  1. Sep 21, 2022 at 7:50 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I owned a 21' Celebrity for years, absolutely incredible boats. Good luck with both. :thumbsup:
    krap22[QUOTED] likes this.
  2. Sep 21, 2022 at 8:07 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I looked that boat up. Seems like a clean one is a pretty good deal! Interested in how it treats you.
  3. Sep 21, 2022 at 9:07 PM
    DowntownApexTundra
    DowntownApexTundra New Member
    2021 DC SR5 4x4 Sport
    3/2 leveling lift kit, pocket style fender flares (best super white color match you'll ever see - painted by my uncle), 1.5" wheel spacers, S&B CAI, TRD Pro headlights, 18" knockoff Ebay TRD Pro Wheels, wildpeak at3w 275/65R18 116t (32/11), gator roll-up tonneau, blacked out interior by AJT and others, pedal commander, blacked out exterior badges, LED everything, RCI neoprene water proof seat covers (removed back middle seat back material to make it work), weather tech floormats, flowmaster flowfx extreme 3.0 exhaust
    Do you know if it's possible to change or remove the bolts on your fender flares?
    I'm looking at these right now but also in process of chrome delete inside and out.
  4. Sep 21, 2022 at 10:58 PM
    The bolts can be removed and replaced. There is a company that sells black ones.
    bulldog93 likes this.
  5. Sep 22, 2022 at 4:30 AM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    I bought black stainless nickel plated button head bolts off eBay. They have sets to replace fender flair bolts.
  6. Sep 22, 2022 at 5:40 AM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    Pre-Collision System fail, Trailer Brake fail, ABS fail, and Traction Control fail all at once. Time for a new battery!
    That said, have any of you people done an engine bay cleaning? It seem that this truck’s engine bay gets filthy easier than any other vehicle I’ve had. I can get Simple Green pretty much on tap at work so I figure covering that electronic stuff and getting after it is the best option.
  7. Sep 22, 2022 at 5:49 AM
    RobertD
    Robert
    DFW, Texas
    I just used some de-greaser paint prep spray after using some soap and water. I just used shop towels and wiped down the surfaces I cared about. Maybe dilute the simple green some and you should have no problems, plus it will smell nice and probably push that scent into the cab even if its initially a bit strong lol
  8. Sep 22, 2022 at 6:33 AM
    krap22
    krap22 New Member
    Polk City, Iowa
    2017 SR5 TRD off road
    My parents had the 21' version when i was in high school so I'm very familiar with the boat. I've had it for about 3 weeks now and it is fantastic. It was very well taken care of. It runs great.
  9. Sep 22, 2022 at 7:03 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    RCI plates + cat guards, went with the powder coated aluminum. Quality stuff and the holes for the cat guards now come pre drilled.
  10. Sep 22, 2022 at 10:35 AM
    trd_in_cny
    trd_in_cny Code jockey and cloud monkey
    Donny
    Central NY
    2015 TRD DC Limited
    That shifter is slick. Custom made or ordered online?
  11. Sep 22, 2022 at 11:00 AM
    stevep0925
    stevep0925 New Member
    Trinity, AL
    19 Cav Blue Limited 4x4
    Tundra – Teton Workshop < right here my dude....
  12. Sep 22, 2022 at 1:21 PM
    KSTNTUNDA
    KSTNTUNDA New Member
    Nashville
    2020 LIMITED TRD OFF ROAD
    Just dropped her off to get new shoes put on.
    Mickey Thompson Baja Boss A/T 275/70 R18
  13. Sep 22, 2022 at 1:46 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    Nice my next set of tires
    Littledog likes this.
  14. Sep 22, 2022 at 1:55 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Those will look sweet!!!!!
  15. Sep 22, 2022 at 1:58 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    Attempted to change my oil. Truck just hit 30k and has only had the dealer change the oil to this point. Low and behold Mongo put the filter housing on with what appears to be a 3/4 drive impact wrench. Geez this thing is tight! Currently just have a 64mm filter socket but ordered the MotivX tool from Amazon. I’m having said dealer take the filter housing off first thing in the morning so the liability is on them if they break anything. Also going to replace the plastic housing with the aluminum version. What a pain!
    Henry1jg, Mike59, Blowdart and 3 others like this.
  16. Sep 22, 2022 at 2:02 PM
    Tripleconpanna
    Smart move... I'd do the same!!!!
    It's almost starting to look like this crap is being done intentionally broad spectrum. Toyota needs to clean up the service being provided by dealerships!
  17. Sep 22, 2022 at 2:09 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    They even over torqued the hardware for the access window on my RCI skid plate! I understand it’s the junior employees doing these type of services but they either need better training, more supervision or both. Until then I’ll just change it myself like most members here do and recommend.
