Stupid Question: how do I unplug the TSS harness for grill removal / FRAC install?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Sep 13, 2022.
  1. Sep 13, 2022 at 4:11 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    Ok folks. I’m feeling pretty dumb. First time working on my truck behind any panels.
    I’m trying to remove the front grill to install my FRAC harness. I got the grill pulled off its clips, but I can’t pull it off entirely with the TSS harness plugged in. Removed the square panel, but I can’t seem to figure out how to unplug the harness. I don’t see any tabs. It doesn’t seem to pull apart. And I don’t want to apply to much force trying, for fear I’ll break it.
    So what’s the magic trick for unplugging the harness?
    Help an idiot out, please?
  2. Sep 13, 2022 at 4:27 PM
    18" TRD Off Road Wheels
    Not the greatest video, but it shows where, kinda. This guy didn't take the little access door off on the top of the grille. I remember doing it, but that was about 3 years ago.
    https://youtu.be/yTDwVSsAG_w?t=87
  3. Sep 13, 2022 at 4:36 PM
    SFTundra
    SFTundra New Member
    Jimmy
    for some cars, the connectors are really tight. You have to wear it out abit until they are easier to remove. The best way I find is, use a tiny micro flat head screw driver. The ones you use for small electronics, while pressing on the connected . if you pry in the middle where the tab is, it helps with the removal.
