'18 Head Gasket - Dang!
Discussion in '2.5 Gen Tundras (2014-2021)' started by btodag, Aug 19, 2022.
  1. Aug 24, 2022 at 6:39 AM
    btodag
    btodag [OP] New Member
    BG
    2018 Tundra Limited
    Def not using the magic sealer.
    Dealer has started being more supportive later in the day yesterday, wants to find the problem. I'm happy with the direction, just need to find a way to confirm the leak.
    Me using the word "blown" may not be appropriate. "Leaking" may be more appropriate. It isn't spewing fog all day everyday, but is pretty consistent. Out of 4 times I drove it last weekend, I saw fog 2 times. Coolant is over an inch low after 2k miles. Not a "blown" level maybe, but isn't right.
    joseph_womack likes this.
  2. Aug 24, 2022 at 6:42 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    just because smoke isn't coming out all the time doesn't mean it isn't blown, one eco boost f150 came into the shop, only blew smoke on startups, but gradually got worse and pretty much did it all the time, tried sealer, didn't work, just made it worse
    since it was the eco boost we were already pretty sure the motor was blown since they do it at 100k... and sure enough it was, internal head gasket leaking, turbo shot, common things for a ford but not a toyota :burnrubber:
  3. Aug 24, 2022 at 6:52 AM
    btodag
    BG
    2018 Tundra Limited
    Amen brother!
    joseph_womack[QUOTED] likes this.
  4. Aug 24, 2022 at 6:57 AM
    joseph_womack
    Joe
    Louisiana
    and unfortunately I'm not seeing any TSBs related to head gaskets or coolant leaks with the '17 tundra
  5. Aug 24, 2022 at 10:33 AM
    btodag
    BG
    2018 Tundra Limited
    I'm hearing it is a non-existent problem, so a legit point to be extra confused about.
    Never got hot, I don't do too much to crazy. Occasional boat towing or hauling something, well within normal use expectations.
  6. Aug 24, 2022 at 10:44 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    @btodag shoot me a PM. I have some info for you. Probably too much to type to be honest
  7. Sep 18, 2022 at 5:48 PM
    rockfordhx
    rockfordhx New Member
    Any update on this thread? I have a 2017 5.7L Flex Fuel Tundra with 58K and noticed a white cloud of smoke after startup one morning. Later that day, I checked the engine bay and noticed that the coolant level in the reservoir tank was about empty. It had been about 5K since I had last checked the fluid levels so it has happened within 6mo/5K. Took it to the dealer last week and they told me that they could not find any reason for the coolant leak and could not reproduce the white cloud of smoke after keeping it overnight. I am concerned that it could be a small leak in the head gasket and I want to get it fixed before the warranty is out.
    I have not observed the issue reoccurring over the past week and I am monitoring the coolant level.
    Any update on your situation as it may be helpful to me.
