Prospeed dyno
Discussion in 'Performance and Tuning' started by Oz_zy, Sep 6, 2022.
  1. Sep 6, 2022 at 11:06 AM
    Oz_zy
    Oz_zy [OP] New Member
    2016 magnetic grey tundra tss off-road
    Morimoto headlights Morimoto xb led fog light Db custom tundra grill with led Spyder smoked led taillight
    I am about to get truck dyno tune by prospeed I have a cel because I removed the 2 front cats when I installed headers. They told me that they cannot erase the cel??? I thought tunning the truck would make the cel go away????
  2. Sep 6, 2022 at 11:41 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    What CEL code?
    Oz_zy[OP] likes this.
  3. Sep 6, 2022 at 12:00 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    At least in the Tacoma you absolutely can have those removed with HPTuners. Idk about Tundra but I'd assume it's the same...you basically turn off that monitoring PID
    TundraMoe, snivilous and Oz_zy[OP] like this.
  4. Sep 6, 2022 at 12:11 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Do you have o2 sensors in your pipe right out of the collectors?
    Oz_zy[QUOTED][OP] likes this.
  5. Sep 6, 2022 at 12:14 PM
    Oz_zy
    Yes I still have the o2 sensors
  6. Sep 6, 2022 at 12:15 PM
    Oz_zy
    I know if I get tuned by dap he told me that it would erase the code....so why wouldn't hp tuner from pro speed??
  7. Sep 6, 2022 at 12:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Have you put new sensors in? The code should tell you which one to replace. I've replaced both of mine.
  8. Sep 6, 2022 at 1:11 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    They should be able to disable the codes, I wonder if they just don’t want to disable any emissions related equipment. Not sure what the local laws are, but I’m sure they must do it all the time.
    M3Tundra-JK, Oz_zy[OP] and snivilous like this.
  9. Sep 6, 2022 at 1:54 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Ok, so you installed headers, did you leave the set up like this:
    Headers => primary O2 => cats => secondary O2?
    or
    Headers => primary O2 => Secondary O2 => cats?
  10. Sep 6, 2022 at 3:53 PM
    Oz_zy
    Headers---primary 02---secondary 02---cats
  11. Sep 6, 2022 at 3:54 PM
    Oz_zy
    I live in Texas and I've gotten to a couple of shops and they all say that they're tune will get rid of the cel
  12. Sep 6, 2022 at 4:05 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Tunes can get rid of LEAN/RICH environments that can cause CEL. If the CEL is caused by missing hardware, they just disable the monitoring. It's not necessarily tuning it away. But you should find out what the CEL is reading if you can.
    Also do you have long tube headers? if so, is the primary 02 sensor after the merge of the 4 tubes or before? My Doug Thorley had both options. Preferred is after the collector but an O2 harness extension was required.
  13. Sep 6, 2022 at 5:42 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    You would rather use a simulator. Making the monitor not run keeps the cycle from being complete.
    Oz_zy[OP] and M3Tundra-JK like this.
  14. Sep 6, 2022 at 5:44 PM
    M3Tundra-JK
    Scott
    2005 GX470
    I forgot about the O2 sims. Yes I did have the URD O2 sim on my primary sensor. However laws changed since then and URD no longer sells them. Idk who does
  15. Sep 6, 2022 at 6:56 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    You could try Fabspeed Motorsport O2 sensor spacers with mini-cats.
    I had them on my twin turbo Tacoma in El Paso, TX. Pricey option though and Fabspeed naturally doesn't guarantee success.
    That said, the CELs for p0420/30 can be turned off. I use VFTuner on behalf of YotaWerx Tuning and can confirm that they're available in the software to turn off via tune.
    Medic343 likes this.
  16. Sep 6, 2022 at 7:04 PM
    M3Tundra-JK
    Scott
    2005 GX470
    One thing to mention that turning off the PID will still show up on emissions testing when they connect to the odb. The O2 sim will fool it. Likely the reason they can't be sold anymore
  17. Sep 6, 2022 at 7:13 PM
    mZiggy
    mZiggy Honey badger
    Marc
    In Texas, you can pass the safety inspection if you have no cel and if you have one monitored monitor in a not ready state. That info came straight from my buddy at the dealer when I had asked him, he's a service guy.
    Idk about the tundra but I'm assuming it's the same situation, but on the 3GT the rear sensors are not monitored. I passed the state inspection with both my p0420 and 30 turned off, with no CEL present. I was not catless, but had high flow cats. Not that it mattered, since the codes were off.
    M3Tundra-JK[QUOTED] likes this.
  18. Sep 6, 2022 at 8:05 PM
    Oz_zy
    Yes I am running long tube headers
    Yes
  19. Sep 6, 2022 at 8:06 PM
    Oz_zy
    What would you recommend??
    I can't find 02 simulator with good reviews
  20. Sep 6, 2022 at 8:58 PM
    HTXtundra4x4
    HTXtundra4x4 Texas
    Katy, TX
    2018 SR5 CM MGM
    You don’t need sims or even the mini cat spacers. Just plain 90 degree spacers will stop the 420/430 codes. You don’t have to bother with the 12v wiring for the sims either and they’re cheaper than the mini cat ones that may or may not actually work. My truck is straight piped because my cats were stolen. 90 degree spacers and no CEL for a few thousand miles now.
  21. Sep 6, 2022 at 9:07 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm running 0 cats and 0 sims with 0 CELs.
    I have LT headers and 2 upstream sensors (Denso) with extensions from ARH.
    TX210Tundra and Oz_zy[OP] like this.
  22. Sep 7, 2022 at 8:24 AM
    Downytide
    GTA
    If you running the cats, why not just slot it between the primary and secondary? probably get rid of the codes and has no change in performance, you can buy harness extenders easily.
  23. Sep 9, 2022 at 6:39 PM
    Oz_zy
    So headers---primary o2---cats---secondary02
    And I am have a hard time finding 02 extension
    Do you know where to buy?
  24. Sep 9, 2022 at 7:03 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    ARH sells them. Call them up.
  25. Sep 9, 2022 at 7:32 PM
    Downytide
    GTA
  26. Sep 10, 2022 at 6:27 PM
    Oz_zy
    Here is another question if i move the cats forward how would I go to attach the o2 sensor to the midpipes behind the cats without the female bung connector? Also I don't think I would need 02 extenders....the silver pipe is where the front cats were so if I moved the back cats to replace where the silver pipe the 02 harness actually reach
  27. Sep 11, 2022 at 6:20 AM
    HTXtundra4x4
    HTXtundra4x4 Texas
    Katy, TX
    2018 SR5 CM MGM
    TXTundra2722 and Oz_zy[OP] like this.
  28. Sep 11, 2022 at 6:30 AM
    Oz_zy
  29. Sep 11, 2022 at 7:03 AM
    Oz_zy
  30. Sep 11, 2022 at 8:24 AM
    HTXtundra4x4
    HTXtundra4x4 Texas
    Katy, TX
    2018 SR5 CM MGM
    Yes, that's all you have to do. Plug and play. And yes, you'll need to clear the 420/430 codes with a scan tool. Or take it to a parts store and they can clear them for you.