  18. Sep 22, 2022 at 3:17 PM
    Fugis281
    Fugis281 New Member
    Rufio
    CA
    2021 TRD Sport/PRO
    Suspension: TRD PRO Suspension, Wescott Lift, Coachbuilder +3 Shackles and Tierods, Element UCS's, Wheels/Tires: Method Race Wheels MR312's, Toyo 35" Open Country RT's Engine: Stillen CAI, Pedal Commander, D3 Performance Tune, TRD PRO Dual exhaust.
    Finally got around to installing the boost mirrors and AMP steps.Screenshot_20220916-125613_Instagram.jpg
    Henry1jg, texasrho83, Mike59 and 5 others like this.
  19. Sep 22, 2022 at 3:23 PM
    Cliffy34
    Cliffy34 New Member
    Pittsburgh
    2018 White Tundra SR5 Crewmax
    I’ve been going back and forth on these mirrors for a while. This might’ve sealed the deal lol
  20. Sep 22, 2022 at 3:31 PM
    Fugis281
    Fugis281 New Member
    Rufio
    CA
    2021 TRD Sport/PRO
    They are awesome, only thing I regret is not getting the power fold but not necessary. Plus it was an extra 200 or 300 bucks.
  21. Sep 22, 2022 at 3:38 PM
    Cliffy34
    Cliffy34 New Member
    Pittsburgh
    I don’t have powerfold to begin with so that wouldn’t be an issue for me
  22. Sep 22, 2022 at 3:52 PM
    Cthulhu
    I am on a TRD Pro Fox Suspension with the TRD Pro Lift Kit by Coachbuilder. (3" front, 1.75" rear) The TRD Pro Lift Kit by Coachbuilder technically only clears 11.5" / 11.7" wide tires without rubbing on the front wheel liner or the body mount (Coachbuilder explains this in the kit description). If you use 12.5" wide tires like I did, you may see rubbing on the front wheel liner in reverse. I did, so I spray painted the liner white so I can accurately see where the rubbing was occurring, then I will use a heat gun to push the rubbing areas back, and finally spray the liner back to black. Even with the 12.5" wide tires though, I still have no rubbing, forward or reverse, on the body mount. I also had to remove the front air-dam flaps and the front mud flaps.
    I hope this helps.
    Tundrastruck91 likes this.
  23. Sep 22, 2022 at 3:59 PM
    RobertD
    Robert
    DFW, Texas
    They are one of the few companies that provide the harnesses to give you power folding mirrors if your stock set up didn't have it (if you select that option). They are very customizable and so far have a very good reputation.
    texasrho83 and Cliffy34[QUOTED] like this.
  24. Sep 22, 2022 at 4:28 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Not all do yet unfortunately. I'll have to drill them in the plate I just got.
  25. Sep 22, 2022 at 4:59 PM
    Lost in the East
    Lost in the East New Member
    Derek
    Voodoo Blue TRD Pro (Should’ve kept it) Mudbath TRD Pro
    02600B22-A765-4297-8EDD-B5D6A9F9987D.jpg D0C9DC6D-EC00-4135-87F3-F20003B2773E.jpg C4ADBD79-C483-4E2B-89E4-57D7324B41DA.jpg 66F02C64-952C-4EA4-A7A5-CF8B8CC0F816.jpg
    Changed the center console lid from the pro one to the platinum and added the wireless charger (Still need to plasti dip the Pro insert) Then had the seats redone with Katzkin ventilation (Needed for this Texas heat)
  26. Sep 22, 2022 at 5:13 PM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    I've used Simple Green for many years to clean my engine bay. I've been slacking a bit on the Tundra, but my Taco was immaculate for it's age. I use full strength or 50/50. Spray on, let sit without drying, hose off. I don't cover anything. Maybe clean and grease battery terminals after, but Taco never minded either way.
  27. Sep 22, 2022 at 5:28 PM
    Lost in the East
    Derek
    I need to take care of the engine bay soon. I’ll try this out.
  28. Sep 22, 2022 at 5:42 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    Welcome!!!
  29. Sep 22, 2022 at 5:44 PM
    Welcome from NY.
    sleepydog[QUOTED] likes this.
  30. Sep 22, 2022 at 5:49 PM
    Gort
    Gort New Member
    Canada
    2020 Tundra SR5+
    A wireless charger was one thing that I was upset about missing in my 2020, especially with that perfect slot in the center console. I went the lazy route because I didn't want to begin messing with electrical and just got this.
    https://www.amazon.ca/CarQiWireless-Wireless-Organizer-2014-2020-Accessories/dp/B09NW2KY3H?crid=3FQ6QZ7PH6ML6&keywords=tundra+console+organizer+wireless+charger&qid=1663894079&sprefix=tundra+console+organizer+wireless+charge%2Caps%2C115&sr=8-2
    Works great.
