Fall is here, winter is coming
Discussion in '2.5 Gen Tundras (2014-2021)' started by FrostyTundra22, Sep 26, 2022.
  1. Sep 26, 2022 at 5:54 AM
    FrostyTundra22
    FrostyTundra22 [OP] No longer new member
    2020 Toyota Tundra 1794 Crewmax
    My fellow Tundra enthusiast,
    I live up in the land of 10,000 lakes. As we get closer to winter, I want to be ready for it.
    This is my first time owning a pickup and I’ve always heard that pickup trucks are not heavy enough because of the bed, and you need to put some sand or heavy stuff back there.
    Are those things needed these days?
    For those of you who have dealt with snow, what are some of the things you do to stay safe, with and without the whole family?
  2. Sep 26, 2022 at 6:09 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Last year was my first year with a truck, or rear wheel drive, in winter. I've always had front wheel drive or all wheel drive and have always run snow tires. I don't keep anything in the bed and I feel the truck did great. Only a couple times during heavy snow did I put it in 4HI and when I did it was rock solid, other than that I was fine in 2WD.
  3. Sep 26, 2022 at 6:10 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Toss a couple bags of sand back there. You could use it for other things too
  4. Sep 26, 2022 at 6:40 AM
    PermaFrostTRD
    Northern NY
    If you're coming from an all-wheel-drive SUV, then I would put a little weight in the rear (2 90lb bags of sac-crete wrapped in some trash bags should suffice). If you're coming to a truck from a FWD/2WD then just drive the truck like you did the FWD. slow, long stops & starts. keep your distance. Use 4Hi as needed (try to avoid turns on dry pavement when in 4Hi). You can engage/disengage 4Hi from 2Hi all the way up to 60mph per the owners manual, but I wouldn't recommend doing that. I try to keep it below 40mph to engage. If you find yourself in an a hairy driving situation in the snow you probably shouldn't be running at 60mph anyway.
    3peak mountain snowflake rated all terrain tires are great if you want to have great snow performance in addition to the benefits of an all-terrain in both looks and performance. Or a set of dedicated winter tires is also not a bad choice. Take off steelies can be found for cheap to mount the winters on if you choose this route.
  5. Sep 26, 2022 at 7:46 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Like others have said, couple sandbags certainly don't hurt and you can always pull them out and dump them under a tire for a little extra traction if stuck. Decent tires make all the difference. I really only find myself in 4HI if the weather turns bad while I'm driving. Decently plowed roads or hard pack way up north and I'm usually still in 2WD. Also, have you considered having someone fluid film the underside of your truck/frame? Makes a world of a difference when the salt goes down.
    FrostyTundra22[OP] likes this.
  6. Sep 26, 2022 at 7:53 AM
    CTundraForMe
    CTundraForMe New Member
    To piggy back on what TundraMidwesterner said: if you live in a salt state, treat your truck to regularly undercarriage washes once the salt starts hitting the road. It's a cheaper solution than what you'll have to deal with if you let that salt stay on.
    (I had an '08 in PA .... )
  7. Sep 26, 2022 at 7:57 AM
    FrostyTundra22
    I was planning to do it myself but where are you at and who do you recommend?
  8. Sep 26, 2022 at 8:08 AM
    TundraMidwesterner
    Northern Illinois
    I'm at the edge of northern IL. I'm guessing you are farther north. Fluid film has an installer locator on their site but many more people do the installs since you have to pay to be listed as an installer. The guy that did mine pulled the plugs on the frame rails, dropped my skid plates, did various parts under the hood, fenders, doors, tailgate etc.
    https://www.fluid-film.com/undercoating-locator/
    Tundrastruck91 likes this.
  9. Sep 26, 2022 at 8:12 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Use 4wd if it’s treacherous, dont speed/drive like a dick when its slippery, woolwax your undercarriage, and make sure theres still meat left on your tires. A side note, I keep a couple space blankets, small shovel, yum-yum bars, and water in the truck during winter just incase.
    dondino, Wallygator, panicman and 4 others like this.
