Need help finding part # for trans warmer/cooler hose
Discussion in '2nd Gen Tundras (2007-2013)' started by wadeofdeath, Sep 22, 2022.
  1. Sep 22, 2022 at 6:05 AM
    wadeofdeath
    wadeofdeath [OP] New Member
    2009 CrewMax 4x4
    Does a topper count?
    I need help finding the part number for this little length of hose running to my trans warmer (the little puck on the trans not the actual radiator like cooling device) in the picture attached. Even just the hose diameter might work as it seems like maybe I will have to just go with off the shelf hose to get by. The hose I need is the lower hose I the pic though I may just get both while I'm at it. If anyone has input on what might cause that hose to leak other than being 280,000 miles old. I'm all ears. Thanks in advance.
  2. Sep 22, 2022 at 6:49 AM
    @Genuine Cooling Systems may be able to provide a part number or the hose itself.
  3. Sep 22, 2022 at 6:51 AM
    Look at the descriptions of these as well...It may get you to a good starting point.
    https://www.sparksparts.com/v-2009-...-7l-v8-gas/belts-and-cooling--hoses-and-pipes
  4. Sep 22, 2022 at 6:56 AM
    Genuine Cooling Systems New Member Vendor
    maybe 16267-0S011? I would just call the local dealer for verification.
    Tundra234[QUOTED] likes this.
  5. Sep 22, 2022 at 7:05 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Here you go.
    Tundra234 likes this.
  6. Sep 22, 2022 at 7:46 AM
    those are for the thermostat, not the warmer.
  7. Sep 22, 2022 at 9:04 AM
    e30cabrio
    Yes they are, I have regular hose there now as these took 5 ever to come in, I plan on installing them when Az is under 100 degrees. I figured they were the same.
