Need feedback on price for new audio
Discussion in 'Audio & Video' started by Goosedog, Sep 23, 2022.
  1. Sep 23, 2022 at 2:21 PM
    Goosedog
    Goosedog [OP] New Member
    Mark
    2020 Limited
    So in another thread I complained about the weak JBL stereo in these trucks and most of the feedback was to get a whole new system including the head unit. That seemed like a lot to do and pay for so I asked the local shop what they recommend for less than an entire system. They said most people upgrade all the speakers, with Alpines, and then add a boosted amp under the seat all the while leaving the head unit stock. This sounded reasonable until I got his estimate. Can someone who knows more about this than me please look at this proposal and tell me of it's inline and/or even advisable. Thanks all
  2. Sep 23, 2022 at 3:52 PM
    chrisf111
    chrisf111 New Member
    Looks about right. DIY will save you serious money.
    BrandonL812 and Goosedog[OP] like this.
  3. Sep 24, 2022 at 5:08 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    You can diy and source all parts for a lot cheaper. Go to crutchfield and compare. Hit up Amazon or ebay. Speakers adapter are cheap. Some can be had for like $10. So, shop around.
  4. Sep 24, 2022 at 8:49 PM
    Tundrafan23
    Tundrafan23 New Member
    Unfortunately, getting a Tundra to sound good without changing out the head unit is damn near impossible. I wouldn't do anything if I were you, I have a feeling you are spend $2k which is a lot of damn money these days and still not be happy. The problem with leaving the stock JBL head unit is that it sends a very processed signal and getting a good clean signal for the new aftermarket speakers is almost impossible, this is why a large majority of us that upgrade just bite the bullet and buy a new head unit as well.
  5. Sep 24, 2022 at 9:16 PM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    I changed speakers first, sounded worse... then i just decided to change the head unit, amp, subwoofer.. spent almost 4k for the whole system.. but now it sounds waaay better than then the stock system.
  6. Sep 25, 2022 at 8:10 AM
    chrisf111
    I'm halfway there with a new headunit, and speakers all around. No sub or amp yet but still a huge difference in sound quality. One thing people forget when discussing this subject is that our trucks are approaching 15 years old. Speakers wear out with time, even just replacing with new oem will be an improvement.
  7. Sep 25, 2022 at 8:38 AM
    AZBoatHauler
    So.Arizona
    This is why you were encouraged to replace everything. $1800 for a band aid or about $700 more to start fresh and clean.
    1lowlife likes this.
  8. Sep 25, 2022 at 8:40 AM
    AZBoatHauler
    So.Arizona
    And $200 for an amp kit is robbery.
  9. Sep 25, 2022 at 10:51 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    $200 and probably using CCA cable..:eek2:
    @Goosedog the lower-priced amp kits are CCA cable.
    The higher priced are OFC cable.
    OFC vs. CCA Wire: The Rundown - Sonic Electronix Learning Center and Blog
    You may not even notice the difference, but why not buy the better product?
    Not saying you need to buy Knukoncepts, but this shows you the price differences.
    Amp Installation Kits (knukonceptz.com)
    As others stated, look into doing it yourself and replacing the Entune HU.
    You're never going to get what you want out of the Entune HU.
    A good HU (I'd go Kenwood or Pioneer) and the iData MAestro steering wheel control will give you much better results than putting lipstick on the Entune pig.
    You'll also be REPLACING the stock OEM under seat amp.
    Get a decent 5 channel, you're going to end up replacing your OEM JBL sub too.
    I love my Focal speakers, they are several that fit many budgets.
    Get on Crutchfield, read reviews, and talk to their customer service.
    They won't pressure you to buy.
    You'll find A LOT of helpful people on this forum..
    Good luck...
    AZBoatHauler[QUOTED] likes this.
  10. Oct 15, 2022 at 8:03 AM
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    Morning sir. I’m sorry but some of this advice is horrible. Nothing wrong with the entune jbl system hu IF you know how to deal with it. Apparently you live very close to me. I’m in Arden. I did a complete overhaul in my 2019 limited. 3 amplifiers, 2 12s, dsp and stereo integrity components.
    People fussing about the amp kit but do not even know what it is and saying it’s to expensive. Many good amp kits cost that much even if you part it out now. Also not knowing what specific speakers are being quoted is another issue. Alpine has many different options.
    And frankly, $600 to install it isn’t bad. I was quoted $1500 (in the same city) for mine but I just wound up doing it as I sound deadened the whole truck as well. Location makes a big difference as well.
    DM me and we can meet up and I’ll let you listen to mine and show you what I did.
  11. Oct 15, 2022 at 8:08 AM
    Anelson1
    Anelson1 New Member
    2020 Super White Crew Max
    Tint
    OEM Audio Plus Reference 500 system is amazing if you want to keep the stock head unit. I went with dual subs which pushed the price to $2348. Local shop installed it for $300.
  12. Oct 15, 2022 at 8:13 AM
    Iamsecond
    Kevin
    2019 Limited Tundra
    Tech12volts has a great option for your truck with an 8 channel amp and different speaker options that work well with the jbl system and it’s easy to install.
    several options that do not include changing the hu. I wanted to keep mine to keep everything looking stock.
  13. Oct 15, 2022 at 8:16 AM
    As mentioned, compare the prices against Crutchfield. You can get the amp kit cheaper than $200, and that labor charge is rediculous. There are plenty of us here that gave done our own installs that can help answer your questions.
