Toyota Tundra 2022
Discussion in '3rd Gen Tundras (2022+)' started by Matvey tod, Sep 9, 2022.
  1. Sep 9, 2022 at 5:20 PM
    Matvey tod
    Matvey tod [OP] New Member
    2022 Silver Tundra 1794 edition
    I just order some 35 nitto ridge grappler for my tundra and can’t find any information about leveling kits that work with Toyotas OED air ride suspension. Need help!
  2. Sep 9, 2022 at 5:41 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Um.
    Siblue likes this.
  3. Sep 9, 2022 at 6:16 PM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    You may need to remove your mud flaps and ride around unlifted for a while until they are released…dole are doing it so you won’t be the first/last.
    welcome and enjoy the truck
  4. Sep 9, 2022 at 9:02 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC
  5. Sep 10, 2022 at 2:36 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    There are threads discussing lifting air ride trucks and you can make adjustments so the rear rides a little higher- just search upper right. You will need new wheels to run 35s, stock wheels are thinner than most 35s are designed for and the stock offset will have 1250 wide tires hitting UCA. You can probably run wheel spacers with the stocker wheels and get them to fit.
