:57 PM
    1*MEDIC
    1*MEDIC New Member
    BCM and FN are GTG for the money , I’ve put thousands of rounds “some 855a1” though a BCM upper with very little maintenance and it’s never malfunctioned. As far as the tier 1 stuff, KAC, LMT and Noveske they are nice but expensive. I’ve owned a KAC and still have a few LMT’s and a few Noveske’s. LMT’s are my favorite due to the barrel design and lower. KAC has a better bolt, LMT has a better upper/barrel and lower design IMO. Noveske is an amazing barrel manufacturer that assembles a good rifle, not a lot of innovation with the Noveske’s.
  14. Sep 15, 2022 at 7:01 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I agree, and lean to the BCM uppers.
  15. Sep 15, 2022 at 8:03 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Last I looked, the price of ammo said I wasn't gettin another AR platform. What's a case of 5.56 going for these days??
  16. Sep 26, 2022 at 2:24 PM
    FREEDOMcomesatacost
    FREEDOMcomesatacost Go ahead, pull my finger…
    Just call me Easy
    Louisiana
    2022 SR5 Crewmax supersonic red
    Too much to list…
    Case, I don’t need no stinking case…….:cool:
    (For those that don’t know it’s a drum of 5.56 aka 14k rounds of FREEDOM)(if you have to ask why so many you won’t understand)
  17. Sep 26, 2022 at 2:59 PM
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Some People aren’t going to like what I am about to say but In my years of experience using M16a1 to multiple brand M4’s, from gas to piston, etc etc. so many things to compare on them, but bottom line is they all go BANG! Yes you can spend $500 or $3k on them, but it all comes down to your choice and use for it (SHTF, zombies (that’s right they coming eventually), competition, home defense (some do), etc etc). Pick it up, handle it, do your research/reviews on it. I have $500 (Diamondback/Core/etc) AR’s that shot almost as well as my more expensive ones $2k plus (LWRC/H&K/SCAR/etc). Buy what you like and can afford it will do it’s job when the time comes. Have owned and still own many and have yet to have any just not go BANG or do it’s job. This is from my personal experience only. If you only prefer certain ones that is your choice. I always say, to each his own……ok one pic of some of them….:D
  18. Sep 26, 2022 at 3:07 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Whats it look like on the inside? Just loose rounds or a ton of boxes?
  19. Sep 26, 2022 at 3:08 PM
    Junior 88
    Junior 88 New Member
    Junior
    18 tundra Sr5
    7inch bds on 35s
    I love my core-30
  20. Sep 26, 2022 at 3:14 PM
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Just 14k loose rounds. No boxes or wrapping etc. Funny thing is I saw these at all places at an local Academy like 8 or so years ago for like $4k and was like no way. If i only knew, would of bought 3-4 of them. You CANNOT find these right now and they go for $14k no BS Google “Winchester 5.56 M193 drum”. I had two but traded one for something. You can’t even move it with 3-4 grown men. We had to use a forklift!! When the truck delivered them (was a special delivery) it came with a forklift attached to the back of the delivery truck. I have a friend who owns a gun store and he has been looking for me for the last two years and got the call a few months ago he found 2 and if I wanted them. He had to take all kinds of extra crap from the vendor to get em but that’s what friends do for other friends!! :rofl:
    (I’m a good friend too as I bought a lot of the extra stuff too!!)
  21. Sep 26, 2022 at 3:28 PM
    Danimal86
    Daniel
    Sacramento, CA
    Wow! Thats nuts!
    Cant believe its still $1/rd for 556.
  22. Sep 26, 2022 at 3:34 PM
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    You can find them cheaper, but for some reason these drums demand full price. Guess they think if you’re buying 14k rounds you can afford full/high end pricing. :censored:
  23. Sep 26, 2022 at 5:16 PM
    Gene_in_FL
    FLORIDA
    Yeah, I can't justify that kind of money for 5.56. I'll help keep the cost down for you by not increasing the demand.
    MEWaters and FREEDOMcomesatacost like this.
  24. Sep 26, 2022 at 5:23 PM
    Tripleconpanna
    Looks like we all get a range day on this dude :cool:
    :infantry:
  25. Sep 26, 2022 at 5:26 PM
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    I have been wanting one of these drums for a while now so when my gun guy found a couple I couldn’t pass, plus most of his vendors been telling him they thought the drums were gone and won’t be made anymore. I do have plenty of much cheaper .223 & 5.56 rounds bought on the low low between $0.45 to $0.55 and not gonna show all. This probably too much showing as is:
    Tundra Dude 45 and MEWaters like this.
  26. Sep 26, 2022 at 5:27 PM
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Arent you gonna sing me sweet lullabies first and romance me???!!! ;)
  27. Sep 26, 2022 at 6:52 PM
    eharri3
    eharri3 New Member
    Yeah 556 can be weird, especially post COVId. I find that big bulk discounts aren’t that impressive over 20,30 or 50 round boxes. I can find individual boxes for 50-60 cents per round, haven’t really seen a lot of case-plus deals for much cheaper than that in awhile.
