37s on 6inch lift
Discussion in 'Wheels & Tires' started by 240franklin, Sep 20, 2022.
  1. Sep 20, 2022 at 11:38 AM
    240franklin
    240franklin [OP] New Member
    Franklin
    2019 Tundra Sport
    So i just got my tundra not to long ago and i wanted to go with a 6inch roughy country lift with the stock platinum rims but can’t decide between 35s or 37s because i think 35s would look to small but if i went 37s i want to know what spacers i could run for it not to rub to much
  2. Sep 20, 2022 at 11:42 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Welcome to the forum.
    Not sure you can put 37s on stock rims... may need to get someone else to chime in on this.
  3. Sep 22, 2022 at 2:44 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Check the fine print for the RC lift, that is a bracket lift and probably states what offset rims to use, doubt stock will work. And you wont be running 37s on stock wheels. 1250 wide tires will hit the UCA with stock rims due to the +60 offset. You need rims will less offset and most 1250 tires spec at least 9 inch wide wheels. Stockers are 8.
    You can fit 35s with 2-2.5 lift and wont have to cut the crossmember. That RC 6 inch lift requires the cut. Check out the wheel/tire and suspension forum here, there are better alternatives for your $ to run 35+ tires.
    You will also want to regear the truck for 37s 5.29 gears.
    trucknut and texasrho83 like this.
