Hybrid battery
Discussion in '3rd Gen Tundras (2022+)' started by Tb2, Sep 16, 2022.
  1. Sep 16, 2022 at 2:36 PM
    Tb2
    Tb2 [OP] New Member
    James
    My battery level on my hybrid never gets 100% charge . There is at most 2 open slots to full drove over 200 miles highway and it never went to full? why
  2. Sep 16, 2022 at 2:41 PM
    Tikisia
    Tikisia New Member
    The only time! 3ECB5739-6323-4839-B89B-CD1EA878296A.jpg after going downhill for 20 minutes
    =JSG= likes this.
  3. Sep 16, 2022 at 3:13 PM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    You'll need to drive down a long grade that requires continuous light braking in order to fully charge it. I'm talking probably 5-6 miles (maybe more?) of steep, downhill grade with your foot on the brake pedal and then you might fully charge it. The battery only charges when braking, so driving 200 miles on what I assume is a fairly flat highway will never charge it.
    Also, hybrid batteries tend to operate at less than fully charged states. Batteries work the hardest in the lowest 20% and the highest 20% of capacity, so they can be made to last much, much longer if the charge is always kept in that 20-80% range. Maybe even 30-70% depending on the vehicle. There are options in electric cars to set the max charge to 60 or 70% if your typical daily commute never needs more than that, which allows the battery to last several hundred thousand miles.
  4. Sep 16, 2022 at 3:18 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    You’ll never get it 100% full nor 0% drained. By design. 20-80%.
    just like plug in EV’s optimal charging max is 80% . If you recharged to 100% constantly you’d wear out the battery quicker
    ToyoMon, Terndrerrr and =JSG= like this.
  5. Sep 16, 2022 at 4:00 PM
    breynolds
    breynolds New Member
    Future Tundra owner
    If its anything like my wife's 22 Highlander Hybrid, the gas motor will charge the batteries as well, not just braking.
  6. Sep 16, 2022 at 5:56 PM
    Will816
    Will816 New Member
    Will
    Idaho
    Are you sure it’s not just charging it to a minimum level after it’s been extremely depleted? It defeats the purpose to charge it from the motor and not from regenerative braking.
  7. Sep 16, 2022 at 6:21 PM
    Tb2
    Tb2 [OP] New Member
    James
    So 2022 tundra hybrids have regenerative braking?
  8. Sep 16, 2022 at 7:07 PM
    Blitz79
    Blitz79 New Member
    So if the optimal use of the battery is between 20 and 80%. The user probably sees 20% as 0 and 80% as 100%. The computer should manage the real battery charge in the background.
  9. Sep 16, 2022 at 7:25 PM
    Tb2
    Tb2 [OP] New Member
    James
    Well that makes no sense
  10. Sep 16, 2022 at 8:12 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    We had a 2006 Camry Hybrid, and have a 2015 Prius & a 2020 Camry Hybrid. I have never seen more than one short of all the bars, usually, they sit about 3/4.
    Canebrake likes this.
  11. Sep 16, 2022 at 8:59 PM
    Will816
    Will816 New Member
    Will
    Idaho
    ALL hybrid assisted drivetrains use regenerative braking. Every single one. That’s how it works, instead of losing that kinetic energy in the form of friction and heat in your brake pads and discs, hybrids attempt to use the motor-generator to slow you down, which produces a voltage and charges the battery. Then, when you start accelerating again, it uses the stored energy in the battery to propel you (in part) with the motor-generator. Rinse and repeat. That’s how hybrids maintain efficiency, especially in stop-go driving. In non-hybrid power trains, accelerating uses a ton of gas and braking wastes energy.
  12. Sep 16, 2022 at 9:03 PM
    xc_tc
    xc_tc New Member
    Nearly all hybrids stay at around the half point on the battery charge. This is for durability purposes. It will charge up more if you do a lot of braking due to the regenerative braking. Also if you deplete it by sitting with the AC on, the engine will kick on to charge up the battery.
  13. Sep 17, 2022 at 4:23 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Mine spends most of its time from 2-5 bars never is full. My display is different from yours.
  14. Sep 17, 2022 at 7:24 AM
    breynolds
    Future Tundra owner
    Correct it doesn't fully charge but only when it gets very low and only to the bare minimum charge
  15. Sep 17, 2022 at 8:08 AM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    You can adjust the display settings for gauges. I believe the one in the picture is called the "tow/haul" gauges or something to that effect as it displays a visual for transmission and oil temps.
    SWB Tundra[QUOTED] likes this.
