Ink stain removal from door panel vinyl
Discussion in '2.5 Gen Tundras (2014-2021)' started by jtwags, Sep 15, 2022.
  1. Sep 15, 2022 at 7:37 AM
    jtwags
    jtwags [OP] Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Hi All,
    Need some advice on this one. Found this beautiful piece of contemporary art my 5 year left for me. I can't get it out, tried vinegar, baking soda, goo gone, acetone (carefully), baking soda, detergent, magic eraser. It seems to be set in there good.
    Anyone know another trick or is that a piece I can order from Toyota and replace? Passenger Rear door vinyl from 2018 Limited
    Thanks!
  2. Sep 15, 2022 at 7:46 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Brake cleaner? Maybe get rid of the kid? lol
  3. Sep 15, 2022 at 7:47 AM
    Call an auto detailer and see what they recommend.
    jtwags[QUOTED][OP] likes this.
  4. Sep 15, 2022 at 7:48 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I would get a tattoo of it, it's kinda cool....:cool::eek2::p:thumbsup:
  5. Sep 15, 2022 at 7:49 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Is that permanent marker/sharpie? Try a dry erase marker over it and wait for it to dry then wipe it off, NOT the low odor kind. Might take a couple attempts. Unfortunately, not sure if it will still work after all the other stuff you have tried but it normally works on fresh permanent marker.
    jtwags[OP] likes this.
  6. Sep 15, 2022 at 7:56 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Awww....
    I was going to say what @TundraMidwesterner said. Put a dry erase marker on top. Then follow up with some Dawn dish soap.
  7. Sep 15, 2022 at 8:02 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Acetone
  8. Sep 15, 2022 at 8:05 AM
    '08grade
    '08grade New Member
    2008 DC V6 grade 1gr-fe
    2013 OE alloys. 2013 OEM head unit, Weathertecs,
    Mineral spirits, then napthalene. (VM&P naptha) Every garage should have these two amazing cleaning chemicals anyway. Mineral spirits is the gentler one, so start with that.
  9. Sep 15, 2022 at 8:15 AM
    TundraMidwesterner
    Northern Illinois
    I'm just going to repeat this again because you don't want to damage the vinyl with anything to harsh if you don't have to. Dry erase markers work over sharpies because they have non-polar solvents. When you write with a dry erase marker on a whiteboard the dye/ink is mixed with the solvent, as it drys the solvent breaks down the bonds in the dye/ink so its easy to wipe off. The smell in a dry erase marker is the solvent evaporating. You could use another non-polar solvent but a dry erase marker is usually pretty easy to come by. Again, not the low odor kind, less solvent means it doesn't work as well. The non-polar solvent will do the same thing to a sharpie.
    Many years ago I used to work IT in a school district and on occasion teachers would accidentally use a sharpie on their SMART Board projector screens, which were fairly soft. Regular dry erase markers would work to fix them 95% of the time. Even after they tried to clean them off themselves with various cleaning supplies. It was part of the SMART Board factory technician training.
  10. Sep 15, 2022 at 8:19 AM
    It is not sold separately. It is part of the main door panel. It is probably attached with plastic rivets. You might be able to get it recovered if the ink doesn't come out.
  11. Sep 15, 2022 at 8:50 AM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
    Rubbing alcohol has worked for me in the past. Strong enough to dissolve the ink but not the dye.
    Retired...finally and jtwags[OP] like this.
  12. Sep 15, 2022 at 10:44 AM
    jtwags
    League City, TX
    2018 Tundra CM
    I think it was an ink pen, not a marker. Tried mineral spirits, no difference. I am going to take a pic, blow it up to Tshirt size and wear it anytime she makes poor choices :)
    Good call about pro detailer, going to call around.
    1lowlife likes this.
  13. Sep 15, 2022 at 10:48 AM
    AZBoatHauler
    So.Arizona
    Another route - search for a junkyard door panel? Probably cheaper than hiring a detail guy.
