heating (but not over-heating) on hills in 6th gear all of a sudden
Discussion in '2nd Gen Tundras (2007-2013)' started by trpeters, Sep 25, 2022.
  1. Sep 25, 2022 at 3:49 PM
    trpeters
    trpeters [OP] New Member
    Trent
    2012 Black Tundra Limited Crewmax
    Hello, thanks in advance to anyone for help.
    I have a 2012 4x4 crewmax with 265k (bought it at 247k 3 years ago).
    Truck runs incredible, I had no records when I bought it, had a "pre-buy-inspection" which passed with flying colors.
    HISTORY:
    Truck has never had the engine temp move past "half way" (I will call it) on the engine temp gauge...this includes up mountains, around town, etc. Yesterday when going up hills the needle on the gauge went up to about 3/4 temp within 15 seconds of hill, and comes back down when going downhill within 15-20 seconds. Drove about 15 miles total.
    It has never leaked a drop of water or oil. Checked the radiator (cap looks good) when cold and I was able to put in 1.5 quarts fluid. Drove it again about 15 miles, and had the same results on the temp gauge. Parked, looked under the hood and looks like fluid is spitting out from expansion tank exit hose (expansion tank is empty, some coolant looks like it had blown out the hose with white residue). Radiator was again low, 1 quart filled it.
    Checked oil, its perfect / not milky and no smoke from exhaust (so thinking / hoping its not the head gasket). Drives great, no loss of power. Only does this at 70+ MPH, doesnt do it on hills in lower gears.
    QUESTION: I have looked around and know there could be many things, I am thinking thermostat can anyone give your $.02?
    Thanks a ton
    Trent in NC
  2. Sep 25, 2022 at 4:08 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Pull off radiator cap and post a picture of the rubber side here.
    07DCLimited and trpeters[OP] like this.
  3. Sep 25, 2022 at 4:12 PM
    18" TRD Off Road Wheels
    I'd flush the coolant and replace the thermostat. Easy and cheap to do. Replace the rad cap too.
    Has the radiator ever been replaced?
    trpeters[OP] likes this.
  4. Sep 25, 2022 at 5:26 PM
    trpeters
    Trent
    Thanks @GODZILLA - dont know if radiator has ever been replaced but it looks fairly knew / entire top of engine looks new as well. Agreed on "flush + new thermostat".
    Thanks @Half Assed, pic attached of the cap
  5. Sep 25, 2022 at 5:33 PM
    trpeters
    Trent
    pic attached
  6. Sep 25, 2022 at 5:38 PM
    timsp8
    NY
  7. Sep 25, 2022 at 5:55 PM
    Half Assed
    Heartland Florida
    Its possible the nipple on the bottom of the rad cap broke off and got sucked into system causing and overheating condition in part of the engine.
    It happened on mine. Got stuck in a small heater line where the upper rad hose goes into the engine. I was able to remove it by removing the upper rad hose. Lemme search and find the old post about it...
    Notice the difference between a new cap and yours:
    landphil likes this.
  8. Sep 25, 2022 at 6:18 PM
    trpeters
    Trent
    @Half Assed that nipple certainly is missing, thank you...easy to get another rad cap and I appreciate you trying to find the old post on it, I am searching as well
    @timsp8 thanks for the fan clutch suggestion as well, I had looked at that but 1. didnt have overheating at low speeds, only at higher and 2. there is no noise from the fan ...who knows though!
  9. Sep 25, 2022 at 6:22 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You need to find that piece as well as replace the rad cap. At least a couple members found that piece from the cap plugging a passage to the thermostat causing overheating.
  10. Sep 25, 2022 at 7:10 PM
    Half Assed
    Heartland Florida
    Theres info and pictures in this thread about it
    https://www.tundras.com/threads/running-hot.33183/
    Considering your rad cap is broke, I'd start by getting a new cap, and then pulling the upper hose looking for little chunks of rubber stuck in those little coolant passages.
    trpeters[QUOTED][OP] likes this.
  11. Sep 25, 2022 at 7:44 PM
    trpeters
    Trent
    Already on it Half Assed, thanks for the help folks...love this forum
  12. Sep 25, 2022 at 10:10 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Damn nipples always causing trouble. I love 'em and hate 'em.
  13. Sep 25, 2022 at 10:22 PM
    But do you snap them? :monocle:
  14. Sep 25, 2022 at 10:52 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s a vacuum valve, not a nipple. If you suck on it you’ll see how it works.
  15. Sep 26, 2022 at 12:15 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Every one I can get a hold of.
    Listen... I'm not a blushing, demure schoolboy. I've sucked enough neeples to fathom every aspect of their function.
    Also, biting.
    Sumo91 and Retired...finally like this.
  16. Sep 29, 2022 at 3:45 PM
    trpeters
    Trent
    Well thanks for everyone's help...the damn nipple was the issue ;-) Pic attached
    GODZILLA, hagrid, 07DCLimited and 2 others like this.
  17. Sep 30, 2022 at 9:33 AM
    minter66
    minter66 2007 TSS CrewMax
    I don't have this issue on my 2007 - but you better believe I am buying a new Rad cap this week.
  18. Oct 1, 2022 at 8:48 PM
    ajax1
    ajax1 New Member
    2012 black trd limited modded up
    Tires, suspension, bumpers, soft topper
    Where was it stuck?
    I would second the option of replacing the radiator if it is original, it has given you 265k miles. Fan clutch should be rebuildable you can pull, remove the fan, open the clutch and then drain the fluid , measure what comes out and add new back in. Or buy new one.