  10. Sep 26, 2022 at 8:21 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Snow tires or snow rated tires, use 4hi when needed, drive according to the conditions, give space to slow down and stop.
    Treat your undercarriage. I use Corrosion free DIY.
    Keep some tractions boards and a shovel handy. I also have a bag with recovery straps etc, but haven't had to use them.
    Always have gloves/mitts somewhere, for yourself or helping someone else out if they are stuck.
    Keep your portable battery booster charged. I use a NoCo (GB50). If you don't a portable booster, buy one.
    Don't let your fuel tank go under half full.
  11. Sep 26, 2022 at 9:31 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Lots of good advice here.
  12. Sep 26, 2022 at 9:39 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Bought a set of steel wagon wheels that were beat up for $50 on Facebook marketplace… cleaned them up and rattle canned them, put some Cooper snow tires. Between those and a couple 70lb sandbags over the rear axle, I’ve only needed the 4wd once in 3 years.
    Oh, I fluid filmed it and touch it up every year.
    But yea, tons of good advice here.
    WILLINH and BravoDeltaRomeo like this.
  13. Sep 26, 2022 at 10:39 AM
    Wahayes
    Will
    2017 tundra limited *sold*
    It's really not a big deal, if you have 4wd and good tires
    HulkSmurf14 and BravoDeltaRomeo like this.
  14. Sep 26, 2022 at 6:21 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Tires are the only thing touching the ground... don't skimp on them and you'll be just fine!
    RaginTxn and BravoDeltaRomeo like this.
  15. Sep 29, 2022 at 3:42 PM
    eagleguy
    eagleguy New Member
    Whole different story here in Fl.
  16. Sep 29, 2022 at 4:27 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Good a/t tires or snow tires, tundras are surprisingly decent in snow compare to others.
  17. Oct 3, 2022 at 11:00 AM
    MNdiver
    MNdiver New Member
    steve
    Up north Minnesota
    2020 tundra sr5 crewmax Black
    The tubes of sand they sell everywhere up here work good , fit between wheel well and tail gate. as mentioned by many snow tires will help immensely. 4WD will help you go but not stop, drive like me (old guy)
    WILLINH likes this.
  18. Oct 3, 2022 at 6:18 PM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    I keep a couple bags of kitty litter just in case I get stuck but 4wd should be all you need.
  19. Oct 3, 2022 at 6:56 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Sounds like Minnesota won’t allow use of studs that’s interesting. Stud-less tires like Blizzaks work well, used a set of 255/70r18 on my prior Tundra for 5 years/20k miles and 4runner. They do really well even decent on ice. The usual complaint for stud-less tires is they wear quicker than you’d expect, which is true. People practically give steel Tundra rims away for free so getting a set is easy. Snow tires are generally overkill for most situations but offer a level of insurance and control that is hard to let go of once you experience it. Just got some Nokian LT3 studded 315/70r17 I’m excited to try out.
    WILLINH and HulkSmurf14 like this.
  20. Oct 3, 2022 at 7:12 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Honestly, I’ve never really added weight. If the beds not covered and you get significant snow fall, there’s your weight
    the big thing people forget with trucks, while they get going better in the snow, they will stop WORSE than a car due to the weight
    BravoDeltaRomeo and MNdiver like this.
  21. Oct 3, 2022 at 7:22 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Winter tires! I have ran them every single winter since I was 18 no matter the vehicle and will continue to do so. They make a huge difference.
    coldcanuk, WILLINH and HulkSmurf14 like this.
  22. Oct 3, 2022 at 7:25 PM
    Yep. Lows in the low 30's and a breeze if we're lucky lol. I can't remember the last time Tampa was in the teens...it's been a few years.....damn global warming lol.
    WILLINH, Tundrastruck91 and Booney like this.
