FFS-- Toyota.....another rear wheel bearing project?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Vito117, Sep 21, 2022.
  1. Sep 21, 2022 at 3:49 PM
    Vito117
    Vito117 [OP] New Member
    ANTONIO V.
    IOWA & ILLINOIS
    2019 TUNDRA CREW MAX-- LIMITED- TRD PRO
    So I've told you about the rear wheel bearing issue I had back in February. Got it replaced...no issues, good.
    So now this past week I'm hearing the telltale death siren of another wheel bearing going to shit.
    This time drivers side rear.
    What the hell Toyota?
    A truck with a measly 140,000 miles on it from easy highway driving, isn't hauling CMU pallets or towing stock trailers up Pikes Peak has another one go out?
    What the hell are these bearings made of? Pot metal?
  2. Sep 21, 2022 at 4:21 PM
    Damn. That sucks Antonio. I wonder if a bad lot of bearings were installed.
    You do put the miles on. Grass doesn’t grow under your Tundra.
  3. Sep 21, 2022 at 4:35 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    At least it isn't the same one you replaced right? What brand is your replacement bearings?
  4. Sep 22, 2022 at 3:13 AM
    Vito117
    ANTONIO V.
    IOWA & ILLINOIS
    The bearing I had replaced in February ( passenger side) was done by my local Toyota dealership so I assume these were Toyota original.
    Got an estimate from mom and pop shop near my office and they want $850.00 to do the drivers side rear.
  5. Sep 22, 2022 at 3:16 AM
    Could you perform this yourself? Not sure if you have the garage space or tools is why I ask. If you know someone with a press….
  6. Sep 22, 2022 at 3:24 AM
    Vito117
    ANTONIO V.
    IOWA & ILLINOIS
    I could probably do the job myself. I would need a press though. Getting this thing back together and making sure all the ABS, speed sensor..etc all work and not glitch out worries me. Above my pay grade.
  7. Sep 22, 2022 at 3:33 AM
    I think you underestimate your abilities sir. It’s not that bad of a job if you wanted to save some money. Not everyone has the time though either.
  8. Sep 22, 2022 at 4:10 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I miss the days of working for a company that had a 300k lb press
  9. Sep 22, 2022 at 5:40 AM
    Vito117
    ANTONIO V.
    IOWA & ILLINOIS
    Napa has the bearing hubs for $180-250.00.
    Toyota has them for over $450.00
    Why the large difference? OEM vs...?
  10. Sep 22, 2022 at 5:43 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've seen Koyo for less. They're stock Toyota/Lexus parts
  11. Sep 22, 2022 at 7:13 AM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
    Tons of Koyo counterfits out there, be dilligent.
