Fluctuating battery gauge
Discussion in '3rd Gen Tundras (2022+)' started by TunBruh22, Sep 21, 2022.
  1. Sep 21, 2022 at 6:06 AM
    TunBruh22
    TunBruh22 [OP] New Member
    Charles
    22 Tundra Limited
    Question.
    is the battery gauge supposed to fluctuate while driving?
    the last time this happened was my 2020 Ram etorque and the battery’s failed while driving. Praying not more battery issues. Hopefully this is normal, you all know more than me I just transitioned from Mopar from last 20 years
  2. Sep 21, 2022 at 6:15 AM
    timsp8
    NY
    I’d guess not. How much and how fast is it fluctuating? It’ll charge higher when you first start the truck and then drop once the battery is topped off. My 2.5 Gen starts around 14.5 but goes down to mid 13s after driving awhile. If yours is noticeably up and down in short periods, that’s not normal.
  3. Sep 21, 2022 at 6:26 AM
    TunBruh22
    Charles
    22 Tundra Limited
    I was trying to upload a video but it won’t let me but yes it is constant like every five seconds it goes to 3/4 then back to a 1/4
  4. Sep 21, 2022 at 6:31 AM
    xc_tc
    xc_tc New Member
    It’s normal. Charges at first, then stops charging, but will charge when you’re off the throttle and coasting.
    KroppDuster likes this.
  5. Sep 21, 2022 at 6:59 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I've had my truck since April and that's a normal occurrence. As others have started the battery charges during certain driving conditions and therefore you see the increase to 14ish volts then it stops charging and goes back down on to the 12ish normal reading.
  6. Sep 21, 2022 at 9:44 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    More and more newer vehicles do this as a way to manage to charging the battery. My 22 Tundra does it and my wifes 21 Honda Ridgeline does the same thing, some kind of pulse charging they called it, not sure of the thought process behind it but it's normal.
    hudrock likes this.
  7. Sep 21, 2022 at 10:11 AM
    pursuit2550
    pursuit2550 New Member
    I know they are saying it’s normal but that’s a lot of fluctuation. And if you look at the gauge it reads 9-19 volts. That’s 2.5 volts per line. So if he is correct on the 1/4-3/4 then he’s going from 11.5-16.5. Doesn’t sound right.
  8. Sep 21, 2022 at 10:33 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    I have a digital usb port plugged into the light port and it shows actual battery voltage and the numbers I see when it's charging and not charging are 11.9 vdc to 14.3 vdc. The analog voltage gauge I'm sure isn't the most accurate, it sure caught my attention the first time I saw it. I think if you have the digital voltmeter, it may not even show the fluctuations.
  9. Sep 21, 2022 at 10:36 AM
    pursuit2550
    Granted I don’t have a 22 but I don’t see Toyota using a gauge that goes from 1/4-3/4 every 5 seconds like the OP mentioned. That would drive me crazy. But hey I have seen weirder things. Does your move that much?
    Leo's first likes this.
  10. Aug 9, 2025 at 6:45 AM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    This has caught my eye since driving it as the voltage level fluctuates often and I'm not used to seeing it, in reading more about it online I think Toyota uses a smart alternator in its 3rd gen Tundras which charges the battery different. Curious if this will this prolong your battery life?
  11. Aug 9, 2025 at 7:38 AM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    Absolutely normal.
    The charging system apparently now has a PhD, far beyond the high school dropouts entrusted with this task in the years past. It will charge initially after starting, then only when the engine is coasting or not under under load, except when the draw is larger than normal. As a result, the voltage will go up to 14.5 or so and drop down to 12.9 or so all the time.
    Raven67 and Tundrastruck91 like this.