  23. Oct 4, 2022 at 3:17 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    Never needed 4WD when I lived in PA, DE, NJ even when I went snowboarding. Just threw some extra weight in the bed and go. When the first snow fall happens go out and play in an empty parking lot. Get to know your new truck and how she handles the Snow & Ice.
    TundraMidwesterner likes this.
  24. Oct 5, 2022 at 7:13 AM
    TundraMidwesterner
    Northern Illinois
    I second Tundra14platinum. Every first snow fall with any real accumulation I go out and find a safe space to accelerate hard and brake hard and do a couple hard turns at low speeds, learn how the truck will react in the snow and at what intensity it starts to be a problem or break loose. I'm not saying go and do donuts in the neighborhood cul-de-sac but an open empty parking lot with no poles and a few minutes can make all the difference in knowing how a new vehicle is going to react or re learning every winter . Just don't make it a ... crash course...
  25. Oct 5, 2022 at 7:24 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I agree, knowing your truck, even if you drive it everyday, in the different weather is important, as you may not remember that it was skidding 8 months back (unless you are where it snows 10 out of 12)
  26. Oct 5, 2022 at 8:23 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Yep, I do this with every vehicle the first winter with it. I remember the first time I had my wife do it she thought I was weird, she had fun and said she felt more comfortable knowing the limits after lol
    Tundra14Platinum likes this.
  27. Oct 5, 2022 at 10:05 AM
    Tmd_mn
    Tmd_mn New Member
    Welcome!! Also from MN.
    Good advice above with some additional weight in the back. I have resorted to the Water softener bags from Costco, as I need them anyways.
    Rear wheel drive for most of the time will be be fine if you take it easy, only issue I run across is the traction control is a bit touchy.
    Keeps going off when trying to accelerate from a stop at the traffic lights, so i briefly turn it off to get moving.
    Or switch to 4x4 to avoid angering the people behind me when they miss their light.
    Tires with good thread are ok, but dedicated winter tires are way better if you can afford them and have space for storage.
    I should have 1 season left on my tires and will use those rims for winter tires in the future.
    However nowadays I have all my ice fishing gear in the back so close to 200 lbs of weight there.
    RaginTxn likes this.
  28. Oct 5, 2022 at 10:16 AM
    Bammer
    Monroe, CT
    Got a set of 4 steelie yota rims, and Goodyear ultra grips and I am set as a jet !
  29. Oct 5, 2022 at 10:16 AM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    I’ve lived in NH my whole life and drive to northern Quebec as often as possible all winter to ride. 3 peak rated all terrains or dedicated winter tires, oil undercoating and a fresh coat of wax and send it.
    WILLINH, RaginTxn and Bammer like this.
  30. Oct 5, 2022 at 10:42 AM
    RaginTxn
    RaginTxn New Member
    Ya done messed up..
    Cypress, TX
    2018 SR5 X Series Tundra (sold) - why, why, why
    all excellent advice above - M2C - really a lot is just "common sense" - you're not on dry pavement so adjust driving for low traction environment - take your time. Too, the one thing about a RWD/4x4 truck is be easy on the pedal on turns (especially from a stop). After one season you'll be a pro. I drove a 2wd '01 tundra in eastern Idaho and never had a problem once I had proper tires and some weight in the back. IMO if you have good tires and some weight, you'll only need 4x4 if your off road or need to get out of a bind. I run with 2 tubes year around on my current truck and throw in 2 more in the winter - it feels better with 4-5 tubes (personally).
    Anywhoo - my list:
    • tires, tires, tires (3peak ATs good, snow specific better, studded - situational (arguably best)) - any of these are better than HTs
    • sand tubes (both for weight and if needed if you get in a bind)
    • long stops, slow starts, don't race
    • probably biggest thing is just knowing that unless you have metal inserted into your tires, all tires suck on ice (especially wet ice) - snow is your friend with 3 peak/snow tires (like driving on slightly slicker sand).
    • Keep gloves, blanket, flares, water in the truck, hand warmers (don't fill the water jug full incase it freezes) - general winter driving
    have fun in the winter playground!
