True level
Discussion in 'Suspension' started by Goosedog, Sep 14, 2022.
  1. Sep 14, 2022 at 1:55 PM
    Goosedog
    Goosedog [OP] New Member
    Mark
    2020 Limited
    Which spacer kit will truly level a stock 2020 Limited Crew Max, a 3/2 or a 3/1? I'm guessing a 3/1 is level and a 3/2 keeps the factory rake.
  2. Sep 16, 2022 at 6:32 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Stock rake is 2 inches. Lift the front 2 inches and the truck will be level.
    Goosedog[OP] likes this.
  3. Sep 16, 2022 at 6:41 AM
    Goosedog
    Mark
    2020 Limited
    So lifting the front 3" and the rear 1" (which is my intention) I'll still be at dead level, Thanks
  4. Sep 16, 2022 at 6:49 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Yep agreed, every truck is a bit different but it's roughly two inches. You can park somewhere flat and measure from the bottom middle of the tire to the wheel well in the front and back to see. Mine was about 2-1/8" difference so I went with a 3/1 leveling kit and it sits perfectly level. Even if it still has a touch of rake you'd never be able to tell over that span.
