  1. Sep 23, 2022 at 1:20 PM
    dpittman
    dpittman New Member
    Daniel
    Hopewell, Va
    2005 Tundra DC 4.7 4x4
    Move Precision Rear Bumper
    After a few weeks of trying to find a matching color handle and getting tired of opening the window in order to get out of the truck, finally replaced the interior door handle on the drivers side today. Took about 20 mins from start to finish. There a slight color difference between the old trim piece and the new handle, but I think it’s from years and years of sun fade.
    77E3D804-6D62-4E7F-9AF0-A09015A2FBE1.jpg 5D711F2A-0039-4F6A-B088-34A10D1EBC3B.jpg 82FDA4C8-0EDB-4226-85B3-CFBACC166666.jpg FD171812-F49E-4407-A762-7D13434B6DE0.jpg
    5N0W808, Kimosabe, bmf4069 and 12 others like this.
  2. Sep 23, 2022 at 4:51 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    You might be able to get by with a clear coat respray rather than full paint.
  3. Sep 25, 2022 at 11:14 AM
    snoope
    snoope The Old Man
    I "LIKE" my Tundra :cool:
    We ended up not using it for an appliance move BUT dam thing Rides sweet and when using "cruise" it "sips gas like Bourbon instead of Bud" :rolleyes::thumbsup:
    That New tint did its job also...
    shifty` likes this.
  4. Sep 25, 2022 at 3:10 PM
    ryderboy
    ryderboy New Member
    06 tundra sr5 double cab
    Just put on the toolbox from my Tacoma. It’s a little short but I made it work.
    NUDRAT and oscardog86 like this.
  5. Sep 25, 2022 at 4:06 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    If y’all remember, my dumbass only ordered one reboot kit thinking it was for both axles. Ended up buying two new Cardone ones due to time constraints, and kept the OEM’s. Well here’s an update 6 months and 3k miles later:
    COMPLETE GARBAGE!
  6. Sep 25, 2022 at 4:11 PM
    So what’s the alternative?
  7. Sep 25, 2022 at 4:17 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    IMO, rebuild your OEM ones or buy a new OEM set.
  8. Sep 25, 2022 at 4:31 PM
    snoope
    snoope The Old Man
    OEM is the only way I have gone...
    '02 Tacoma needed one after my son returned my truck all "Detailed" As if :rolleyes::eek::mad:
    Lucky for him a family member works at Toyota ; Heavy parts Discount and the advantage of "Shop use"...
    My Son ALSO got a lesson on "Cleaning the undercarriage " when not 2 days later I smell gear oil.... Right rear wheel seal leaking :confused: :mad: The rear end vent was plugged with mud :argue:....
    His 1st rear brake job with an axle seal PLUS the "breather mod" up to the gas filler door :thumbsup:
    And NO, he NEVER got my keys again :fistbump:
    NUDRAT, oscardog86 and txagg like this.
  9. Sep 25, 2022 at 6:04 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    In other news, got my skid row setup installed today. Only hard part was running to the store for a drill bit, as my cheap HF set was so worn out I couldn't get it done. Anybody have a recommendation for a drill bit set? @shifty` ?
    5N0W808, des2mtn, oscardog86 and 2 others like this.
  10. Sep 25, 2022 at 6:22 PM
    Consider getting a step bit for that job. I wish I had one when I drilled into my frame.
  11. Sep 25, 2022 at 6:37 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I used a new 1/4 first and then a 3/8's. iIt honestly was easy and went through it like butter. That crossmember is a pretty light gauge.
    oscardog86 likes this.
  12. Sep 26, 2022 at 8:03 AM
    More line Fargone, not Cardone. Or your Car done need 'nother set of boots after a couple thousand miles. :rofl:
    Honestly, with all the frame work I've done over the years, I typically grab a pack of the cobalt bits at the big box hardware store. Dewalt is usually the ones I'll grab. I couldn't even kill a single bit in the set across 2 different 60s-era GM pickup frames. But in the event I've needed to replace, you can go back to the store and buy individual tips.
    But @FirstGenVol is right. having a step bit is killer. I prefer to drill a small pilot beforehand, then blow it out from there.
    txagg[QUOTED] and oscardog86 like this.
  13. Sep 26, 2022 at 8:13 AM
    Good times with some amazing people, beautiful sites, great food and coffee!
    It was a long drive home so I didn’t want to leave!
