  1. Sep 10, 2022 at 10:42 AM
    At least I know what a control arm is!
    It’s the “arm” or sub selection of study participants that receive the standardized method to which the method to be studied is compared against.
    Tripleconpanna likes this.
  2. Sep 10, 2022 at 10:48 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Sounds like what I might expect out of a shop full of 8th graders. I don’t leave many reviews on Google, and they’re never out of spite, but I would leave one for that shop. People need to be aware of what they’re getting into.
  3. Sep 10, 2022 at 11:03 AM
    Cthulhu
    Sounds like an episode title of one of my favorite shows, Succession:
    Shit Show at the Fuck Factory
    Mike59 and ATV25 like this.
  4. Sep 10, 2022 at 11:43 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Tested the tires and 4L for the first time. I’m diggin this full size truck. My homie came out with his taco.
  5. Sep 10, 2022 at 3:46 PM
    SAGE63
    San Diego County
    Installed ICON 3.0 VS RR CDCV Coilovers and RXT 2.5 Omega series RR Rears..20220910_125545.jpg 20220910_135539.jpg
  6. Sep 10, 2022 at 5:41 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Is their any noticeable difference running those sway bar endlinks?
    SAGE63[QUOTED] likes this.
  7. Sep 10, 2022 at 5:49 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    installed ARB rear diff breather.
    ran some wire getting ready to connect extra backup lights
  8. Sep 10, 2022 at 5:58 PM
    This.....also installed a Roku with it.
    Nbab23, rebmo, lowball and 18 others like this.
  9. Sep 10, 2022 at 9:17 PM
    Hippyhunter
    Hippyhunter New Member
    2018 Tundra Platinum 4X4
    SDHQ ABS Protectors, RSI Rock Sliders w/top plate, RCI front skid, RCI A-Arm Skids
    What did I do with my Tundra today? I BOUGHT IT! Then filled it up! I am WAY NEW HERE!!! 2018 TSS w/ 114k Tulsa OK.....here to learn.
    OHwendTrd, Giskk, cartage1 and 27 others like this.
  10. Sep 10, 2022 at 9:23 PM
    Welcome from NY.
  11. Sep 10, 2022 at 9:59 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    That looks great, what unit is that? I know a pioneer, but what model? It almost looks oem. How far that stick out, any side pics? Also how do you like the unit? Any real positives or negatives? TIA
    bulldog93 and IsaiahCanada like this.
  12. Sep 10, 2022 at 10:04 PM
    mgm16trdpro
    Northern NJ
    Congrats on a great vehicle. Since you're new here I'll just give ya a heads up. Many of us here are a pics or it didn't happen group. Don't be shy and good luck on your recent purchase.
    cartage1 likes this.
  13. Sep 10, 2022 at 10:27 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    My 2020 TRD Sport has storage, but it’s a Double Cab
    Wallygator and Mike59 like this.
  14. Sep 10, 2022 at 11:00 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome!
    :worthless:
    reywcms and RegGex like this.
  15. Sep 10, 2022 at 11:56 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Added perfectly obnoxious air horns to my onboard air system. To me they are like my EDC, only for judicious use but there if you need them. After riding sport bikes and Harley's my entire life I firmly believe in the old "loud pipes save lives" adage. I do live in Florida after all...
    https://hornblasters.com/products/shocker-xl-train-horn
    I went with HornBlasters Shocker XL train horns mounted stealth fashion behind my grill. I can't in any way justify deleting my spare for air horn installation so I spent some time and thought and fabricated a mount out of 1" aluminum angle "iron" and flat bar with all SS hardware. Only needed to drill two small holes in my sheet metal and otherwise used existing mounting points. Secured them very firmly so they should stand up well to wind pressure at speed and the vibration from trail riding washboard roads. I also tried to align the mount along existing hardware borders to minimize air flow restriction. These horns work great with my ARB Twin compressor and a 3 gallon aluminum bottle mounted underneath the truck above the PS rocker panel.
  16. Sep 10, 2022 at 11:58 PM
    SAGE63
    San Diego County
    keeping the sway bar definetly reduces the roll. Those are Jomax sway bar links
  17. Sep 11, 2022 at 12:16 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix,
  18. Sep 11, 2022 at 5:05 AM
    It is the DMH-WT76NEX. It is the same identical unit as the 7600NEX. I like it so far. I still have to go through all the settings and learn the menus. It's definitely a different layout compared to the Pioneer that I removed.
    Compress_20220910_172100_0134.jpg Compress_20220910_172100_0607.jpg Compress_20220910_172100_0363.jpg
  19. Sep 11, 2022 at 7:19 AM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Congrats! Hide your wallet.
  20. Sep 11, 2022 at 7:26 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Congrats, and welcome from TX.
  21. Sep 11, 2022 at 1:09 PM
    moodywizard
    moodywizard New Member
    Lost
    2017 Tundra 4x4 Crew Max
    Installed some goodies last weekend and adjusted the coilovers this weekend. Rides a lot better over the mall speed bumps now!
  22. Sep 11, 2022 at 1:11 PM
    moodywizard
    Lost
    Also installed the trd exhaust with down pipes I picked up from a member here, thanks again!
  23. Sep 11, 2022 at 1:22 PM
    moodywizard
    Lost
    Forgot to add I took advantage the last few RCI sales and first installed their engine and trans skid with cat shields. Yesterday fedex delivered the gas tank skid I purchased during the Labor Day weekend sale. Only issue ran into them sending no 3/8 nuts for the carriage bolts. After watching notre dame getting humiliated and tanking a nap from drinking ponied up and went to Home Depot and installed late last night. Been a busy last few weekends lol I was hesitant on buying the fuel tank skid but my stock plastic one was bent and was an eye sore looking from the side all the time.
  24. Sep 11, 2022 at 2:58 PM
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
  25. Sep 11, 2022 at 3:55 PM
    Nice backdrop. I wish we had mountains here lol. Adorable girls! Mine are grown now ;).
    CaptRussia253[QUOTED] likes this.
  26. Sep 11, 2022 at 3:58 PM
    CaptRussia253
    Ruslan
    Ya the summers are beautiful here. I do plan on moving though as I can’t stand the 6 months of rain. And thank you. They love tagging along and have been on every trip with me and my wife.
  27. Sep 11, 2022 at 4:17 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    ahh... 2 Broke Girls w/Kat Dennings!!!! :drool::drool::drool:
  28. Sep 11, 2022 at 4:18 PM
    Either one.....:D
  29. Sep 11, 2022 at 4:21 PM
    That's awesome that they love to tag along. Yeah it does rain alot up there. I was stationed in Montana for 5 years....I miss it. Fl has its perks but Palm trees and 80 degrees during the holidays drives me nuts.
  30. Sep 11, 2022 at 4:54 PM
    Installed a new mountain decal after the radio installation. Also picked up my free OEM sunshade. I tried to order it through the parts department a few times but it has never shown up. My buddy that works there found one in the corner of the storage room. His manager told him to let me have it for free. Score!
