No charge
Discussion in '2nd Gen Tundras (2007-2013)' started by WesT0531, Sep 22, 2022.
  1. Sep 22, 2022 at 10:35 AM
    WesT0531
    WesT0531 [OP] New Member
    Wisam
    2007 tundra crewmax v8 4.7L
    Stock
    I have a 2007 tundra crewmax v8 4.7L model. Truck died while I was parked with engine running. The voltage on battery read about 12.5 volts. I got a jump start and it ran for 10 minutes and died again. While running, the voltmeter read only 7.5 volts. I d8sconnected the battery for 10 minutes, then reconnected the cables. Checked all the fuses. And got another jump start from another car. At first it did not even crank at all. I kept it connected to running car and it started back up after 4 or 5 minutes. As soon as I disconnected the cables, the voltage started dripping so quickly from 12.5 to dying and shutting down completely.
    I replaced both altenator and battery at the same time a year ago. Fairly new.
    Another note, the battery light on the dash board does not come on at all. I read that the light is connected to the alt, in the case the light is blown, the alt does not get the signal to send power to battery. I opened up my dash board and there is bunch of led lights on the electric board. Not like the old school simple light bulb replacement.
    I am completely stock. Drained battery. Not crank. Completely dead.
    Any help is highly appreciated.
    Thank you.
    I hope my phone does not die on me as well before I figure this thing out.
  2. Sep 22, 2022 at 12:33 PM
    socaldiablo
    socaldiablo New Member
    Carlsbad, CA
    2013 White Tundra SR5 Rock Warrior
    Leer camper shell, slight lift kit, TRD Pro BBS wheels
    I'd say your newish alternator is no good.
    07 Tundie and Gort like this.
  3. Sep 22, 2022 at 1:16 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Pull the alternator and take it to your local auto part shop to get it tested. Probably a good idea to get them to charge and load test your battery also.
    Just because it is fairly new doesn't mean it can't be dead.
    socaldiablo likes this.
  4. Sep 22, 2022 at 3:39 PM
    socaldiablo
    Carlsbad, CA
    Yep, totally agree with this. I purchased 2 brand new batteries recently for other vehicles I have/had and after short usage (like maybe a year or so), both batteries had a bad internal cell which rendered them useless paper weights. Both were replaced under warranty with no cost to me. New parts can prematurely malfunction ...happens way more often than it should. Hell, everything is made in China anymore so I'll just leave it at that.
  5. Sep 22, 2022 at 5:58 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Before you just go tearing it apart, check all the fuses. Get the voltmeter out and verify some power inputs. Just because the alternator isn’t working doesn’t mean it’s bad. Sometimes the trigger to enable the alternator to charge gets cut off by a fuse.