    Big Bear 2k22 2A1223B1-261E-46EA-96AE-B012BC3006D9.jpg8A3F4EE7-A44C-449E-A6B3-3295E3EF9636.jpg5B3EC466-73F5-421B-8A63-FFF4FC334ED5.jpgEAF7FB24-7639-4DCE-9017-6AA3FD84D77F.jpg72225F2A-C8BC-4D35-8AA3-19B009C99500.jpgD588EBF0-D583-415B-B2DB-F03C6C3E3045.jpgD2774354-D379-4F97-8F46-8C597B5E8C24.jpgED01AE6E-BB19-421D-8108-6A2F5C775C62.jpgA6C6F59A-EF77-40C7-B6BA-DC2E5A1CC67D.jpgEA2766DB-F2F0-462B-BE90-9953C7C4B5B4.jpgC4661CCF-F3FE-4597-A11C-DB41F0A6049C.jpgE118E818-9236-4FDE-9584-175760DAB7E5.jpg
    5N0W808, 805Tundra, Sunnier and 6 others like this.
  14. Sep 26, 2022 at 8:14 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Looks like a good time! I cant wait to get out camping in the next few weeks as hopefully the deserts start cooling down soon
  15. Sep 26, 2022 at 9:43 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  16. Sep 26, 2022 at 11:12 AM
    Who are the other Best gen owners? I spot a few more in the pictures.
  17. Sep 26, 2022 at 11:17 AM
    des2mtn
    SW
    Tonto cover
    We definitely didn't take a lot of pictures this weekend which is a sign of a good time.
    The best gens in attendance were myself,
    @Voss
    @Silver1stgen13
    @alb1k
    @FrenchToasty
    @RUSTYNUTS
    @Sunnier
    @Cruzer is in a few of the shots too.
    bmf4069, NUDRAT, 805Tundra and 7 others like this.
  18. Sep 26, 2022 at 11:18 AM
  19. Sep 26, 2022 at 11:21 AM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Good times with good people.
  20. Sep 26, 2022 at 11:42 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    bmf4069, txagg, Jack McCarthy and 2 others like this.
  21. Sep 26, 2022 at 11:42 AM
    empty_lord
    05 rollover special
    In other news, brake lines came in. Just waiting on the drive pins I got shorted. Should be in tomorrow. I MAY do install of the TRD BBK tomorrow night
    bmf4069, NUDRAT, txagg and 2 others like this.
  22. Sep 26, 2022 at 12:36 PM
    Silver1stgen13
    Silver1stgen13 New Member
    Sam
    2005 Blue DC 4x4 2001 Silver AC(SOLD)
    Definitely add these to the google photos album if you guys can!
    Got @Noah in one of those as well.
  23. Sep 26, 2022 at 1:30 PM
    danmurphymn
    danmurphymn New Member
    Minneapolis, MN
    Black 2004 DC TRD
    Who has more info on this rig? I'd love to see how the bed is setup.
    Looks nice!
  24. Sep 26, 2022 at 2:13 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    As far as bed setup, I've heard the Ridgeline's have a built in storage compartment in the floor. HTH.
    bmf4069 and FrenchToasty like this.
  25. Sep 26, 2022 at 2:17 PM
    Yeah, but it's not quite big enough to fit an adult body in it, even when dismembered. :(
    bmf4069 and txagg[QUOTED] like this.
  26. Sep 26, 2022 at 2:28 PM
    Silver1stgen13
    Sam
    That would be @FrenchToasty
  27. Sep 26, 2022 at 2:36 PM
    Thanks, it’s more helter-skelter than setup, @des2mtn probably has a better bed setup to show off than I do C85DA774-184C-4BDC-933E-318DE86F15DF.jpg
    oscardog86, bmf4069, txagg and 2 others like this.
  28. Sep 26, 2022 at 4:38 PM
    snoope
    snoope The Old Man
    NOPE, even the New Guy ain't asking :monocle:
    Pre-loading the Tundra,
    We will be "moved on" by this Stupid Hurricane tomorrow afternoon ...
    Maybe have "Water worx "pix come Thursday o_O
    shifty`[QUOTED] likes this.
  29. Sep 26, 2022 at 5:31 PM
    I was just talking to my sis in St Pete. The national news is making it sound like Armageddon is coming. I’m curious just how bad this thing is going to get.
  30. Sep 26, 2022 at 6:02 PM
    As a former Floridian that's, like, every freaking hurricane. You get desensitized to it after a year or two, and I'm not even kidding. Every one you survive makes you more skeptical of the reports. To the point you legitimately don't know what to take seriously or not, you just kinda watch NOAA to track the 3, 5, 7 day and assess the risk on your own, despite how educated you may or may not be. Floriduh.
    Man, you'd think you were a Cali guy with all that grass in your truck. :rofl:
    oscardog86, bmf4069, NUDRAT and 2 others like this.