  14. Sep 15, 2022 at 11:33 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    If she is only 5, you better get a dozen of the same shirts made..:eek2:
    You're gonna need more than 1 and they will wear out quickly.:cool:
    Just kidding........................................... kinda.:confused:
    I'll just say this, enjoy that kid in her youth.
    She will 28, like my daughter, in the blink of an eye..:thumbsup:
    Hope you get it out...:D
  15. Sep 15, 2022 at 8:28 PM
    AgileTundra
  16. Sep 16, 2022 at 8:22 AM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Magic Eraser
  17. Sep 16, 2022 at 9:07 AM
    mike220022
    mike220022 New Member
    I was going to suggest the same as @AgileTundra, rubbing alcohol is the best thing Ive ever used to clean stains off of leather and vinyl.
  18. Sep 16, 2022 at 2:16 PM
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
    Isopropyl Alcohol - takes ink out of fabrics, takes ink off other materials
    Also 'Blue Magic' carpet cleaner will take out anything in carpet and fabrics
    jtwags[OP] and Retired...finally like this.
  19. Sep 16, 2022 at 2:30 PM
    Retired...finally
    91% Isopropyl alcohol. Dab at it instead of rubbing.
  20. Sep 19, 2022 at 6:18 AM
    jtwags
    League City, TX
    2018 Tundra CM
    Tried alcohol and dry erase marker yesterday. The ink is definitely set in, albeit barely lighter but I am also loosing color on the panel. Had a fabric restore guy over too and he said if the alcohol isn't working it needs to be sealed and repainted/pigmented. Apparently overtime the ink will just bleed through the stuff he has to fix it so sealer first. $150 to color match the panel. Started scouring junk yard sites. Found 1 panel but ironically has a blemish on the gray vinyl too and it is $275. Tempted to find a gray ball point pen and just blend it in for now until kids are past their tagging stage.
  21. Sep 19, 2022 at 2:06 PM
    Rocko9999
    Rocko9999 New Member
    Goof Off. Gently. Have wet rag(water) handy to clean off chemical residue.
  22. Sep 19, 2022 at 3:18 PM
    JRS
    JRS New Member
    2012 DCLB
    MEK
    You've already tried everything I would've started with.
  23. Sep 19, 2022 at 5:10 PM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    I'd blend it, then just grin and bear it until old enough. Then have this pic to remind them when they get their first car + kid...
  24. Sep 19, 2022 at 5:11 PM
    AZBoatHauler
    So.Arizona
    Wait til they’re older and back into your new ride.
  25. Sep 19, 2022 at 5:17 PM
    BeauDacious
    14 DC 4x
    Did you mean to write
    Back into their new ride? Like as in revenge?
    Looks gnarly.
  26. Sep 19, 2022 at 5:48 PM
    AZBoatHauler
    So.Arizona
    Ha. I wish. Financial pain inflicted by your children is the gift that keeps on giving.
  27. Sep 19, 2022 at 5:54 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Alcohol and if that doesn't work get some Vodka.. at least it will work on you :proposetoast:
    jtwags[OP] and AZBoatHauler like this.
  28. Sep 19, 2022 at 8:08 PM
    ConcordCarlos
    ConcordCarlos New Member
    Carlos
    2021 Tundra SR5
    I remove a lot of light duty graffiti with WD-40.
    jtwags[OP] and Rocko9999 like this.
  29. Sep 26, 2022 at 6:09 AM
    jtwags
    League City, TX
    2018 Tundra CM
    Well, final outcome. Had it blended by a pro who was restoring my neighbors Camaro seats. Looks good and no longer irks me everytime I strap my kiddo in, happy pappy!
  30. Sep 26, 2022 at 9:16 PM
    activereality
    activereality New Member
    2020 Tundra SR5 TSS Cavalry Blue
    MillerCats installed!
    that looks amazing - they did a great job. I love my kid - but sometimes........... haha!
