Skinny Tall Tires
Discussion in 'Wheels & Tires' started by Skierdad, Sep 16, 2022.
  1. Sep 16, 2022 at 6:48 AM
    Skierdad
    Skierdad [OP] New Member
    Skierdad
    2019 Tundra from 2010 Tundra
    Hey all. Been a while since I posted. 2019 Tundra TRD. 2" level in the back, 3" in the front. I am currently running 275/60R20 on stock rims.
    I want to go to a skinny tire. No more of this 10" and wider crap. I would ideally like to go to a more retro taller skinnier tire look but finding a tire is unbelievably hard. I don't want to lose height (currently about 33") but want to drop at least an inch off width.
    Been trying to use the tire comparison website and would love to find a 235/70R20 tire. That would allow me the same height but I would go from 10.8" to 9.3" in width. Nobody makes that tire that I can find. Have tried tirerack and discounttires. I have even tried looking at walmart cheap tires.
    Looking for an AT or MT tire. Do I need to look at commercial tires? What am I doing wrong?
  2. Sep 16, 2022 at 6:56 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    If you change rims you should have more options, going to a 18 or 17 inch rim will open up more options.
    Not a cheap fix, unless you find a good deal.
    275 70 R18, but if your lifted you may need to go larger
    Sierradevil likes this.
  3. Sep 16, 2022 at 8:48 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    MT Baja Boss has a 255/85R18 size. That's 34.57" tall with a 10.03" section width. It's a 10" wide 35. (35s are actually 34.5" tall)
    Kenda Klever makes (or made?) an AT KR28 in 275/80R18. 275 is 10.82" wide, but the tire is again the same as a 35 in height.
  4. Sep 16, 2022 at 10:56 AM
    Skierdad
    Skierdad
    Thanks for the help everyone. 35" is too tall. I like the look of mine at 33" but I don't want something wider than 10". I would prefer to get to that 9" range.
    MT Baja Boss I might have to look in to.
  5. Sep 16, 2022 at 11:14 AM
    Terndrerrr
    Music City
    6UR-FE
    255/80R17 has 8 options on discount tire. That's your 33x10, but you'd need to go to 17" rims. I'm not sure a 33x10 exists in an 18" rim.
    255/70R18 is a 32x10, and there are tons of options in that size.
